This topic contains 11 replies, has 0 voices.
Last updated by sohailaH 19 hours, 47 minutes ago.
Assisted by: Dražen.
May 15, 2026 at 9:41 am #18038253
sohailaH
welcome, i hvae issues again
the first product i want to translate in products not found in translation dashborard, i send you screens
May 15, 2026 at 9:53 am #18038289
sohailaH
May 15, 2026 at 10:04 am #18038328
Dražen
I checked further, but unfortunately I could not find the cause from a quick review.
To continue troubleshooting properly, I would need a staging site where I can safely disable plugins/themes and run deeper tests without affecting the live website.
If possible, please create a staging copy using the WP Staging plugin and share access with me.
If creating a staging site is not possible, I can instead take a local copy of the website and continue checking there.
Please let me know which option works best for you.
Drazen
May 15, 2026 at 10:13 am #18038407
sohailaH
Hello Drazen,
Thank you for the update. Since creating a staging site might be a bit complicated for me at the moment, I would prefer if you could take a local copy of the website to continue your troubleshooting.
May 15, 2026 at 10:27 am #18038426
sohailaH
"Hello Drazen,
Thanks for following up. Please go ahead and take the local copy of the website. However, I have a small request:
Once you finish downloading the backup file to your computer, please make sure to delete the backup folder/file from the server immediately to save disk space and for security reasons.
Let me know once the local copy is ready and the server is cleared.
Regards,"
May 15, 2026 at 10:58 am #18038563
Dražen
I am currently trying to upload Duplicator PRO to create a local copy of the website, but it seems the upload is not working or is being blocked.
Do you perhaps have some restrictions on the server that could prevent plugin uploads or file creation? If so, those same restrictions could also potentially affect WPML when trying to write or process content from the database.
Also, once I finish downloading the backup locally, I will make sure to remove the backup files from the server immediately, as requested.
Please let me know regarding the plugin upload restrictions, and we can continue from there.
Drazen
May 15, 2026 at 11:24 am #18038671
sohailaH
welcome,
i confirm you that every thing is well in server
are you completed uploading, also can you use updraft plugin it's already installed in plugins as you have admin user
thanks
May 15, 2026 at 11:46 am #18038705
Dražen
I understand, but uploading a new plugin currently does not work. You can also try uploading any other plugin yourself and you should see the same issue.
Because of that, could you please check with your hosting support and make sure plugin uploads are allowed and not being blocked by some server restriction?
I need to use Duplicator PRO for this case. I already tried the free version, but since your website is around 8 GB in size, the backup process gets stuck. With the PRO version I can try to exclude large folders/files and create the package more safely.
At the moment, something seems to be blocking uploads of new plugins, so please let’s first make sure that works correctly, and then I will proceed with creating the backup.
Drazen
May 15, 2026 at 12:12 pm #18038760
sohailaH
"Hello Drazen,
I've checked the server files and noticed a subdomain folder named demo.wahageg.com. If it's easier for you to create a staging site there directly on the server instead of a local copy, please feel free to do so.
Regarding the Duplicator PRO plugin, since the WordPress dashboard is still blocking the upload, please send me the plugin zip file or a download link. I will upload it manually via the File Manager to the plugins folder so you can start working immediately.
Let me know how you prefer to proceed."
May 15, 2026 at 4:18 pm #18039597
sohailaH
hello,
ihope you're well and everything do well, i can't heare from you 3 hours ago
are you fix issue in my site ?
regards
May 15, 2026 at 5:08 pm #18039634
sohailaH
hell, i don't hear from you, is everything done well ???
