This topic contains 28 replies, has 2 voices.
Last updated by Itamar 1 year, 5 months ago.
Assisted by: Itamar.
September 25, 2023 at 9:05 am | |
thomasV-73 |
I startes suffering the following problem after completing the WPML reset proces: "I am now suffering a new problem, namely, images are missing, If you go to the home page of my site hidden link and you scroll down to the "populaire producten" section, the first product "Hondenharnas met gepersonaliseerde tekst" shows no image. Then when you go to the product, some more images in the product gallery are missing. See the images I added, it will show the problem. It is not just happening on this product, but on many other products as well. This gives off a very unprofessional look to my website |
September 25, 2023 at 9:36 am | |
September 25, 2023 at 12:31 pm #14458307 | |
thomasV-73 |
The regeneration of thumbnails you proposed didn't do anything at all... |
September 27, 2023 at 7:45 am #14470981 | |
Itamar Supporter
Languages: English (English ) Hebrew (עברית ) Timezone: Asia/Jerusalem (GMT+03:00) |
Hi, I'll continue to help you with this issue. I read the chat you had with Noman, my colleague. Thanks for following his advice and regenerating the images. Do you have a backup of your site before you reset WPML and when the missing images were still showing? Also, could you please share your site's Debug information with me? You can read about it here. http://wpml.org/faq/provide-debug-information-faster-support/ Regards, |
September 27, 2023 at 9:35 am #14472281 | |
thomasV-73 |
Yes, I have a backup from before I did reset when the images were still showing. As for the debug information, does this mean I need to reactivate WPML? |
September 27, 2023 at 9:53 am #14472571 | |
Itamar Supporter
Hi, I'm sorry it was my mistake to ask you to share the debug information, as obviously, you cannot get it because WPML is no longer active on your site. I'll access your site now to check if I can better understand the cause of the problem. I'll keep you updated here. |
September 27, 2023 at 10:05 am #14472625 | |
Itamar Supporter
Hi, Earlier today when I checked your site, I could see the problem you described with the "Hondenharnas met gepersonaliseerde tekst" product. The image was missing under the "Populaire producten" section. But when I check it now, it shows, and I cannot see the problem—also, all the images of the product show when I check the product page. Please see the attached screenshots. Maybe the regeneration of the thumbnails helped this time. Or maybe you already fixed the problem. Can you please confirm that it is fixed now? If it is not fixed please let me know where I can see other products with missing images. |
September 27, 2023 at 11:14 am #14473231 | |
thomasV-73 |
It is NOT fixed. I redownloaded the missing images for that product and reuploaded them manually to that product. I did that because that is my nr. 1 bestselling product. There are still many products where this problem is occuring. If you go the the following pages you will see more products which are dealing with this issue (there are more products with this issue that I know of): hidden link Also, the problem on some products might not be on the cover image, but on different images in the product gallery, or maybe even on the product variant images, so just scrolling through all the pages of my shop might not show all the affected images, the only way to find out all the affected images is by going through all of my products and checking for the variant images as well (which is a huge task since I have over 400 products) |
September 27, 2023 at 1:03 pm #14474347 | |
Itamar Supporter
Hi, and thanks for sending me links with more products that have this problem. To investigate this issue further, I will need the backup of your site before you reset WPML and when the products have all the images. You can upload it to a service like Google Drive or Dropbox and share the link with us. For this, I'm enabling a private message for the next reply. What will we check? |
October 3, 2023 at 8:24 am | |
October 3, 2023 at 6:01 pm #14508127 | |
Itamar Supporter
Hi, and thanks for the file. I downloaded and saved it. Please let me know once I can continue. |
October 4, 2023 at 9:32 am #14511369 | |
thomasV-73 |
Hello, 2 things: 1: Can you please verify if the download was 3.3GB? (because my Dropbox account only had 2GB of space so I maybe they cut the file short or something) 2. Can you plese make my next reply private so I can send you the download link for the database? |
October 6, 2023 at 7:08 am #14524533 | |
Itamar Supporter
Hi, 1. The size of the downloaded file is 3.3GB. Please see the attached screenshot. 2. I enabled a private message to the following reply. |
October 6, 2023 at 7:58 am | |
October 8, 2023 at 12:37 pm #14534511 | |
Itamar Supporter
Hi, and thanks for sharing the DB with us. The package of your site was huge, and I could not install it on my local server. After installation, I received the ERR_CONNECTION_REFUSED error. I'm consulting our second-tier supporters about this case and how we can help you further. I'll update you once I have news from our second-tier supporters. |
