 Marcel
Languages:
English (English )
Spanish (Español )
German (Deutsch )
Timezone:
Europe/Vienna (GMT+02:00)
With the help of our sysadmins, we checked the logs and also enabled the WordPress error log and identified the cause of the crash. Woodmart alone, even without WPML, is using over 152MB—exceeding the available memory. For now, we’ve increased the memory limits to make the system accessible.
You can now try reproducing the issue on the Sandbox by creating an identical example product, which is fully configured with WPML and WCML in Ukrainian.
Marcel
 Юрій Воробйов
Hi Marcel,
Good news — I created a product with 48 variations and custom WoodMart layout in the sandbox, and it works. The product page renders correctly.
So the issue doesn't reproduce in the sandbox, but it persists on my production site.
We need to identify what's different between the sandbox and my site. The only difference I notice so far is that I'm using Elementor Pro on my site, while the sandbox has the free version.
Could this be related? Or are there other configuration differences we should investigate?
Please advise on next steps to pinpoint the cause.
 Marcel
Languages:
English (English )
Spanish (Español )
German (Deutsch )
Timezone:
thanks! I tested this at the beginning as well.
It also works with Elementor disabled; however, for testing purposes I kept the free version of Elementor active.
The config on "Settings" shoudl not make a big difference here, except if you changed any custom field pre-default configs.
The settings configuration should not make a significant difference here, unless you’ve modified any custom field default values.
At this point, I suggest that I create a Duplicator package so we can debug the issue on a local copy of your site where it is reproducible. If we can’t reliably reproduce the problem, we won’t be able to address it as a compatibility bug.
Does that sound good? If so, I’ll proceed.
Marcel
 Юрій Воробйов
Hi Marcel,
Yes, please proceed.
I've created a Duplicator package using the "Two-Part Install" method because the full archive is significantly larger than 500MB. The package contains only the database backup — you'll need to transfer the website files via FTP using the credentials I provided earlier, and grab the installer from the Duplicator plugin page in wp-admin.
Also, I've set up a staging site from the production site, removed all products from it, and I'm currently in the process of importing them to test there as well.
Let me know if you need anything else.
 Marcel
Languages:
English (English )
Spanish (Español )
German (Deutsch )
Timezone:
I’m unable to access the FTP. I’m receiving the following error:
Response: 530 Login authentication failed
Error: Critical error: Could not connect to server
Could you please check this on your end?
Thank you!
Marcel
 Юрій Воробйов
Host: rs7-fra.serverhostgroup.com
 Bruno Kos
Languages:
English (English )
German (Deutsch )
French (Français )
Timezone:
Europe/Zagreb (GMT+02:00)
Could you please try the following change on your site and let us know the result?
In this file:
`sitepress-multilingual-cms/addons/wpml-page-builders/classes/Integrations/Elementor/class-wpml-elementor-adjust-global-widget-id.php`
Please update the function `duplicate_css_class_with_original_id` (around line 132) so it looks exactly like this:
public function duplicate_css_class_with_original_id( $content ) {
$classPrefixes = implode( '|', [ 'elementor-', 'elementor-global-' ] );
$pattern = '/(class="[^"]*?((?:' . $classPrefixes . ')))(\d+)/';
$result = preg_replace_callback( $pattern, [ $this, 'convert_id_to_original' ], $content );
if ( null === $result ) {
return $content;
return $result;
After making the change, please clear any caches and check whether the issue is resolved.
For context, the underlying issue is related to templates failing to display when the PHP setting `pcre.backtrack_limit` is exhausted.
A permanent fix is planned and may be included in WPML 4.9.
Please let me know about the results in your site!
 Юрій Воробйов
Hi Bruno,
Thank you for providing the fix! I have successfully applied the suggested solution on my development site.
What was done:
Edited the file /wp-content/plugins/sitepress-multilingual-cms/addons/wpml-page-builders/classes/Integrations/Elementor/class-wpml-elementor-adjust-global-widget-id.php
Replaced the duplicate_css_class_with_original_id function with the optimized version from your code
Saved the changes and tested the site
Result:
Pages now load correctly, and Elementor templates display properly. The regex backtrack limit issue is resolved.
Looking forward to the official WPML 4.9 release with this fix included.
Thank you for the quick and effective support!