May 15, 2026 at 5:16 pm #18039635
sohailaH
{"core":{"Wordpress":{"Multisite":"No","SiteURL":"https:\/\/wahageg.com","HomeURL":"https:\/\/wahageg.com","Version":"6.9.4","PermalinkStructure":"\/%postname%\/","PostTypes":"post, page, attachment, revision, nav_menu_item, custom_css, customize_changeset, oembed_cache, user_request, wp_block, wp_template, wp_template_part, wp_global_styles, wp_navigation, wp_font_family, wp_font_face, wpcode, e-floating-buttons, elementor_library, woodmart_layout, woodmart_woo_lv, woodmart_woo_fbt, wd_woo_discounts, wd_popup, wd_floating_block, cms_block, woodmart_size_guide, woodmart_slide, woodmart_sidebar, portfolio, product, product_variation, shop_order, shop_order_refund, shop_coupon, shop_order_placehold, pys_event, wpcf7_contact_form, rm_content_editor, rank_math_schema, elementor_font, elementor_icons","PostStatus":"publish, future, draft, pending, private, trash, auto-draft, inherit, request-pending, request-confirmed, request-failed, request-completed, wc-pending, wc-processing, wc-on-hold, wc-completed, wc-cancelled, wc-refunded, wc-failed, wc-checkout-draft","RestEnabled":"Yes"},"Server":{"jQueryVersion":"3.7.1","PHPVersion":"8.2.31","MySQLVersion":"10.11.16","ServerSoftware":"Apache"},"PHP":{"MemoryLimit":"265M","WP Memory Limit":"2000M","WP Max Memory":"265M","UploadMax":"2048","PostMax":"2048","TimeLimit":"900","MaxInputVars":"10000","MBString":true,"libxml":true,"OPcache":"Enabled","Memory Used":"128 MB","Memory Free":"0 MB","Memory Wasted":"0 MB (0%)","Memory Total":"128 MB","Memory Usage":"100%","Cache Hits":"82,972,323","Cache Misses":"36,811,689","Hit Rate":"69.27%","Cached Scripts":"4,765"}},"plugins":{"active_plugins":{"sitepress-multilingual-cms\/sitepress.php":{"Plugin Slug":"sitepress-multilingual-cms","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"WPML Multilingual CMS","PluginURI":"https:\/\/wpml.org\/","Version":"4.9.3","Author":"OnTheGoSystems","AuthorURI":"http:\/\/www.onthegosystems.com\/","TextDomain":"sitepress-multilingual-cms","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"WPML Multilingual CMS","AuthorName":"OnTheGoSystems"},"chaty\/cht-icons.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Chaty","PluginURI":"","Version":"3.5.6","Author":"Premio","AuthorURI":"https:\/\/premio.io\/downloads\/chaty\/","TextDomain":"chaty","DomainPath":"\/languages","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Chaty","AuthorName":"Premio"},"classic-editor\/classic-editor.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Classic Editor","PluginURI":"https:\/\/wordpress.org\/plugins\/classic-editor\/","Version":"1.6.7","Author":"WordPress Contributors","AuthorURI":"https:\/\/github.com\/WordPress\/classic-editor\/","TextDomain":"classic-editor","DomainPath":"\/languages","Network":false,"RequiresWP":"4.9","RequiresPHP":"5.2.4","UpdateURI":"","RequiresPlugins":"","Title":"Classic Editor","AuthorName":"WordPress Contributors"},"contact-form-7\/wp-contact-form-7.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Contact Form 7","PluginURI":"https:\/\/contactform7.com\/","Version":"6.1.5","Author":"Rock Lobster Inc.","AuthorURI":"https:\/\/github.com\/rocklobster-in\/","TextDomain":"contact-form-7","DomainPath":"","Network":false,"RequiresWP":"6.7","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"Contact Form 7","AuthorName":"Rock Lobster Inc."},"duplicate-page\/duplicatepage.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Duplicate Page","PluginURI":"https:\/\/duplicatepro.com\/","Version":"4.5.9","Author":"mndpsingh287","AuthorURI":"https:\/\/profiles.wordpress.org\/mndpsingh287\/","TextDomain":"duplicate-page","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Duplicate Page","AuthorName":"mndpsingh287"},"elementor-pro\/elementor-pro.