You are using the WPML plugin with the Avada Theme on your website. After installation, some components became unconfigured. Specifically, the background color of the footer does not appear in the original version of the site, despite being set in the settings, and the sidebar styles have disappeared.
We recommend checking if you have duplicated the Avada theme options across all languages as described here.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Marcel 2 months, 1 week ago.
Assisted by: Marcel.
May 14, 2025 at 6:46 pm #17034065
jorge-humbertoP
I am trying to use the WPML plugin on my website, which uses the Avada Theme. After installing the plugin, some components of the site became unconfigured. The issue can be seen at hidden link.
The background color of the footer does not appear in the original version of the site, despite being set in the settings. However, it works in the translated version. Additionally, the sidebar styles have disappeared completely.
How can I fix the background color issue in the original version of the site?
What steps should I take to restore the sidebar styles?
May 15, 2025 at 4:28 pm #17038057
Marcel
Hallo,
haben Sie die Avada Optionen wie hier beschrieben in alle Sprachen dupliziert?
Viele Grüße
Marcel
