Supporter timezone: America/Sao_Paulo (GMT-03:00)
Last updated by Mateus Getulio 1 year, 10 months ago.
Assisted by: Mateus Getulio.
July 6, 2024 at 4:55 am #15901829
raymondC-5
My site has product reviews. I want to enable reviews to show under all of my languages without translating each review manually. I want them to show exactly the same as they appear under the parent language. Under WPML settings>post type> wcml-review, I cannot find this wcml-review. I am currently using a plugin 'Multilingual Comments' which does the job but I want to remove this plugin because it is causing some issues with my shop.
Cannot find wcml-review under WPML settings>post type.
How do I enable reviews to show under all of my languages without translating each review manually?
How can I choose to 'Copy' all product reviews into all languages instead of making them 'Translate'?
Is there a way to achieve this without using the 'Multilingual Comments' plugin?
July 6, 2024 at 10:12 pm #15904535
Mateus Getulio
Hello Raymond,
Thank you for contacting us.
Are you using the WooCommerce default feature for product reviews or a third party solution?
Can you please follow this tutorial?
https://wpml.org/documentation/related-projects/woocommerce-multilingual/translating-and-displaying-product-reviews/
In summary the reviews only show up in the languages they were added, if you want to show them in other languages you can enable the option 'show product reviews in all languages by default' in WooCommerce → WooCommerce Multilingual → Settings → Product reviews.
After that, if you need to translate the reviews in the future, you could od it going to WPML -> String Translation and searching for the reviews.
Thank you, please let us know.
Mateus
July 7, 2024 at 2:29 pm #15907557
raymondC-5
Is it possible to just duplicate these reviews into other languages since I am not going to translate them anyways. The reason for doing this is because I am using a plugin called notificationx to show popup of recent reviews. Right now, when a user click on the recent review popup, it will always redirect to the parent product page. I want the user to stay on the same translated product pages.
July 8, 2024 at 11:49 am #15912805
Mateus Getulio
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
July 11, 2024 at 12:18 pm #15934925
Mateus Getulio
Hello there,
I was able to show the product reviews in all languages by following the steps:
- Go to WooCommerce → WooCommerce Multilingual → Settings → Product reviews
- Enable the option 'show product reviews in all languages by default'
If you want to, though it is optional, you can also translate the reviews in WPML -> String Translation.
Please check the demo video:
Thank you,
Mateus
July 12, 2024 at 4:23 am #15939420
raymondC-5
Thank you for writing back.
but why is the number of reviews not correct?
It is showing only 5 review count under the first screenshot and 17 review count at the review tab? The actual review count is 17.
Please check the two screenshots.
Here's a sample product page:
July 12, 2024 at 8:12 pm #15944407
Mateus Getulio
I checked it and it looks like the issue is happening even in the main language.
I temporarily disabled WPML in the staging site and I'm still able to see the different count for the reviews with WPML and the other WPML addons disabled.
Both tests suggest that the issue is not related to WPML.
Have you tried to reach out to the plugin support to see if they can help? If for example, the count is correct in the main language but it is wrong in the translation, then we can review to see if this is something we can fix, but with the issue happening to the main language and even without WPML, it is possible that the issue is in a different location.
The topic ‘[Closed] Product Review Translation’ is closed to new replies.