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"4.0.4-ga","Elementor Pro tested up to":"","Name":"Elementor Pro","PluginURI":"https:\/\/go.elementor.com\/wp-dash-wp-plugins-author-uri\/","Version":"4.0.4","Author":"Elementor.com","AuthorURI":"https:\/\/go.elementor.com\/wp-dash-wp-plugins-author-uri\/","TextDomain":"elementor-pro","DomainPath":"","Network":false,"RequiresWP":"6.7","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"elementor","Title":"Elementor Pro","AuthorName":"Elementor.com"},"elementor\/elementor.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Elementor","PluginURI":"https:\/\/elementor.com\/?utm_source=wp-plugins\u0026utm_campaign=plugin-uri\u0026utm_medium=wp-dash","Version":"4.0.8","Author":"Elementor.com","AuthorURI":"https:\/\/elementor.com\/?utm_source=wp-plugins\u0026utm_campaign=author-uri\u0026utm_medium=wp-dash","TextDomain":"elementor","DomainPath":"","Network":false,"RequiresWP":"6.6","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"Elementor","AuthorName":"Elementor.com"},"health-check\/health-check.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Health Check \u0026 Troubleshooting","PluginURI":"https:\/\/wordpress.org\/plugins\/health-check\/","Version":"1.7.1","Author":"The WordPress.org community","AuthorURI":"https:\/\/wordpress.org\/plugins\/health-check\/","TextDomain":"health-check","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"5.6","UpdateURI":"","RequiresPlugins":"","Title":"Health Check \u0026 Troubleshooting","AuthorName":"The WordPress.org community"},"insert-headers-and-footers\/ihaf.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"WPCode Lite","PluginURI":"https:\/\/www.wpcode.com\/","Version":"2.3.5","Author":"WPCode","AuthorURI":"https:\/\/www.wpcode.com\/","TextDomain":"insert-headers-and-footers","DomainPath":"\/languages","Network":false,"RequiresWP":"5.0","RequiresPHP":"7.0","UpdateURI":"","RequiresPlugins":"","Title":"WPCode Lite","AuthorName":"WPCode"},"paymob-for-woocommerce\/init-paymob.php":{"Plugin Slug":"","WC requires at least":"4.0","WC tested up to":"10.4","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Paymob for WooCommerce","PluginURI":"","Version":"4.1.2","Author":"Paymob","AuthorURI":"https:\/\/paymob.com","TextDomain":"paymob-woocommerce","DomainPath":"\/i18n\/languages","Network":false,"RequiresWP":"5.0","RequiresPHP":"7.0","UpdateURI":"","RequiresPlugins":"woocommerce","Title":"Paymob for WooCommerce","AuthorName":"Paymob"},"pixelyoursite-pro\/pixelyoursite-pro.php":{"Plugin Slug":"","WC requires at least":"2.6.0","WC tested up to":"10.3","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"PixelYourSite PRO","PluginURI":"http:\/\/www.pixelyoursite.com\/","Version":"12.5.1","Author":"PixelYourSite","AuthorURI":"http:\/\/www.pixelyoursite.com","TextDomain":"pys","DomainPath":"","Network":false,"RequiresWP":"4.4","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"PixelYourSite PRO","AuthorName":"PixelYourSite"},"print-invoices-packing-slip-labels-for-woocommerce\/print-invoices-packing-slip-labels-for-woocommerce.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"10.6.2","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"WebToffee WooCommerce PDF Invoices, Packing Slips, Delivery Notes and Shipping Labels","PluginURI":"https:\/\/www.webtoffee.com\/product\/woocommerce-pdf-invoices-packing-slips\/","Version":"4.9.4","Author":"WebToffee","AuthorURI":"https:\/\/www.webtoffee.com\/","TextDomain":"print-invoices-packing-slip-labels-for-woocommerce","DomainPath":"\/languages","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"woocommerce","Title":"WebToffee WooCommerce PDF Invoices, Packing Slips, Delivery Notes and Shipping Labels","AuthorName":"WebToffee"},"product-catalog-feed-pro\/product-catalog-feed-pro.php":{"Plugin Slug":"","WC requires at least":"3.0.0","WC tested up to":"10.4","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Product Catalog Feed Pro by PixelYourSite","PluginURI":"https:\/\/www.pixelyoursite.com\/product-catalog-facebook","Version":"5.8.2","Author":"PixelYourSite","AuthorURI":"https:\/\/www.pixelyoursite.com","TextDomain":"wpwoof","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"7.0","UpdateURI":"","RequiresPlugins":"woocommerce","Title":"Product Catalog Feed Pro by PixelYourSite","AuthorName":"PixelYourSite"},"redirection\/redirection.