The client was experiencing issues with the WooCommerce Product Bundles plugin where bundled products were not being synchronized in translations.
We recommended checking if the issue aligns with a known problem detailed on our errata page: https://wpml.org/errata/woocommerce-product-bundles-bundled-products-not-synced-in-translations/.
Following this, we advised the client to:
1. Navigate to Dashboard > Products.
2. Open the edit screen of the original product and make a minor change (e.g., adding an extra space).
3. Save the changes, which should prompt an update icon beside the translation links indicating that an update is required.
4. Re-edit the translation to ensure it is 100% translated and save again.
If this solution does not resolve the issue or seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum.
Last updated by willJ-2 2 months ago.
March 3, 2026 at 5:52 pm #17869755
willJ-2
Having some issues with Product Bundles for WooCommerce, seems to work nicely on the original UK version but none of the bundle selection options show on the Dutch (NL) version?
Looking at the back end of the shop, specifically at the 'Bone Broth Twin Pack' I can see the bundle products for UK version listed but not for the NL version?
Ive also tried adding the dutch products to the Bundle Products but once you publish the product them they then don't save?
Am I missing something?
March 4, 2026 at 7:38 am #17870732
Christopher Amirian
WPML Supporter since 07/2020
Welcome to WPML support. Am I correct to assume that you are talking about this plugin?
https://woocommerce.com/products/product-bundles/
May I ask you to provide the debug information so I can have a better idea of how the website is set up?
https://wpml.org/faq/provide-debug-information-faster-support
Also, I'd appreciate it if you could share the link to Bone Broth Twin Pack.
Finally, if we are talking about the bundle product plugin there is a known issue that I'd appreciate it if you could follow the steps there:
After that, please refresh the products:
- Go to your Dashboard > Products.
- Open the edit screen of the original page. You should see a pencil/circle/gear icon in the sidebar options under the "Languages" section.
- Make a small change, for example, add an extra blank space at the end of a sentence/paragraph.
- Save it.
- You should now see that a circular arrow appears beside the 2nd languages links, this means that an update is required.
- Edit the translation again and save it up to 100% translated.
March 4, 2026 at 1:43 pm #17872115
willJ-2
Great thank you the additional code seems to have resolved the issue.
Thanks again
