Supporter timezone: Asia/Jerusalem (GMT+02:00)
Last updated by Itamar 2 months, 2 weeks ago.
Assisted by: Itamar.
November 25, 2025 at 11:48 am
yi-lingL
I am trying to have the same slug for a page in different languages. For example, I want the page to be accessible at both hidden link and hidden link.
When I try to access the translated page with the same slug, I get a 404 error instead of the expected translated page.
Why does using the same slug for translations result in a 404 error?
How can I configure WPML to allow the same slug for different language versions of a page?
November 25, 2025 at 12:50 pm #17608114
Itamar
WPML Supporter since 02/2016
We suspect a collision with the theme or another plugin might cause this problem. If possible, get your site into a minimum environment, switching to a default WordPress theme and activating only WPML.
First, check whether the problem persists when only the theme is switched to the Hello Elementor parent theme. If it persists, deactivate all plugins except WPML and Strings Translation. Then, please check if the problem persists. If it does not continue, start by activating the plugins individually and checking when the issue comes back, then report to me which plugin was the culprit.
Itamar.
The topic ‘[Closed] Same slugs for translation returns 404 error’ is closed to new replies.