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Redirection","PluginURI":"https:\/\/redirection.me\/","Version":"5.7.5","Author":"John Godley","AuthorURI":"","TextDomain":"redirection","DomainPath":"","Network":false,"RequiresWP":"6.5","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"Redirection","AuthorName":"John Godley"},"seo-by-rank-math-pro\/rank-math-pro.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Rank Math SEO PRO","PluginURI":"https:\/\/rankmath.com\/wordpress\/plugin\/seo-suite\/","Version":"3.0.107","Author":"Rank Math SEO","AuthorURI":"https:\/\/rankmath.com\/?utm_source=Plugin\u0026utm_medium=Readme%20Author%20URI\u0026utm_campaign=WP","TextDomain":"rank-math-pro","DomainPath":"\/languages","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Rank Math SEO PRO","AuthorName":"Rank Math SEO"},"seo-by-rank-math\/rank-math.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Rank Math SEO","PluginURI":"https:\/\/rankmath.com\/","Version":"1.0.270","Author":"Rank Math SEO","AuthorURI":"https:\/\/rankmath.com\/?utm_source=Plugin\u0026utm_medium=Readme%20Author%20URI\u0026utm_campaign=WP","TextDomain":"seo-by-rank-math","DomainPath":"\/languages","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Rank Math SEO","AuthorName":"Rank Math SEO"},"structured-content\/class-structuredcontent.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Structured Content","PluginURI":"https:\/\/wordpress.org\/plugins\/structured-content\/","Version":"1.7.0","Author":"Gordon Böhme, Antonio Leutsch","AuthorURI":"https:\/\/wpsc-plugin.com","TextDomain":"structured-content","DomainPath":"\/languages\/","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Structured Content","AuthorName":"Gordon Böhme, Antonio Leutsch"},"suretriggers\/suretriggers.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"OttoKit","PluginURI":"https:\/\/ottokit.com\/","Version":"1.1.27","Author":"OttoKit","AuthorURI":"https:\/\/ottokit.com\/","TextDomain":"suretriggers","DomainPath":"\/languages","Network":false,"RequiresWP":"5.4","RequiresPHP":"5.6","UpdateURI":"","RequiresPlugins":"","Title":"OttoKit","AuthorName":"OttoKit"},"wc-hide-shipping-methods\/hide-shipping-free-shipping.php":{"Plugin Slug":"","WC requires at least":"3.9.4","WC tested up to":"9.9","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"WC Hide Shipping Methods","PluginURI":"https:\/\/wordpress.org\/plugins\/wc-hide-shipping-methods\/","Version":"2.0.5","Author":"WPExperts","AuthorURI":"https:\/\/wpexperts.io","TextDomain":"wc-hide-shipping-methods","DomainPath":"\/languages","Network":false,"RequiresWP":"6.5","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"WC Hide Shipping Methods","AuthorName":"WPExperts"},"wc-messaging\/wc-messaging.php":{"Plugin Slug":"","WC requires at least":"3.7","WC tested up to":"10.7","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Notiqoo","PluginURI":"https:\/\/notiqoo.com\/","Version":"1.4.10","Author":"Notiqoo","AuthorURI":"https:\/\/notiqoo.com\/","TextDomain":"wc-messaging","DomainPath":"\/languages","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"woocommerce","Title":"Notiqoo","AuthorName":"Notiqoo"},"woo-order-export-lite\/woo-order-export-lite.php":{"Plugin Slug":"","WC requires at least":"4.0.0","WC tested up