If you're experiencing issues with Turkish characters such as 'şçöğü' displaying as '?' after using automatic translation with WPML on your site, the issue might be related to the database character set.
We recommend checking if your database character set is set to UTF-8. You can find instructions on how to retrieve this information here.
If this solution does not apply to your case, or if it seems outdated, please open a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins.
Last updated by Otto 9 months, 2 weeks ago.
Assisted by: Otto.
| Author | Posts |
| March 10, 2025 at 3:04 pm #16797190 | |
bernaT |
| March 10, 2025 at 6:08 pm #16797931 | |
Marcel Supporter
Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: Europe/Madrid (GMT+02:00) |
Hi, before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process. Could you please check if your database character set is set to UTF-8? You can find instructions on how to retrieve this information here: Best regards, |
| March 11, 2025 at 9:58 am #16800590 | |
bernaT |
Yes, as can be seen in the photos attached, my database u452833898_iOe53 is already set to utf8mb4 with the collation utf8mb4_unicode_ci! I can write with Turkish Characters but the translated output with WPML is shown as => ???? How can we solve this matter? Best Regards |
| March 11, 2025 at 1:29 pm #16801970 | |
Otto WPML Supporter since 09/2015
Languages: English (English ) Spanish (Español ) Timezone: America/Argentina/Buenos_Aires (GMT-03:00) |
Hello, Thanks for your reply. I'll take care of this ticket. Which translation engine did you use for the automatic translation? To replicate the issue in my local development environment without affecting your website, could you provide me with a copy of your site? Please follow these steps: - Install this plugin. This will allow me to duplicate your site locally and investigate the issue. I set your next reply as private, which means only you and I can see and have access to it. You can share the download link safely (there is no need to share the credentials). Once the problem is resolved, I will delete the local site. Thanks! |
| March 12, 2025 at 2:52 pm #16807803 | |
bernaT |
It takes ages to create a backup. Can I share credentials? |
| March 12, 2025 at 3:46 pm #16808197 | |
Hi, In any case, before providing us with access to your site you'll need to have a backup :). You may know another tool that works faster, but you'll need to be able to restore it if something goes wrong. I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. The information you will enter is private, which means only you and I can see and have access to it. **IMPORTANT** Best Regards, |
| March 12, 2025 at 8:13 pm #16809153 | |
Hello, Thanks. I managed to get the DB (with WP Staging) and check it. Although your database and tables are fully set to utf8mb4, individual tables or columns may still be set differently. In phpMyAdmin, open the structure of key tables like _posts, _postmeta, _terms, _term_taxonomy, and verify each table and column’s collation. As far as I can see wp_posts has latin1_swedish_ci, and there are many more with this collation. Also, even if your database is configured for UTF-8, data might have been saved incorrectly in the past. After fixing the collation, check a problematic post directly in the database via phpMyAdmin to see if it displays Turkish characters correctly in the content fields. If it’s already stored incorrectly, you may need to re-enter or update that text in WordPress so it’s saved properly. Let me know if this helps, please. Best Regards, |
| March 15, 2025 at 2:23 pm #16819956 | |
bernaT |
Hello Otto, thank you for addressing the situation. I've created a PHP my admin user for you. Can I please share it so we can fix this problem once and for all. 1- Can you please adjust the chat so I can reply privately to share your details? 2- I've also used almost all my credit to translate, and all of the translations are wrong. Are we going to be able to use the lost credits again, or do you think it's translated correctly but is just showing wrong on the WordPress side? Thanks! |
| March 17, 2025 at 1:38 pm #16825385 | |
Hi, I think it's translated correctly but stored incorrectly due to the wrong collation of the tables. You may need to resend the content to translate but you should not be charged because of the translation memory feature of the Advanced Translation editor: I've enabled the private form. ❌ Please make a full website backup before proceeding ❌ Best Regards, |
| March 21, 2025 at 12:38 pm #16844522 | |
Hello, The user you provided doesn't have access to the site's DB. Only to the schema and an empty DB (see the screenshot attached). Can you please check? Best Regards, |
| March 21, 2025 at 12:50 pm #16844548 | |
bernaT |
Try the following usernames with the same password, please u452833898_z0aRu Thanks |
| March 21, 2025 at 4:03 pm #16845460 | |
Hello, The second user can't log in. The first one, logs in but the DB there doesn't seem to be the one on your site. It doesn't have WPML tables. I am enabling a new private reply so you can check and share the credentials for the DB. Thanks! |
| March 24, 2025 at 11:29 am #16851386 | |
Hello, I changed the collation of the columns of the posts and postmeta tables. Can you please check if this solves the problem? You may need to resend to translate the content. To do so, make a small change in the post title (like adding a space or a dot). Send the post to update the translation, Check if the issue is gone. Let me know your results, please. Best Regards, |
| March 25, 2025 at 3:53 pm #16858848 | |
bernaT |
The problem persists on the published pages, but it looks okay on the translation screen. Please check the photos attached. How can we solve this problem? Best |
| March 25, 2025 at 3:58 pm #16858899 | |
bernaT |
Also, I tried changing the name of the title of the courses, but the previous translations did not come back from memory, and all my automatic translation credit is finished. This is very frustrating! I thought using WPML Pro would make this process much more easier. Please help me fix this problem! Best |
