The client needs a code snippet so that WPML translates only product titles.
We currently do not have a built-in function or a custom snippet specifically for this request. We recommend creating a custom solution. As a starting point, you can refer to this example on how to exclude specific fields from automatic translation: https://wpml.org/forums/topic/do-not-translate-title-with-automatic-translation/. In the example, replace "title" with "product_title" or any other field you wish to exclude, such as "description" or "short_description".
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket at WPML support forum.
Last updated by Marcel 3 weeks, 5 days ago.
Assisted by: Marcel.
March 12, 2026 at 12:05 pm #17892269
Tomas Bagaciunas
please give me code snippet , so wpml would translate only product titles
March 12, 2026 at 12:08 pm #17892277
Tomas Bagaciunas
dont close this ticket
March 13, 2026 at 2:16 pm #17895840
Marcel
We do not currently have a specific built-in function to achieve this nor can't we provie you with a full custom snippet for that.
I recommend creating your own custom solution for your use case. As a starting point, you can try something like this:
In the example, you can replace "title" with any other field you want to exclude, such as "description", "short_description", or other fields as needed.
Marcel
