[Resolved] Problems with displaying languages in the header custom space
Problem: The client is experiencing issues with displaying the WPML language switcher in a custom header space created with Elementor and the Saasive theme. Solution: 1. Edit Your Header Template with Elementor: Access your WordPress admin, navigate to Templates → Theme Builder, and edit your header with Elementor. 2. Add the WPML Language Switcher Widget: In the Elementor editor, search for the WPML Language Switcher widget and add it to your header. 3. Customize and Publish: Customize the appearance of the language switcher and publish the changes. 4. Translate the Header: Ensure the header template is translated for all languages using WPML’s Translation Dashboard. 5. If the issue persists, consider adding the language switcher to the main menu for better visibility across all devices. You can manage this in WPML -> Languages -> Menu language switcher. 6. Adjust the style of the language switcher using CSS at WPML -> Languages -> Language switcher options -> Additional CSS.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, please open a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, you can contact us directly at WPML support forum.
This is a professional support service, and we do not tolerate incorrect language.
I understand your frustration, but the more you cooperate, the faster we will be able to solve any issues you have related to WPML.
Now, from your messages, I understand that you desire a language switcher that looks like this screenshot: hidden link with a transparent background and minimum width. If the above is correct, then we can help you adjust the CSS to achieve this desired style. In your next message, I need you to confirm that the style you are looking for is the one in the screenshot, and I also need your authorization to update the headers in the secondary languages, which are the steps I mentioned at the end of my previous message, but you didn't do it.
Please keep in mind that we are here to help you solve any problems related to WPML and that you have other tickets opened, one for each specific issue that must be treated independently.
I have added the CSS to set the language switcher style you described. However, I also added the language switcher to the main menu so you can see how it works. Perhaps this is what you are looking for, and it works for all screen sizes, including mobile.
1.- If you don't like the language switcher in the menu, you can remove it in WPML -> Languages -> Menu language switcher -> Click on the (X) icon below the Actions column.
2.- If you like the language switcher in the menu and want to remove the first one added with the shortcode, then edit the header in hidden link -> Remove the language switcher added with the shortcode -> Save the changes and update the translations.
My recommendation is to remove the shortcode in the header as described in step number two.
Second, please adjust the menu to the center. Because of your work, the menu is positioned too far to the left. Don't you see that? Do you need glasses or assistance from our team?
If you're going to make changes, please do them properly. If you don't know how to do them properly, then don't do anything!
There's also no language icon in the mobile header!
The problem is that your widgets are taking up too much space. The widgets shouldn't be so wide when there's no text; otherwise, the menu gets pushed to the left, and that looks awful and unprofessional.
We fixed the header issue ourselves in the desktop version. Otherwise, we'd still be working on this ticket next year!
The remaining problem is that the mobile header doesn't have a language switcher. We've tried, but we can't get it to work.
You implemented the language switcher in the menu, but that doesn't work.
Since we have to disable the redirect in WPML due to Google indexing, because the module supposedly causes problems with indexing, the language switcher needs to be immediately visible to the user in the header.
I’ve reviewed the theme, but I wasn’t able to identify where the mobile header (outside of the Elementor template) is being managed — specifically the area where you’d like to add the language switcher.
To move forward, I recommend contacting the theme’s support team and asking them how to edit the mobile header layout, particularly the section that displays the hamburger menu icon. Once you have that information, I’ll be happy to assist you in integrating the language switcher accordingly.
Thank you. We've also been searching. We're writing to the theme author. Unfortunately, it's rather dumb and does absolutely nothing. We've already filed a complaint with Envato.
Can you tell us how to set the font size to 21px and adjust the hover color to match the theme colors, like the menu here? Currently, the hover color is white without a border, which doesn't match the rest of the design.
