The client is experiencing issues with translating records using the WPML editor, where clicking the 'Abschließen' button redirects back to the original record instead of the translated version. Additionally, there are problems with ACF fields not being translated correctly, and line breaks and paragraphs being stripped from the translated content.
1. Ensure you are using the visual editor instead of the text editor to maintain formatting such as paragraphs and line breaks.
2. For ACF fields, set the translation preferences appropriately:
- Set 'Field Groups (acf-field-group)' to 'Not translatable' under 'WPML > Settings > Post Types Translation'.
- Use 'Copy' for special fields like 'Repeater' and 'Flexible'.
- Set subfields of flexible content to 'Translatable'.
- For fields not requiring translation, use 'Copy' to keep the same value across translations.
3. Update the translation preferences and make a minor modification to the original page to trigger an update.
4. Check the 'Presentation' tab in the ACF field settings to ensure proper rendering of new lines and automatic paragraph addition.
If these steps do not resolve your issues or the solution seems outdated, we recommend opening a new support ticket. Additionally, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. For further assistance, you can also visit our support forum at WPML support forum.
This topic contains 30 replies, has 3 voices.
Last updated by Ilyes 1 year, 7 months ago.
Assisted by: Ilyes.
September 17, 2024 at 4:24 am #16186012
danielM-3
@Nicolas: Could you please provide me a fixed ip which i can enable for backend access?
September 17, 2024 at 12:08 pm #16188159
Nicolas V.
WPML Supporter since 12/2021
My IP: 179.6.6.195
Also, the line break issue has been reported and we offer 2 workarounds already. Could you please try them?
https://wpml.org/errata/line-breaks-are-ignored-when-using-the-advanced-translation-edior/
September 18, 2024 at 7:40 am #16191313
danielM-3
@Nicolas: The cms access should now work for your IP.
September 18, 2024 at 7:41 am #16191315
danielM-3
@Nicolas: The two workarounds you mentioned did not help either.
September 18, 2024 at 4:29 pm #16194805
Nicolas V.
I still have the error message and can't access the site. I've checked and my IP address didn't change. I can use a VPN if I need to access it from a specific country (but in that case I can't provide you a fixed IP address).
September 19, 2024 at 8:11 am #16196736
danielM-3
now the access issue is fixed, could you please check again?
Thx.
September 20, 2024 at 12:30 pm #16202933
Ilyes
Nicolas is currently in vacation, I will take care of your ticket in the meantime,
Your site hidden link doesn't seem to be accessible for me,
My IP address is 137.220.54.14 , I could use VPN to connect to most countries if that helps,
Let me know what I should do to connect to your site,
Best,
September 23, 2024 at 5:52 am #16207344
danielM-3
@Ilyes: Your ip is now enabled too; please check.
September 23, 2024 at 7:17 pm #16211580
Ilyes
I'm able to login to your site, I will get back to you once I found a solution,
Thank you for your patience,
September 25, 2024 at 7:35 pm #16222371
Ilyes
Hello again,
Could you please whitelist this IP address too : 142.188.57.214 , My IP changed recently and that removed my access to your site,
Thank you for your help,
September 27, 2024 at 10:50 am #16229473
danielM-3
The IP 142.188.57.214 is now permitted to access.
September 30, 2024 at 12:01 pm #16236010
danielM-3
Is there any progress on this issue?
September 30, 2024 at 1:46 pm #16236557
Ilyes
I'm sorry for the delay in response, our IPs keeps changing as we are using dynamic ones,
We would like to perform the following fixes: https://wpml.org/errata/line-breaks-are-ignored-when-using-the-advanced-translation-edior/
You could either apply them yourself or please deactivate that protection for a couple of days or deactivate it for a specific country (and I can then use VPN).
I will be waiting for your response for immediate follow-up,
October 3, 2024 at 10:55 am #16249283
danielM-3
Could you please provide an save input form for the new basic auth credentials?
October 3, 2024 at 6:13 pm #16251676
Ilyes
Yes of course, your next reply will be private,
