I am trying to:the EN button on the Home page is linking to the wrong page and not the EN home page.
I expected to see: hidden link but in english
Instead, I got: hidden link
There is also an issue with the menu in english it has not replicated the layout from the danish menu. its placing a white banner behind each menu itemes but needs to look like the danish site. see screen shots with the correct danish menu layout and the wrong EN layout.
New threads created by Eran Helzer and linked to this one are listed below:
I had a look at your website and found something that may give us a clue about what the issue is.
It seems like the language switcher is linking to the correct URL, but that URL is redirecting to the incorrect one. I attached a screenshot showing that, and you can also see the redirection if you try to go to the English homepage: hidden link
This leads me to think that there one of these is possibly the reason:
- Some other plugin
- Some custom code
In order to know for sure, let's perform a minimal test and proceed from there.
Please deactivate all other plugins, other than WPML, and switch to a WordPress default theme.
If this does not resolve the redirect issue, we will proceed with other troubleshooting steps.
Regarding the menu styling issue, I will split that into another ticket. It is our policy to keep it to one issue per ticket, that way everything is clear and organized.
I tried what you suggested but the issue still remains.
I do have redirect plugin installed and in there was a a redirect for this page hidden link, but had nothing to do with the EN homepage. I have switched of the redirect plugin for now.
All this started yesterday, I could get into the EN homepage but had a issue that the box saying facilitation of meeting (see screenshot I have take inside the Avada builder) when clicked on it went to the Danish page. I did an update on the meeting facilitation page on the danish page and also updated the translation. Then suddenly the homepage EN switcher started to redirect to the "meeting facilitation" page.
In that case, I would like to have admin access to your site, or preferably a staging one where the issue is replicated. I may be able to find and solve the issue quickly.
I may need to:
- Deactivate plugins
- Change themes
- Change general settings
If you do not want me to do any of these, please say so.
Please confirm you have a working backup before we proceed.
I have set your next reply to be private so you can share credentials there.
I have set the ticket to auto-close in two weeks. You will be notified before it is closed, if you want to keep it open longer just write another reply here.
The topic ‘[Closed] Problem with links.’ is closed to new replies.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
