You are managing a bilingual website and encountering issues with The Events Calendar plugin. Specifically, event links are redirecting incorrectly (e.g., /(/?:month|mois)) and translations are not functioning properly in the WPML admin section. Previously working configurations have started showing errors, such as incorrect slugs in URLs.
First, ensure that The Events Calendar plugin is compatible with WPML by checking the known issues.
For the redirection issue, apply the workaround provided on the errata page.
For the translation issues:
1. Navigate to WPML -> Strings Translation.
2. Click on 'Translate texts in admin screens'.
3. In the Admin Texts Translation section, search for 'evenement' and 'evenements'.
4. Select these strings and move them to Strings Translation.
5. Translate them into English.
If these steps do not resolve your issues or if the solution becomes outdated, we recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket.
Last updated by jean-francoisS-2 6 months, 1 week ago.
Assisted by: Itamar.
January 7, 2025 at 8:48 pm #16571408 | |
jean-francoisS-2 |
January 7, 2025 at 10:00 pm #16571494 | |
Hi, The Events Calendar plugin by Modern Tribe, Inc. is officially compatible with WPML. However, there are a few known issues. You can see all the known issues here. The first issue you mentioned (/(/?:month|mois)) has a workaround. Please read the errata page at the following link and apply the workaround. https://wpml.org/errata/the-events-calendar-incorrect-link-format-with-custom-slug-translations/ I'm not entirely sure, but the second issue you mentioned can be seen on the following errata page, which also includes a workaround. https://wpml.org/errata/the-events-calendar-recurring-event-instances-link-to-first-occurrence/ If not, please see if any other known issues relate to your case. Please let me know how it goes. Regards, |
January 8, 2025 at 1:18 pm #16573582 | |
jean-francoisS-2 |
Hi, Thanks for the quick response. I have already tried the fix of this link https://wpml.org/errata/the-events-calendar-incorrect-link-format-with-custom-slug-translations/, but it keeps happening. The thing I don't understand, it was perfectly working a month ago, but now the translations are not registering only on the part where The Events Calendar is shown (the events page in our case). For the second point, our post type is already at translatable. If you need any other information, let me know. FYI : Here's a working example (with wayback machine) : hidden link. I also notice the slug being evenements in english, and not events on some case with our new bug (see hidden link), which is incorrect, event though we have changed it in the admin section. Thanks. |
January 9, 2025 at 11:38 am #16577384 | |
Hi, I can see that the first problem persists on your site. Please see the attached screenshot. There seems to be a variation of this problem because after clicking 'Month' the link turns like this: hidden link?:list|liste)/ About the second problem, you wrote: "For the second point, our post type is already at translatable." It is unclear to me. Please answer my questions. If you need further help with this, please share the access details for your site with me. I'm enabling a private message for the following reply. |
January 9, 2025 at 8:16 pm #16579772 | |
Hi, and thanks for the access details. However, your staging site does not load on my side. I waited for 5 minutes, and it was not loading. Please see the attached screenshot. Please correct this issue and let me know once it is ready. Please note that my weekend is Friday-Saturday, and I'll be able to continue to check this issue and help you on Sunday. Regards, |
January 9, 2025 at 8:22 pm #16579809 | |
jean-francoisS-2 |
It should be good now, the staging was password protected. If it doesn't load, please try in private navigation. Else, I will try something else. Thank you. |
January 9, 2025 at 8:46 pm #16579843 | |
Hi, I can see that the staging site loads now. However, you marked this ticket as resolved. Regards, |
January 9, 2025 at 9:21 pm #16579914 | |
jean-francoisS-2 |
Yes sorry. |
January 12, 2025 at 3:11 pm #16585928 | |
Hi, I'm going to need the access details for your site again. This is because once a ticket is marked as resolved, our system automatically removes the access details from the private messages. If you need further help with this, please share the access details to your site with me. I'm enabling a private message for the following reply. |
January 15, 2025 at 2:25 pm #16597694 | |
Hi, and thanks for the access details. I tried many things on your staging site. To investigate those problems, I moved the site into a minimum environment. I switched the theme to a default WordPress theme and deactivated all the plugins except WPML, Strings Translation, and the Events Calendar + Pro plugins. Unfortunately, most of the problems you mentioned continue. However, I was able to find the workaround for the strings issue. Please see the attached screenshot. The workaround is explained in this errata page. https://wpml.org/errata/wp-6-7-translations-not-loaded-for-the-events-calendar-plugin/ I suggest you also apply it to your production site. Regards, |
January 15, 2025 at 11:07 pm #16599420 | |
jean-francoisS-2 |
Yes you can escalate further ๐ |
January 16, 2025 at 9:00 pm #16603906 | |
Thanks. I've escalated this issue to our second-tier supporters. I'll update you here once I have news about this issue. Regards, |
January 23, 2025 at 5:59 pm #16629391 | |
Hi, Our second-tier supporter has found a solution to this problem. You can see it is fixed on the staging site. In addition to applying the workaround from the errata pages, you should also do the following. 1. Go to WPML -> Strings Translation, scroll down, and click the Translate texts in admin screens ยป link. 2. In the Admin Texts Translation section, search for "evenement" (and "evenements"). Please see the attached screenshot. 3. Select those strings and move them to Strings Translation. 4. Translate them into English in Strings Translation. Please see the attached screenshot. Please let me know how it goes. Regards, |
January 27, 2025 at 2:25 pm #16638354 | |
jean-francoisS-2 |
Thank you!! This work for me ๐ |
