This topic contains 45 replies, has 2 voices.
Last updated by Kor 1 year ago.
May 6, 2024 at 1:11 pm #15597418
yannay
I am currently running WPML and WooCommerce on a staging site (stage.ranigilat.com) which is under development. I am trying to activate WPML with WooCommerce on this WP staging site and handle the translation of pages myself.
Server times out. Had to manually move WPML to a disabled plugins folder. That allowed the site to reload. Manually moved WPML back to plugins folder, activated it, Reset the plugin in WPML troubleshooting page and deactivated it. This is the third time I went through the process. also went through WPML wizard step by step to setup the plugin from scratch which installed String translation and Woocommerce multilingual. Still when trying to translate pages, server times out. I have PHP 8.3, max_execution_time 30, max input time 120, memory limit 512. There are thousands of images in the media library, is that the reason server times out with WPML enabled? on the live site ranigilat.com WPML is running fine but the live site does not have woocommerce on it.
How do I avoid server timeout while running WPML with my current memory and php server setting which seems to answer minimum requirements?
May 7, 2024 at 2:01 pm #15602615
WPML Supporter since 08/2022
Thank you for reaching out to WPML support.
To expedite the support process, I've enabled a private message option for submitting debug information related to this support ticket. Please follow these initial debugging steps outlined in this link: Debug Information Instructions https://wpml.org/faq/provide-debug-information-faster-support/
In summary:
1. Navigate to "WPML > Support > Debug Information" (link).
2. Copy the Debug Information provided there.
3. Locate the private field I've activated and paste the debug information there.
Additionally, while awaiting further assistance, I recommend contacting your hosting provider to investigate any server error logs. They should be able to identify the issue and determine what might be causing the site to malfunction.
May 14, 2024 at 3:57 pm #15626377
yannay
Pasted debug info. will look into server error logs as well. thank you
May 14, 2024 at 4:07 pm #15626391
Thank you for your response.
I can see that there are only two plugins installed, and your server resources appear to be adequate. Please share the feedback from your hosting provider once you receive it.
May 14, 2024 at 4:09 pm #15626396
yannay
BTW in order to get the debug info WPML needs to be active. as said, the server times out when both Woocommerce & WPML are running but I did manage to activate WPML while woocommerce was running in order to get to debug info. Currently I left them both active
May 14, 2024 at 4:18 pm #15626461
Thanks for your reply.
Alright then, I'll wait for your hosting provider's feedback.
May 14, 2024 at 4:25 pm #15626484
yannay
2024-05-14 11:52:52.332558 [NOTICE] [1647364] [T0] [45.234.234.54:62977:HTTP2-5#APVH_www.stage.ranigilat.com:443] [STDERR] PHP Warning: Undefined array key "path" in /home/ranigila/domains/ranigilat.com/public_html/stage/wp-includes/l10n.php on line 1196\n
2024-05-14 11:52:52.332596 [NOTICE] [1647364] [T0] [45.234.234.54:62977:HTTP2-5#APVH_www.stage.ranigilat.com:443] [STDERR] PHP Warning: Undefined array key "path" in /home/ranigila/domains/ranigilat.com/public_html/stage/wp-includes/l10n.php on line 1213\n
2024-05-14 11:52:52.332602 [NOTICE] [1647364] [T0] [45.234.234.54:62977:HTTP2-5#APVH_www.stage.ranigilat.com:443] [STDERR] PHP Warning: Undefined array key "path" in /home/ranigila/domains/ranigilat.com/public_html/stage/wp-includes/l10n.php on line 1231\n
2024-05-14 11:52:52.332608 [NOTICE] [1647364] [T0] [45.234.234.54:62977:HTTP2-5#APVH_www.stage.ranigilat.com:443] [STDERR] PHP Warning: Undefined array key "path" in /home/ranigila/domains/ranigilat.com/public_html/stage/wp-includes/l10n.php on line 1196\n
2024-05-14 11:52:52.332614 [NOTICE] [1647364] [T0] [45.234.234.54:62977:HTTP2-5#APVH_www.stage.ranigilat.com:443] [STDERR] PHP Warning: Undefined array key "path" in /home/ranigila/domains/ranigilat.com/public_html/stage/wp-includes/l10n.php on line 1213\n
2024-05-14 11:52:52.332620 [NOTICE] [1647364] [T0] [45.234.234.54:62977:HTTP2-5#APVH_www.stage.ranigilat.com:443] [STDERR] PHP Warning: Undefined array key "path" in /home/ranigila/domains/ranigilat.com/public_html/stage/wp-includes/l10n.php on line 1231\n
2024-05-14 12:00:50.338521 [INFO] [1647364] [T0] [45.234.234.54:49582:HTTP2-1#APVH_www.stage.ranigilat.com:443] Abort request processing by PID:2035749, kill: 0, begin time: 2, sent time: 2, req processed: 0
May 14, 2024 at 4:36 pm #15626521
The error log does not indicate any issues with the mentioned plugins. I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to your Website and server.