to":"10.6","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Advanced Order Export For WooCommerce","PluginURI":"","Version":"4.0.7","Author":"AlgolPlus","AuthorURI":"https:\/\/algolplus.com\/","TextDomain":"woo-order-export-lite","DomainPath":"\/i18n\/languages\/","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Advanced Order Export For WooCommerce","AuthorName":"AlgolPlus"},"woocommerce-multilingual-old\/wpml-woocommerce.php":{"Plugin Slug":"woocommerce-multilingual","WC requires at least":"3.9","WC tested up to":"10.6","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"WPML Multilingual \u0026 Multicurrency for WooCommerce","PluginURI":"https:\/\/wpml.org\/documentation\/related-projects\/woocommerce-multilingual\/?utm_source=plugin\u0026utm_medium=gui\u0026utm_campaign=wcml","Version":"5.5.5","Author":"OnTheGoSystems","AuthorURI":"http:\/\/www.onthegosystems.com\/","TextDomain":"woocommerce-multilingual","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"WPML Multilingual \u0026 Multicurrency for WooCommerce","AuthorName":"OnTheGoSystems"},"woocommerce\/woocommerce.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"WooCommerce","PluginURI":"https:\/\/woocommerce.com\/","Version":"10.7.0","Author":"Automattic","AuthorURI":"https:\/\/woocommerce.com","TextDomain":"woocommerce","DomainPath":"\/i18n\/languages\/","Network":false,"RequiresWP":"6.8","RequiresPHP":"7.4","UpdateURI":"","RequiresPlugins":"","Title":"WooCommerce","AuthorName":"Automattic"},"woodmart-core\/woodmart-core.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"Woodmart Core","PluginURI":"","Version":"1.1.6","Author":"","AuthorURI":"","TextDomain":"woodmart-core","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"Woodmart Core","AuthorName":""},"wpml-string-translation\/plugin.php":{"Plugin Slug":"wpml-string-translation","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"WPML String Translation","PluginURI":"https:\/\/wpml.org\/","Version":"3.5.2","Author":"OnTheGoSystems","AuthorURI":"http:\/\/www.onthegosystems.com\/","TextDomain":"wpml-string-translation","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"WPML String Translation","AuthorName":"OnTheGoSystems"},"wps-hide-login\/wps-hide-login.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"WPS Hide Login","PluginURI":"","Version":"1.9.18","Author":"WPServeur, NicolasKulka, wpformation","AuthorURI":"https:\/\/wpserveur.net","TextDomain":"wps-hide-login","DomainPath":"languages","Network":false,"RequiresWP":"4.1","RequiresPHP":"7.0","UpdateURI":"","RequiresPlugins":"","Title":"WPS Hide Login","AuthorName":"WPServeur, NicolasKulka, wpformation"}},"mu_plugins":{"wahag-hotfix-disable-as-runner.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"wahag-hotfix-disable-as-runner.php","PluginURI":"","Version":"","Description":"","Author":"","AuthorURI":"","TextDomain":"","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"","AuthorName":""},"wahag-hotfix-woo-admin.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"wahag-hotfix-woo-admin.php","PluginURI":"","Version":"","Description":"","Author":"","AuthorURI":"","TextDomain":"","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"","AuthorName":""}},"dropins":{"advanced-cache.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"advanced-cache.php","PluginURI":"","Version":"","Description":"","Author":"","AuthorURI":"","TextDomain":"","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"","AuthorName":""},"maintenance.php":{"Plugin Slug":"","WC requires at least":"","WC tested up to":"","Woo":"","Elementor tested up to":"","Elementor Pro tested up to":"","Name":"maintenance.php","PluginURI":"","Version":"","Description":"","Author":"","AuthorURI":"","TextDomain":"","DomainPath":"","Network":false,"RequiresWP":"","RequiresPHP":"","UpdateURI":"","RequiresPlugins":"","Title":"","AuthorName":""}}},"theme":{"Name":"WaHaG