Last updated by Prosenjit Barman 1 year, 10 months ago.
August 28, 2023 at 3:32 pm #14302113
jaapd-2
If you go to hidden link and click any product the url of the product is incorrect. In the url the product base is /yogakleding but in EN it is /yogawear. The same thing is happening in DE.
Already tried saving permalinks but didn't solve the issue.
How can I solve this?
Cheers,
Jaap
August 29, 2023 at 8:13 am #14304963
Prosenjit Barman
WPML Supporter since 03/2023
Hello Jaap,
I understand the issue you're having. Please follow the steps mentioned below and make sure that the Product permalink base is configured correctly.
- Please go to "WooCommerce > WooCommerce Multilingual > Store URLs"
- Find the "product base" and make sure that the English and German base is added correctly. The base URL that you're adding must have to be unique as WordPress doesn't support identical slugs.
- Go to "Settings > Permalink" and resave the permalink structure.
Please check this documentation for more Information: https://wpml.org/documentation/related-projects/woocommerce-multilingual/#urls
Let me know if that helps or if you need further assistance. I will be happy to help.
Best Regards,
Prosenjit
August 29, 2023 at 10:21 am #14305975
jaapd-2
I tried all the steps you mentioned however the problem still persists. When switching to the english language and then clicking yoga wear in the menu will bring up the correct URL. Click any product and the url reverst back to /yogakleding/. When you click an alternative product within a product (see image 3) then the internal link brings a 404 (image 4) as the URL doenst match.
Please let me know how to proceed or if you want to check yourself.
August 30, 2023 at 4:07 am #14309811
Prosenjit Barman
Hi Jaap,
Thanks for trying out the suggestions.
As the issue persists, I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to have a testing site where the issue is replicated.
IMPORTANT
-Please make a backup of site files and database before providing us access.
Best Regards,
Prosenjit
August 30, 2023 at 3:14 pm #14314803
jaapd-2
Hi, can this be looked into with some urgency? The live webshop is now generating a lot of 404's which is bad very bad for SEO.
August 31, 2023 at 7:01 am #14317525
Prosenjit Barman
Hello Jaap,
Sorry for the delay.
I have checked and am happy to inform you that the issue is resolved now. Please check this video for a better understanding: hidden link
I cleared the Object caches from your site and added the English base URL again. After that, resaved the permalink structure and that solved the issue.
Please check and let me know if there is anything else you need help with. I will be happy to assist.
Best Regards,
Prosenjit
August 31, 2023 at 7:42 am #14317805
jaapd-2
Hi Prosenjit,
Can you do the same for live (same pw)? I've tried clearing object cache and removed product base translations and re-added them, saved permalinks. Didn't solve the issue.
Can you tell me the exact steps?
Cheers,
Jaap
September 1, 2023 at 3:37 am #14324059
Prosenjit Barman
Hello Jaap,
I checked your site and can see that the Product Base URL is showing correctly in the English language. Please check this screenshot[ hidden link ] for a better understanding.
Could you please check by clearing the caches from your site and browser as well? If possible, try from a different browser. Rest assured, the Base URL is showing properly now on the main site.
Let me know if you need any further assistance in this matter. I will be happy to help.
Best Regards,
Prosenjit
September 1, 2023 at 7:42 am #14324895
jaapd-2
Hi Prosenjit. Seems to be ok now. Probably cache... Thanks!