May 14, 2024 at 7:43 pm #15626916
Thank you for being patient.
I've configured WPML and finished installing the String Translation and WCML. Everything appears to be working smoothly from my end. Can you confirm? Also, I've updated the Woocommerce plugin since it appeared to be outdated. Please inform me of any observations.
May 15, 2024 at 12:20 am #15627339
yannay
Thank you!
it does seem to work well now with both plugins activated. However, I think I know where the issue of server timeout may be coming from. It just happened again as I was attempting to simply update the Hebrew Homepage with no edits made to it.
In Dashboard > English Pages there are Hebrew pages which WPML thinks are English (there are no Hebrew pages in dashboard > Hebrew pages). What is the proper way to assign the correct language to these pages and then match the English page with its Hebrew translation?
Should I edit a page's English version > assign the existing Hebrew version of the page (which WPML thinks is an English page ATM) as its translation > update the English page?
Or,
Edit the Hebrew page > change its language definition > Update the page. Then edit the English page > match it with the now correctly language defined Hebrew page?
Most importantly, ATM the site is not responding (same issue ) I'll need to get WPML working again in order to start assigning languages and translations to existing pages as described above.
Should I manually move the plugins to a disabled directory on the server, regain dashboard access, manually move the plugins back to the active plugin directory on the server, activate them in dashboard?
I don't want to lose any of the configurations you have made to get the plugins working and I think the action described above might do just that.
Many thanks
May 15, 2024 at 12:48 am #15627385
Yes, you need to correct the language of the page. So, use this method "Edit the Hebrew page > change its language definition > Update the page. If it's still connected to a language, you can disconnect it using this method https://wpml.org/faq/how-to-disconnect-translations-from-the-default-language-page-or-post/
Then edit the English page > match it with the now correctly language defined Hebrew page"
To connect the Hebrew to the correct English language, you can use this method https://wpml.org/faq/how-to-link-already-translated-pages/
May 15, 2024 at 11:09 am #15629788
yannay
Ok I’ll try that
How do I go about reactivating the plug-in?
I don't want to lose any of the configurations And last time I did that I think I lost all the configurations
Thank you very much
May 15, 2024 at 11:28 am #15629870
yannay
Once I get the server to respond again I think it would be impossible for me to make any changes on the Hebrew pages (which are set as English ATM) and update them because that is what causing the server to become nonresponsive. I may need to delete them as opposed to editing them and then create translations from scratch
May 15, 2024 at 12:21 pm #15630334
yannay
How should o go about getting the server to respond again so I can start deleting those pages?
May 15, 2024 at 1:12 pm #15630596
I've checked and I'm able to edit your Hebrew translations without issues as shown in the attached screen recording hidden link . Also, the server is responding fine for me and there is no downtime or nonresponsive. Maybe you can try using another browser?
The topic ‘[Closed] Running WPML & woocommerce on stage.ranigilat.com’ is closed to new replies.
