You are trying to center the text of the language switcher in a widget, but it appears left-aligned due to the theme's CSS overriding your changes.
To center the language switcher text, you need to apply specific CSS rules that can handle the theme's existing CSS. Here is the correct CSS to use:
ul .wpml-ls-menu-item a {
    display: flex;
    align-items: center;
    justify-content: center;
If this solution does not work because it might be outdated or not applicable to your case, we recommend opening a new support ticket. Also, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
Last updated by roxanneS 2 years, 11 months ago.
March 16, 2023 at 9:27 pm #13264421
roxanneS
I am trying to: Have the language switcher text align center. The switcher is used in a widget.
I expected to see: The language name centered horizontally in the column
Instead, I got:The language is left-aligned.
March 16, 2023 at 9:57 pm #13264511
Take note that this is a theme issue.
Please try this CSS solution in the Customizer > Additional CSS or the theme's style.css file:
.wpml-ls-item > a[title] {
  text-align: center!important;
March 17, 2023 at 1:57 pm #13270107
roxanneS
Unfortunately, that solution does not work.
March 17, 2023 at 3:54 pm #13271075
As mentioned, this is actually a topic for the theme support, as it is the theme's style that handles the language switcher but can offer to have a closer look at this and try to adjust this for you.
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue.
IMPORTANT
The steps are also shown in this video: hidden link
March 17, 2023 at 5:03 pm #13271543
Those issues are always these issues, as the menu is designed by CSS coming from the theme.
My CSS suggestion was incorrect, the element looks like that:
<span class="wpml-ls-native" lang="fr">Français</span>
The problem is, when I try to apply CSS to this element, then it does not always take effect, as the theme CSS is overwriting my changes.
The reason for a different layout is that the other menu items use a different markup in the theme:
hidden link">Contact Us
The correct CSS in this case is:
    display: flex;
Take note, that usually, theme support always helps with such problems.
