Supporter timezone: Africa/Cairo (GMT+02:00)
Last updated by Mohamed Sayed 1 year, 9 months ago.
Assisted by: Mohamed Sayed.
September 19, 2023 at 8:54 am #14417469
thomasS-239
I am trying to:
The footer is displayed correctly in German. Unfortunately not in the translation. Only the "Search" field is translated, the rest is not
I expected to see:
Instead, I got:
September 19, 2023 at 3:01 pm #14420719
Mohamed Sayed
Hi Thomas,
Please go into WPML > String Translation and use the search field to look for the strings then add the translation.
kindly check here for more details: https://wpml.org/documentation/getting-started-guide/translating-widgets/#translating-widgets-using-string-translation
Let me know please if that helps.
Kind regards,
Mohamed
September 20, 2023 at 8:03 am #14427241
thomasS-239
the default language of the website is German. Why
Is English the default in the string translation?
The footer is output in German in the frontend.
September 20, 2023 at 8:04 am #14427273
thomasS-239
Why isn't the footer translated automatically?
September 20, 2023 at 11:17 am #14429673
Mohamed Sayed
When the original strings are added in a language other than English, you might see incorrect source language on String Translation.
You can fix this easily by changing the source language of the strings. Please follow this guide: https://wpml.org/documentation/getting-started-guide/string-translation/how-to-change-the-source-language-of-strings/
Regarding the other question about translating the footer automatically, it's expected that the footer strings won't be translated automatically if you're using the "Translate Everything Automatically" mode.
This mode translates the following types of content:
- Posts
- Pages
- Taxonomy terms assigned to any posts or pages
- WooCommerce Products
- Some content from popular plugins
But it doesn’t pick up strings, so the footer widgets won't be translated automatically.
If you use the "Translate Everything Automatically" mode, you can send them for automatic translation as described here: https://wpml.org/documentation/automatic-translation/automatically-translate-strings-with-wpml/#translate-everything-automatically
In case you're using "Translate What You Choose" mode, you can follow the steps mentioned here: https://wpml.org/documentation/automatic-translation/automatically-translate-strings-with-wpml/#translating-strings-automatically-by-yourself
Kind regards.
The topic ‘[Closed] Problems with the footer’ is closed to new replies.
