The client has a custom ACF block called Header Block with multiple fields (title, subtitle, content, button label, etc.), but only the button label is showing, and the other fields are not. The client is following the WPML documentation for translating sites built with ACF but is facing an issue because the field names are not unique across blocks.
We recommend ensuring that all field names are unique. This is a known limitation with ACF and WPML, as WPML handles custom fields by name, which are stored in the meta tables. Therefore, translation preferences are set by field name, necessitating their uniqueness. Here are some resources to help understand the importance of unique field names:
If this solution is not applicable due to it being outdated or not relevant to your case, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket.
This topic contains 10 replies, has 3 voices.
Last updated by Osama Mersal 1 year, 5 months ago.
Assisted by: Osama Mersal.
February 23, 2024 at 1:58 pm #15338139
simpleT
I have a custom ACF block called Header Block that has multiple fields (title, subtitle, Content, Button label etc...)
For some reason only the button label is showing, but none of the other fields, why is that?
trying to follow this https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/
I have a local site but if you want I can also have it live somewhere to give you access.
February 23, 2024 at 5:50 pm #15338911
Lucas Vidal de Andrade
WPML Supporter since 11/2023
Please check in WPML > Settings > Custom Fields Translation if the desired fields are set as translatable.
If that does not help, one of my colleagues will soon come to continue support.
February 23, 2024 at 7:10 pm #15339091
simpleT
Thanks for answering Lucas.
None of the fields I have appear in the "Custom fields Translation" that you mentioned.
I want to point out like in my original post that these are ACF blocks if that makes a difference.
From ACF I only have acfml_non_translatable_locations
But again, like in my screenshot i have fields like btn1_label from the hero-unit block that don't appear here.
February 25, 2024 at 11:08 am #15341300
Osama Mersal
WPML Supporter since 02/2020
I'm Osama from WPML forums support. I'll be glad to help you today.
1) First of all, sorry for the late reply; it was due to a higher workload. Please login to this sandbox site and import your ACF field groups and blocks. (hidden link)
After that, please create a test page using the problematic block and translate it to replicate the issue.
If the issue is replicable, please let me know how to reproduce it.
2) It's unrelated to the issue, but according to your Debug.info, the WP memory limit needs to be increased. PHP memory is fine, but WordPress uses 40Mb as default. The minimum requirements for WPML are 128 MB. (Kindly check this page https://wpml.org/home/minimum-requirements/)
You can increase it by adding the following code in your wp-config.php file right before the /* That's all, stop editing! Happy publishing. */ line:
/* Memory Limit */
define( 'WP_MAX_MEMORY_LIMIT', '256M');
Osama
February 25, 2024 at 8:45 pm #15341968
simpleT
Hi.
I have confirmed that on your test site adding my block fields and adding it via functions.php works with the header-block.php file works.
I activated the glossary + advanced translation and can confirm that also works.
It looks like the problem was the fact that my field names need to be unique across blocks.
This is honestly very bad news as I have multiple blocks that have the field name "content" or "heading". Now it looks like I need to remake my whole site since if I change the field name the data that was added into it will dissapear...
How can I go around this issue?
Even something that can happen after the field was made in functions.php or something like that?
February 25, 2024 at 8:55 pm #15341969
simpleT
Just want to add, I have the same problem as the users here are explaining.
https://wpml.org/forums/topic/acfml-issues-with-fields-with-the-same-name/
February 26, 2024 at 7:19 am #15342367
Osama Mersal
Thanks for your update. I'm afraid that the name should be unique. Please check the following pages.
1- hidden link
2- hidden link
Osama
February 26, 2024 at 8:47 am #15342743
simpleT
This is unfortunate because it works to create them in ACF but for some reasom ACFML plugin can't diferentiate between blocks that use the same field???
Why would anyone create a field "body" and have 2 different blocks work with "body" but because of WPML and ACFML it should be "body_2" for the second one.
This is a huge miss from WPML and ACF.
February 26, 2024 at 8:59 am #15342802
Osama Mersal
I understand your frustration. Please check this guide to see a warning message about this case. (https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/#using-same-fields-across-languages)
This happens because WPML handles custom fields by name, so the translation preferences are set by field name. That's why it should be unique.
Sorry for the inconvenience
Osama
February 26, 2024 at 11:08 am #15343683
simpleT
Just want to make clear its not okay to set a warning as a Note on huge documentation page and expect people to not run into this issue.
As a final question is there anything that can be edited in the ACFML plugin (doesn't matter if an update will break things) as a temporary solution? Maybe for others that have this problem?
Something like using the field_key instead of the field_name?
February 26, 2024 at 12:29 pm #15344159
Osama Mersal
Thanks for your reply. I consulted our ACFML team; unfortunately, that's an ACFML limitation for now.
ACF does use field_keys, but everyone else does not. WPML, for instance, handles names of custom fields as they are stored in meta tables.
Osama
February 26, 2024 at 4:20 pm #15345342
simpleT
Unfortunate that the feature from ACFML does not solve this problem but it is what it is.