EG","ThemeURI":false,"Author":"EsLaM Hamed","AuthorURI":"https:\/\/eslamdev.com","Template":"woodmart","Version":"1.0.0","TextDomain":"woodmart","DomainPath":"","ParentName":"Woodmart"},"extra-debug":{"WPML(setup)":{"is-tm-allowed":true,"original-lang":"en","who-mode":["myself"],"translated-langs":["ar"],"current-step":"finished","translate-everything":false,"review-mode":"no-review","has-translate-everything-been-ever-used":false,"translate-everything-posts":[],"translate-everything-packages":[],"translate-everything-strings":[]},"WPML":{"hide_upgrade_notice":"4.7.5","translated_document_status_sync":1,"icl_capabilities_verified":true,"active_languages":["en","ar"],"interview_translators":1,"existing_content_language_verified":1,"language_negotiation_type":1,"icl_lso_link_empty":0,"sync_page_ordering":1,"sync_page_parent":1,"sync_page_template":1,"sync_ping_status":1,"sync_comment_status":1,"sync_sticky_flag":1,"sync_password":1,"sync_private_flag":1,"sync_post_format":1,"sync_delete":0,"sync_delete_tax":0,"sync_post_taxonomies":1,"sync_post_date":1,"sync_taxonomy_parents":0,"translation_pickup_method":0,"notify_complete":1,"translated_document_status":1,"remote_management":0,"auto_adjust_ids":1,"alert_delay":0,"promote_wpml":0,"automatic_redirect":0,"remember_language":24,"icl_lang_sel_copy_parameters":"","translated_document_page_url":"auto-generate","sync_comments_on_duplicates":0,"seo":{"head_langs":0,"canonicalization_duplicates":1,"head_langs_priority":1},"posts_slug_translation":{"on":1,"string_name_migrated":true},"urls":{"directory_for_default_language":0,"show_on_root":"","root_html_file_path":"","root_page":0,"hide_language_switchers":1},"xdomain_data":1,"custom_posts_sync_option":{"post":"1","page":"1","attachment":1,"wp_block":1,"wp_navigation":1,"wp_template":1,"wp_template_part":1,"elementor_library":2,"e-landing-page":2,"e-floating-buttons":2,"mc4wp-form":1,"cms_block":1,"portfolio":1,"woodmart_sidebar":0,"woodmart_slide":1,"product":1,"product_variation":1,"shop_coupon":0,"shop_order":0,"templately_library":1,"custom_css":"0","customize_changeset":"0","oembed_cache":"0","user_request":"0","wp_global_styles":"0","wp_font_family":"0","wp_font_face":"0","wpcode":"0","elementor_snippet":"0","woodmart_layout":"1","woodmart_woo_lv":"0","woodmart_woo_fbt":"0","woodmart_size_guide":"0","shop_order_refund":"0","shop_order_placehold":"0","wpcf7_contact_form":1,"patterns_ai_data":"0","rm_content_editor":"0","rank_math_schema":"0","elementor_font":"0","elementor_icons":"0","acf-post-type":0,"acf-taxonomy":0,"acf-ui-options-page":0,"wpr_templates":1,"acf-field-group":0,"omapi":0,"popup":1,"elementor_component":2,"wd_popup":1,"wd_floating_block":1,"wd_product_tabs":1},"taxonomies_sync_option":{"category":"2","post_tag":"1","translation_priority":"0","wp_theme":0,"elementor_library_type":0,"categories":1,"project-cat":"2","tag":1,"woodmart_slider":0,"product_cat":"2","product_tag":1,"product_type":0,"shop_order_status":0,"product_visibility":0,"product_shipping_class":1,"wp_template_part_area":"0","wp_pattern_category":"2","wpcode_type":"0","wpcode_location":"0","wpcode_tags":"0","elementor_library_category":"2","cms_block_cat":"0","product_brand":"0","pa_cm":"0","pa_colors":"1","pa_size":"1","elementor_font_type":"0","pa_strings":"1","wd_popup_cat":"0","wd_floating_block_cat":"0","pos_product_visibility":"0"},"tm_block_retranslating_terms":1,"admin_default_language":"_default_","ajx_health_checked":true,"st":{"autoregister_strings":2,"db_ok_for_gettext_context":true,"WPML_ST_Upgrade_MO_Scanning_4_has_run":true,"strings_per_page":"100","icl_st_auto_reg":"disable","strings_language":"en","WPML_ST_Upgrade_Migrate_Originals_has_run":true,"WPML_ST_Upgrade_Display_Strings_Scan_Notices_has_run