Last updated by Andreas W. 11 months, 4 weeks ago.
March 31, 2025 at 1:40 pm #16879664
morganF-3
I'm trying to delete old translations on my site hidden link. I managed to delete 5000 images by repeatedly clicking the button, but now it seems stuck and won't delete anything else.
The deletion process is stuck and not completing as expected.
Why is the deletion process not completing?
How can I successfully delete the remaining translations?
March 31, 2025 at 7:02 pm #16880702
Andrey
WPML Supporter since 06/2013
While one of my teammates takes care of your ticket, I will provide you with the first debugging steps.
Please update your WPML plugin and add-ons to the latest version, 4.7.2, to benefit from the latest bug fixes and improvements. This may not necessarily resolve your problem; however, we need to work on the newest code available to troubleshoot the issue best.
You can check the latest released versions under "My Account -> Downloads" on this site. Instructions to update can be found here: http://wpml.org/faq/install-wpml/
If you do not see the updates, you might need to click the Check for updates button in the Plugins → Add New Plugin → Commercial tab.
If this is still the issue, please check if there is no fatal error when you click the button. You need to enable debugging. You can add a few lines to the site’s wp-config.php file. With the error log enabled, you will see the actual problem.
To enable it, open your wp-config.php file and look for define(‘WP_DEBUG’, false);. Change it to:
define('WP_DEBUG', true);
To enable the error logging to a file on the server, you need to add yet one more similar line:
The errors will be saved to a debug.log log file inside the /wp-content/directory.
April 1, 2025 at 8:40 am #16881833
morganF-3
Everything up to date and no fatal error. Just a loader that never ends and do nothing.
April 2, 2025 at 4:43 am #16885261
IMPORTANT
Video:
April 8, 2025 at 10:32 pm #16911080
Once issues like this occur, I would always suggest enabling the languages again, hiding them from Frontend for visitors, and then cleaning up the site manually.
Once I try to do this and for example try to delete many items, like for example 200 products at the same time, I am running into Timeout Errors coming from the server.
I see the time limit is set currently to 3600 seconds but anyhow it seems the server is not able to process the request or it simply takes too long.
I would suggest you ask the hosting company to take a look into the server's error.log. Maybe this will give a better idea about why those Timeout Errors occur on the server.
The topic ‘[Closed] Problem deleting old translations’ is closed to new replies.
