The client was experiencing a persistent registration issue with WPML on their website, displaying the error 'Unable to register: Site key not matching'. The site was trying to connect using an old URL, and the client was unable to enter a new key or unregister the old one.
We resolved the issue by manually unregistering and re-registering the site with the correct site key. Here are the steps we followed:
1. Accessed the plugins commercial section at domain-example.com/wp-admin/plugin-install.php?tab=commercial
2. Unregistered the site as it was registered with another site key.
3. Re-registered the site with the correct site key provided by the client.
4. Updated WPML to its latest version, 4.8.6.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum.
Last updated by peterS-172 4 months, 2 weeks ago.
Assisted by: Itamar.
December 10, 2025 at 1:39 pm #17652454
December 10, 2025 at 1:54 pm #17652502
Itamar
WPML Supporter since 02/2016
Languages: Hebrew (עברית )
This ticket has been inactive for quite a while. I didn't get a reply from you. So, I've transformed this chat into a support ticket because you may still need our help.
Can you please share the site key you are using to register for hidden link?
Also, please share a screenshot of the error youare seeing.
Privacy and Security Policy
**IMPORTANT**
Itamar.
December 10, 2025 at 2:48 pm #17652747
peterS-172
thanks the site key is: 9b1dfd6c25
December 11, 2025 at 9:08 am #17654844
peterS-172
Hi, sorry i forget the admin credentials, i have activated e temporary access, is this ok for you? Here is the access link: hidden link
December 11, 2025 at 9:50 am #17655008
Itamar
Hi, and thanks for the access details and for sharing the site key.
I was able to register your site with this site key: 9b1dfd6c25
Here is what I did.
1. I went to the plugins commercial section here: hidden link
2. I unregistered your site as it was registered with another site key. Please see the attached screenshot unregister.jpg.
3. I then reregistered with the correct site key.
4. Then I could update WPML to its latest version 4.8.6. Please see the attached screenshot register-ok.jpg.
Can you please confirm that the issue is now fixed?
Itamar.
December 12, 2025 at 10:37 am #17658694
peterS-172
Thank you!
