The client was experiencing issues with Yoast Breadcrumbs not displaying the '/blog' path in the breadcrumbs on the Hestia Pro theme, even after disabling all plugins and resaving Yoast and Reading settings.
We checked the blog page and noticed it was missing a title. We added a title to the blog page. We then asked the client to verify if the 'blog' string appeared correctly in the breadcrumbs.
If you're experiencing a similar issue with Yoast Breadcrumbs not showing the correct path, we recommend you:
1. Ensure that your blog page has a title set.
2. Check the breadcrumbs after adding the title to confirm if the issue is resolved.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the problem persists, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
This topic contains 20 replies, has 3 voices.
Last updated by Osama Mersal 1 year, 10 months ago.
Assisted by: Osama Mersal.
February 6, 2024 at 10:20 am #15270507
nickF-8
I also have an update for our older ticket "Problems with Yoast Breadcrumbs on Hestia Pro theme by Themeisle". I did the tests for that problem at the same time when I disabled all the plugins, and yet, even after I disabled all plugins and resaved the Yoast and Reading settings, the /blog was still not showing in the Breadcrumbs.
I was told to open a new ticket for this as the old one is expired.
February 7, 2024 at 11:03 am #15276143
Carlos Rojas
WPML Supporter since 03/2017
My name is Carlos and I will continue working on this ticket.
I have checked your previous ticket, specifically these two links you shared:
- hidden link
- hidden link
In both cases, the breadcrumbs and the category appear correctly.
If I'm missing something, I kindly ask you to share a new screenshot and URL where the issue can be seen 🙂
Carlos
February 7, 2024 at 6:06 pm #15278464
nickF-8
Hi Carlos, the problem is that the slug /blog should also appear in the breadcrumbs before the blog category, but it doesnt.
February 8, 2024 at 9:01 am #15280193
Carlos Rojas
I understand, however I can't see the Blog slug in the original language: hidden link
Could you provide a URL where the slug Blog appears in the breadcrumbs in the original language?
February 8, 2024 at 2:26 pm #15281738
nickF-8
In the original ticket your colleague made a demo environment that showed it
February 8, 2024 at 5:03 pm #15282496
Carlos Rojas
But the problem is happening or not happening on the site hidden link ?
If the issue is happening, then I need you to share a URL where the issue can be seen.
February 11, 2024 at 11:09 am #15289390
nickF-8
Usually the breadcrumbs should show /blog in the path, but that is not happening at all on my site hidden link. We have identified some kind of conflict due to WPML plugin. It might be best if you include Osama in this conversation as he hopefully will remember the details we discussed in our previous ticket on this topic (Problems with Yoast Breadcrumbs on Hestia Pro theme by Themeisle)
February 12, 2024 at 11:51 am #15292922
Carlos Rojas
While I contact Osama, I would like to ask you to share the access credentials to your site in your next that I've set private. That way we can take a deeper look at the site and its configuration.
February 13, 2024 at 12:00 pm #15297298
nickF-8
Can we first talk to Osama, Im not a big fan of sharing login info so fast and for so long..
February 13, 2024 at 12:05 pm #15297310
Osama Mersal
WPML Supporter since 02/2020
Hi again!
I hope you are doing well. I'll continue this ticket with you.
1) I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
February 14, 2024 at 4:09 pm #15303523
nickF-8
Hi Osama,
You had asked me to test by turning off all the plugins and see if that fixed the problem, but I did that in a staging site and it didnt change anything, so it is not a plugin conflict. Any other ideas for now without needing access?
February 15, 2024 at 7:14 am #15305107
Osama Mersal
If the issue persists in the minimal test, I'd need to access your staging site to check the issue.
In our previous ticket, the issue didn't happen on the sandbox site, which is related to your site's settings.
Osama
February 15, 2024 at 6:26 pm #15308947
nickF-8
Ok I will have you access to the staging site on Monday ok? Now anyways its almost Friday and then the weekend, so lets pick this up on Monday?
February 16, 2024 at 8:27 am #15310392
Osama Mersal
Sure, please take your time. I'll enable the private reply so you can share the access details on Monday.
Osama
February 18, 2024 at 7:30 pm #15315512
nickF-8
Please enable private message so I can put the info
