The client reported an issue with the Croatian version of a WooCommerce product page showing an ERR_TOO_MANY_REDIRECTS error and having a URL with double slashes. Additionally, the featured image and attribute images were not displaying on the translated product page.
We advised the client to first take a full backup of their site and database. The steps included:
1) Checking in String Translation for the problematic URL and correcting it for the Croatian translation. We also suggested running the process to scan and auto-adjust links under WPML -> Settings -> Translate link targets.
2) Deactivating all plugins except for WPML, String Translation, WooCommerce, and WCML to check if the issue persists.
3) Switching to a standard theme like 2024 or 2021 to rule out theme-related issues.
4) Re-activating plugins one by one to identify any conflicts, and then switching back to the original theme to check for issues.
Alternatively, client found that plugin SEO press was causing the url to look like this, resetting the plugin fixed the issue.
If these steps do not resolve the issue or if the solution seems outdated or irrelevant, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket at WPML support forum for further assistance.
This topic contains 7 replies, has 1 voice.
Last updated by ziga pipan 1 year, 2 months ago.
Assisted by: Waqas Bin Hasan.
February 19, 2025 at 4:44 pm #16725985
ziga pipan
I have my WooCommerce products translated using WPML, and all is ok, but this one product is giving me problems. The original version is working ok: hidden link. However, the Croatian version is not opening and is showing an error.
I have my Woocommerce products translated and all is ok, but this one product is giving me problems.
Original version is working ok
but croatianan is not opening, it's saying ERR_TOO_MANY_REDIRECTS
Somehow, I don't know how, it's got two dashes in url
but it's also not showing featured image or attributes images on translations.
Why is the Croatian version of my product showing an ERR_TOO_MANY_REDIRECTS error?
How can I fix the URL issue with two dashes in the Croatian version?
Why are the featured image and attribute images not showing on the translated product?
February 19, 2025 at 9:36 pm #16726896
Andrey
WPML Supporter since 06/2013
While one of my teammates works on your ticket, I'll provide you with some initial debugging steps.
Have you tried to recreate or duplicate this product?
Before proceeding, please ensure that your WPML plugin and add-ons are updated to the latest version, 4.7.1. This will allow you to take advantage of the latest bug fixes and improvements. While this update may not directly resolve your problem, it is essential for troubleshooting with the most current code.
You can check the latest available versions by going to "My Account -> Downloads" on our website. Instructions for updating can be found here: http://wpml.org/faq/install-wpml/
If you do not see any updates available, you may need to click the “Check for Updates” button in the Plugins → Add New Plugin → Commercial tab.
Please remember to back up your database before proceeding with any updates.
Let us know if the issue persists after you've completed the update.
February 19, 2025 at 11:43 pm #16727015
ziga pipan
Yes, after I submitted the debug information, the support form reminded me to update the plugin. I did, and I also clicked "this did not help" button.
Sorry, I thought you got this info.
February 20, 2025 at 10:35 am #16728987
Waqas Bin Hasan
WPML Supporter since 05/2014
I can see // (double-slash) in the URL hidden link. And if I remove the additional slash, it still runs into that too many redirects error.
I checked using hidden link and there are 19 redirects:
>>> <em><u>hidden link</u></em>
> 301 Moved Permanently
Status:	301 Moved Permanently
Code:	301
Connection:	close
x-redirect-by:	WPML
content-type:	text/html; charset=UTF-8
cache-control:	public, max-age=0
expires:	Thu, 20 Feb 2025 10:26:38 GMT
content-length:	0
date:	Thu, 20 Feb 2025 10:26:38 GMT
server:	LiteSpeed
vary:	User-Agent,Accept-Encoding
alt-svc:	h3=":443"; ma=2592000, h3-29=":443"; ma=2592000, h3-Q050=":443"; ma=2592000, h3-Q046=":443"; ma=2592000, h3-Q043=":443"; ma=2592000, quic=":443"; ma=2592000; v="43,46"
Code:	301
Connection:	close
x-redirect-by:	WordPress
expires:	Thu, 20 Feb 2025 10:26:40 GMT
content-length:	0
date:	Thu, 20 Feb 2025 10:26:40 GMT
server:	LiteSpeed
Code:	301
Connection:	close
x-redirect-by:	WPML
expires:	Thu, 20 Feb 2025 10:26:41 GMT
content-length:	0
date:	Thu, 20 Feb 2025 10:26:41 GMT
server:	LiteSpeed
Code:	301
Connection:	close
expires:	Thu, 20 Feb 2025 10:26:42 GMT
content-length:	0
date:	Thu, 20 Feb 2025 10:26:43 GMT
server:	LiteSpeed
.... and so on....
As you can see it keeps switching between single and double slash.
Can you please try the following?
Take a full backup of your site and database before proceeding. It is highly advised to try these on a dev or staging site first, so your live site isn't compromised.
1) Check in String Translation for that URL and see if you can find anything related. If that URL exists, try to correct it for Croatian translation.
--- You can additionally go to WPML -> Settings -> Translate link targets and run the process to scan and auto-adjust the links.
2) If none of these helps, deactivate all plugins except WPML, String Translation, WooCommerce and WCML.
3) Switch to a standard theme like 2024 or 2021.
4) Check for the issue if it still happens.
5) Then start activating plugins one by one while keep checking for the issue. This way you 'll be able to pinpoint a conflict when & where it starts creating the problem.
6) If after activating all plugins you see that it still works fine, then switch to your theme and see if that's causing it.
Please let me know and I'll try my best to help you further on the matter.
Regards.
February 20, 2025 at 12:34 pm #16729532
ziga pipan
Thank yuo.
I found out thjat plugin SEO press was causing the url to look like this
If I disable it it opens ok
Even if I never set any settings, I resetted the plugin settings and now it opens ok.
question remains, why is the feature image and attributes images missing?
February 20, 2025 at 12:56 pm #16729606
Waqas Bin Hasan
Thank you for the updates and glad that issue was resolved.
For the other question/issue, I recommend opening a separate ticket/chat because as per forum policy we can only handle one issue per ticket/chat. So you can get more to the point help, without mixing up several issues in one long ticket.
February 20, 2025 at 1:20 pm #16729698
ziga pipan
it's actually tha same question from my original post
New threads created by Waqas Bin Hasan and linked to this one are listed below:
https://wpml.org/forums/topic/split-featured-and-attribute-images-not-showing-on-the-translated-product/
February 21, 2025 at 4:43 am #16732077
Waqas Bin Hasan
Yes of course the question is from your original message but the problem is different than the redirection issue.
However, I've split it to https://wpml.org/forums/topic/split-featured-and-attribute-images-not-showing-on-the-translated-product/ and 'll be handling in that ticket.
Please feel free to close this ticket as resolved.
February 21, 2025 at 11:26 am #16733305
ziga pipan
thank you!
