You are trying to generate a sitemap for your website using WPML, but the sitemap_index.xml file is only available in the original language ("pt") and not in the translated languages ("en" and "fr").
If you're experiencing this issue, it's important to note that your site uses different directories per language as the language URL structure. In this scenario, you will have one sitemap that includes all languages. You can only have a separate sitemap per language if your site uses a different domain per language. For example:
www.sitename.com
for English
www.sitename.es
for Spanish
For more details, please refer to our documentation on creating multilingual sitemaps with WPML.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket at our support forum.
Last updated by Elsa Soares 5 months, 1 week ago.
March 26, 2025 at 12:23 pm #16862473
Elsa Soares
I am trying to generate a sitemap for my website hidden link using WPML. The sitemap_index.xml file is only available in the original language _pt and not in the translated languages _en and _fr.
The sitemap_index.xml file does not exist for the _en and _fr languages.
Why is the sitemap_index.xml not generated for the _en and _fr languages?
How can I ensure the sitemap is available for all languages using WPML?
March 26, 2025 at 4:53 pm #16864433
Your site uses different directories per language as language URL structure.
In this case, you will have one sitemap that includes all languages.
You can only have a sitemap per language if your site uses a different domain per language.
Example:
hidden link > English
hidden link > Spanish
Source:
https://wpml.org/documentation/plugins-compatibility/using-wordpress-seo-with-wpml/#create-multilingual-sitemaps
April 2, 2025 at 9:30 am #16886206
Elsa Soares
Thanks for your support. You may close this ticket.
