The client is experiencing an issue with missing information in the product view, which seems to be related to a translation problem. The error message indicates an 'Invalid taxonomy' when trying to retrieve terms using custom code.
We have identified that the issue is with custom code attempting to access a taxonomy with an incorrect slug. The correct code should use the taxonomy slug 'gebinde_de' instead of 'gebinde'. Here are the steps to correct the issue:
$the_id = get_the_ID();<br />$categories = get_the_terms( $the_id, 'gebinde_de', array( 'order' => 'DESC') );
We recommend updating the custom code in the file
/wp-content/themes/rttheme19/product-contents/single-products-content.php
on lines 322-323 with the correct taxonomy slug. If the client's developer is unable to resolve the issue, we suggest contacting one of our certified partners for further assistance.
If this solution doesn't look relevant, please open a new support ticket.
Last updated by Long Nguyen 1 year, 7 months ago.
Assisted by: Long Nguyen.
November 27, 2023 at 1:09 pm #14930363
thomasS-239
I had already opened a ticket about this problem, but it was closed again because I was ill for a long time.
We have a big problem with the product view. Very important information is missing there. The fact that these are missing must have something to do with the translation.
The product view programmer sent us the following error message:
The Gebinge graphics etc are output if the "terms":
$categories = get_the_terms( $the_id, 'bin', array( 'order' => 'DESC') );
$terms = $categories;
are not empty and do not produce an error. But this is what they do:
object(WP_Error)#32324 (3) { ["errors"]=> array(1) { ["invalid_taxonomy"]=> array(1) { [0]=> string(21) "Invalid taxonomy." } } ["error_data"]=> array(0) { } ["additional_data":protected]=> array(0) { } }
Where is the error in the translations and how do we fix it quickly?
Please provide urgent feedback.
Many thanks
Daniela Ruhnau
November 28, 2023 at 5:09 am #14935683
Long Nguyen
WPML Supporter since 02/2022
Hi Thomas,
According to your screenshot, I see the image icons are not displayed on the product page in German language, not a translation product page. So I think it might not related to WPML.
If you deactivate WPML plugin, are image icons displayed properly on your site?
Look forward to your reply.
November 28, 2023 at 8:29 am #14936507
thomasS-239
thank you for the feedback.
Not only are the symbols missing, but the entire block.
If I deactivate WPML the product page no longer opens at all. So it must be related to WPML.
Could it be the string translation?
It is really very important that this block appears again and the error message in question is turned off.
Many thanks
Daniela Ruhnau
November 28, 2023 at 9:48 am #14937219
Long Nguyen
Let me know how to replicate the issue on your site. Then I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. It would be better to have a testing site where the issue is replicated. Your next reply is set to private to share the info.
November 29, 2023 at 3:06 am #14945785
Long Nguyen
After investigating the issue further, I see that it is a custom code, not the standard code of the theme itself. The code is located in the file /wp-content/themes/rttheme19/product-contents/single-products-content.php line 322-323
$categories = get_the_terms( $the_id, 'gebinde', array( 'order' => 'DESC') );
as you can see, the developer is trying to get the term ID of the taxonomy "gebinde" but the slug of this taxonomy is "gebinde_de". You can see it in Pods Admin > Edit Pods. I correct the taxonomy slug in the code and the section displayed as well in the front end. Please check screenshot attached.
I would like to inform you that helping you with custom code further, is out of the scope of WPML, but I helped you a lot, pointing you to the source of the problem you are having.
If your developer is not able to fix the issue, I would recommend you contact one of our certified partners who will be more than happy to help you with this. In this link, you will find a list of our certified partners: https://wpml.org/contractors/
November 29, 2023 at 8:22 am #14946945
thomasS-239
thank you very much, you helped me a lot. This solved the problem. So Many thanks.
Daniela Ruhnau
November 29, 2023 at 10:10 am #14948535
Long Nguyen
Feel free to contact us again if you have any questions.
Thanks and have a good day.
