9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 9:00 – 13:00 - -
14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 14:00 – 18:00 - -
Last updated by Christopher Amirian 2 weeks, 5 days ago.
April 25, 2026 at 9:52 pm #17994862
hugyakA
one part of the footer became chinase and not possible to edit the footer any more
April 25, 2026 at 10:05 pm #17994879
hugyakA
I am waiting for the human support
thank you
April 26, 2026 at 8:21 am #17995114
Christopher Amirian
WPML Supporter since 07/2020
Hello and welcome to WPML support. I tried to check the website front end but unfortunately, it is under maintenance, and I do not have access.
I'd appreciate it if you could give me the URL/User/Pass of your WordPress dashboard after you make sure that you have a backup of your website.
Also I have the questions below:
- Did you use WP Dashboard > Appearance > Widgets to add the footer of your website?
- Or did you use WP Dashboard> Elementor > Editor. If this is the answer, please tell me the name of the Elementor Template you used for the footer.
- Also if you used Elementor, there should be a place in the theme that you selected the Elementor template as the footer. I need that option too.
The topic ‘[Closed] solve problem’ is closed to new replies.
