Last updated by Long Nguyen 1 year, 8 months ago.
Assisted by: Long Nguyen.
October 10, 2023 at 10:18 am #14548501
omirosM-2
I'm in the middle of developing a site.
I installed wpml and started to translate from greek to english.
The first problem is that it breaks my home page for some reason.
It doesnt show a section and the other two kinda becomes narrow.
Also the menu is one letter on top of another.
The last thing that is very weird is that in the returns page it show me to translate only couple of sentences even though there is a lot more than that.
I will provide some pictures.
Also i'm using porto theme.
Thank you in advance.
October 11, 2023 at 7:56 am #14556197
Long Nguyen
WPML Supporter since 02/2022
Hi Omiros,
According to your screenshots, I see the translation of the homepage is In Progress and the layout is different from the original page. Please complete the translation > Make a small change to the page content > Save > Update the translation and see if it helps.
Look forward to your reply.
October 12, 2023 at 2:29 am #14562197
Long Nguyen
1. For the homepage layout:
When editing the homepage in Greek and English languages, I see the layout setting is not synced to the translation page, screenshot hidden link
Then I go to WPML > Settings > Custom Fields Translation section > Set two fields "default", "layout" preference to "Copy". And edit the homepage in Greek language > Click on Update. Now you can see the layout is synced to the translation.
2. For the header menu items:
The same, when editing the Custom Header post in Porto > Templates Builder, I see the Container and Custom CSS are not synced to the translation header, screenshot hidden link
Then I set two fields "container", "custom_css" preference to "Copy" > Update the Custom Header post to sync the settings.
Refer documentation https://wpml.org/documentation/getting-started-guide/translating-custom-fields/
October 12, 2023 at 7:12 am #14563025
omirosM-2
Thank you very much for the help and for explaining what you did!
It wont be a problem in the future !
One last thing, in this page :hidden link
There is a lot of text but it shows me to translate only 3 sentenses.
You can see this in the other two pictures i provided that doesnt show the menu or the homepage.
I dont think thats normal .
Thank you in advance!
October 12, 2023 at 7:34 am #14563253
omirosM-2
To add : in the single product the additional information tab dissapeared for some reason .
New threads created by Long Nguyen and linked to this one are listed below:
https://wpml.org/forums/topic/on-the-single-product-page-the-additional-information-tab-dissapeared/
October 12, 2023 at 8:49 am #14564001
Long Nguyen
For the page hidden link, when editing with Classic Editor, I see there are some Gutenberg tags in the content and one of them is not correct. I corrected the tag and now the texts are available in Advanced Translation Editor as well. Please check these screenshots hidden link
We can handle one issue per ticket only so I will split your new issue with the single product page into a new ticket.
If you see the main issue of this ticket with page layout and page content is resolved, please mark it as Resolved.
October 12, 2023 at 8:58 am #14564037
omirosM-2
Thank you very much for your help! Issue is resolved !
