This topic contains 28 replies, has 2 voices.
Last updated by Itamar 1 year, 10 months ago.
Assisted by: Itamar.
October 8, 2023 at 3:47 pm #14535063 | |
thomasV-73 |
Okay, thanks. Just for clarification, the proces you are running will not cause performance issues on my site? |
October 8, 2023 at 4:25 pm #14535111 | |
No, it will not. We used the copy of your site that you sent us to install it on a local server. We are not logged in or doing anything on your server. |
October 9, 2023 at 7:49 am #14536621 | |
Hi, Our second-tier supporter states that if you were using different images per language, it may not work. That means that if you were using our Media translation add-on to switch images on the translated products, after the reset, it is impossible to recover those images, and you will need to update the products and manually upload the missing images. Also, what you did after the reset with the products in other languages is unclear. |
October 9, 2023 at 8:30 am #14536989 | |
thomasV-73 |
"Our second-tier supporter states that if you were using different images per language, it may not work. That means that if you were using our Media translation add-on to switch images on the translated products, after the reset, it is impossible to recover those images, and you will need to update the products and manually upload the missing images." -Yes, I was using the media translation a lot because I had a lot of images with text in them. But a lot of the images that went missing weren't translated (wasn't necessary because there was no text in them) "Also, what you did after the reset with the products in other languages is unclear. -I didn't do anything after the reset. But I went to check my media library (I went through the entire library) and couldn't find back the translated images. Maybe the reset deleted them by default? Can you please verify if this is how it should be, and if there's not maybe some type of folder with the translated images left in my Cpanel? |
October 10, 2023 at 2:25 pm #14551301 | |
Hi, You asked:
I conducted a test on my WPML and WooCommerce test site. I used Media Translation to switch/translate a product image for one of the products. Then I reset WPML and checked the Media Library. The translated image is still there after the reset. It is also available in the /wp-content/uploads/ folder (the WordPress media folder). |
October 10, 2023 at 4:04 pm #14552287 | |
thomasV-73 |
"I conducted a test on my WPML and WooCommerce test site. I used Media Translation to switch/translate a product image for one of the products. Then I reset WPML and checked the Media Library. The translated image is still there after the reset. It is also available in the /wp-content/uploads/ folder (the WordPress media folder)." -Okay but I did the reset, and after that also deactivated all the WPML related plugins, and even deleted them. Does the deactivation and deleting of these plugins delete all the translated images maybe? I'm asking because I want to make sure these translated images don't take up storage space on my site. |
October 10, 2023 at 4:15 pm #14552389 | |
Hi, You asked: "Does the deactivation and deleting of these plugins delete all the translated images maybe?" No. You also added: "I'm asking because I want to make sure these translated images don't take up storage space on my site." If you don't see them in the media library, in the /wp-content/uploads/ folder, or in any other place in your WordPress installation they don't take up any space. |
October 11, 2023 at 8:26 am #14556461 | |
thomasV-73 |
I didn't see them in the in the media library, but in the /wp-content/uploads/ it's hard to check because of how many images there are, and it doesn't show what the actual image looks like. Is there any faster way to check? Or does the fact that they weren't in my media library already mean that they also aren't in the /wp-content/uploads/ ? |
October 11, 2023 at 9:25 am #14557585 | |
As far as I know, if they are in the /wp-content/uploads/ folder, they should be in the media library. But you may have configurations that I'm unaware of. I don't know how you are checking the /uploads/ folder. If you have there an option to search, you can search for a specific media file name. |
October 18, 2023 at 8:10 am #14599803 | |
thomasV-73 |
Okay thanks, I think the translated images must be deleted then. But that still doesn't fix the original issue of this thread. |
October 18, 2023 at 3:00 pm #14606147 | |
Hi, In this ticket, we deal with the issue "Missing product images after a WPML reset". |
October 18, 2023 at 3:43 pm #14606711 | |
thomasV-73 |
That the images of many products were missing in the PRIMARY LANGUAGE. |
October 19, 2023 at 2:42 pm #14616327 | |
Hi, I've made another attempt to install a copy of your site on my local server, but it failed. I consulted our second-tier supporter again. We need to see the missing images on a URL to see if images are completely removed, URLs are wrong, etc. Do you still have products on your site with missing images because of the WPML reset? |
October 19, 2023 at 3:39 pm #14617499 | |
thomasV-73 |
No, I reuploaded them all manually. |
October 22, 2023 at 9:32 am #14630461 | |
Hi, Here is the response from our second-tier supporter.
As I mentioned several times, I tried to install a copy of your site on my local server and failed. The package you sent us is huge. I can escalate this issue to our second-tier supporters, and they may have better luck and tolls than me and may be able to install your site and continue to debug this issue. At this point, all the indications lead to WPML not being the cause of this problem. We also don't have any similar reports from other users. We are willing to make another effort to validate this. However, since you said that you already corrected this problem on your site by manually uploading the missing product images, I want to ask you if you think there is a point we'll continue investigating this issue? I'm waiting for your reply. Regards, |