":true,"WPML_ST_Upgrade_DB_String_Name_Index_2_has_run":true,"WPML_ST_Upgrade_DB_Longtext_String_Value_has_run":true,"WPML_ST_Upgrade_DB_Strings_Add_Translation_Priority_Field_has_run":true,"WPML\\ST\\MO\\Generate\\Process\\Status_background_has_run":true,"WPML\\ST\\Upgrade\\Command\\RegenerateMoFilesWithStringNames_has_run":true,"WPML\\ST\\Upgrade\\Command\\MigrateMultilingualWidgets_has_run":true,"WPML\\ST\\Upgrade\\Command\\UpgradeAutoregisteringStrings_has_run":true,"WPML\\ST\\MO\\Generate\\Process\\Status_has_run":true,"translated-users":[],"sw":[],"WPML_ST_Upgrade_DB_String_Packages_Word_Count_has_run":true,"WPML_ST_Upgrade_DB_String_Packages_Translator_Note_has_run":true,"autoregister_strings_should_register_backend_strings":false,"WPML_ST_Upgrade_DB_String_Packages_2.4.2_has_run":true,"plugin_localization_domains":{"woodmart-core\/woodmart-core.php":{"woodmart":348,"wordpress-importer":110},"woocommerce\/woocommerce.php":{"woocommerce":10241,"jetpack-admin-ui":8,"jetpack-assets":8,"jetpack-config":4,"jetpack-connection":708,"woocommerce-brands":8},"sitepress-multilingual-cms\/sitepress.php":{"wpml":0,"sitepress":1409,"wpml-translation-management":826,"sitepress-wpml-media-setup-ui":0,"sitepress-wpml-ate-jobs-sync-ui":55,"installer":193,"sitepress-wpml-translationReview-ui":0,"sitepress-multilingual-cms":26,"wpml-transation-manager":1,"bbpress":1,"default":14,"wpml-translation-manager":3,"wpml-media":5,"js_composer":1,"wpml-page-builders":3},"seo-by-rank-math\/rank-math.php":{"rank-math":2110,"cmb2":93,"action-scheduler":227},"webappick-product-feed-for-woocommerce\/woo-feed.php":{"woo-feed":813,"Disco icon":2,"my-textdomain":3,"textdomain":1},"paymob-for-woocommerce\/init-paymob.php":{"paymob-woocommerce":239,"woocommerce":13902,"paymob_woocommerce":6,"WordPress":2},"wpml-string-translation\/plugin.php":{"wpml-string-translation":348,"wpml-string-translation-wpml-mo-scan-ui":0,"wpml_string_translation":3,"wordpress-language":1},"elementor\/elementor.php":{"elementor":4380},"contact-form-7\/wp-contact-form-7.php":{"contact-form-7":440},"all-in-one-wp-migration\/all-in-one-wp-migration.php":{"all-in-one-wp-migration":299},"woocommerce-multilingual\/wpml-woocommerce.php":{"woocommerce-multilingual":1289,"sitepress":36,"woocommerce":13826,"WordPress":5,"woocommerce-bookings":8,"woo_ce":6,"default":2,"installer":645},"woo-cart-abandonment-recovery\/woo-cart-abandonment-recovery.php":{"woo-cart-abandonment-recovery":640},"classic-editor\/classic-editor.php":{"classic-editor":23},"duplicate-page\/duplicatepage.php":{"duplicate-page":48},"wps-hide-login\/wps-hide-login.php":{"wps-hide-login":27,"WordPress":95},"mailchimp-for-wp\/mailchimp-for-wp.php":{"mailchimp-for-wp":393,"wpforms":2,"ninja-forms":2},"webp-converter-for-media\/webp-converter-for-media.php":{"webp-converter-for-media":286},"wccp-pro\/preventer-index.php":{"wccp_pro_translation_slug":178,"plugin-update-checker":6,"rc_slider":1},"templately\/templately.php":{"templately":291},"safe-svg\/safe-svg.php":{"safe-svg":11},"elementor-pro\/elementor-pro.php":{"elementor-pro":7415,"mailpoet":1},"duracelltomi-google-tag-manager\/duracelltomi-google-tag-manager-for-wordpress.php":{"duracelltomi-google-tag-manager":260},"insert-headers-and-footers\/ihaf.php":{"insert-headers-and-footers":2684,"header-footer-code-manager":4},"woo-checkout-field-editor-pro\/checkout-form-designer.php":{"woo-checkout-field-editor-pro":180,"woocommerce-checkout-field-editor-pro":1,"woo-checkout-field-editor":4,"storefront":3},"seo-by-rank-math-pro\/rank-math-pro.php":{"rank-math-pro":1699},"customer-reviews-woocommerce\/ivole.php":{"customer-reviews-woocommerce":48},"advanced-custom-fields\/acf.php":{"acf":753},"advanced-custom-fields-pro\/acf.php":{"acf":753},"wpr-addons-pro\/wpr-addons-pro.php":{"acf":142},"woocommerce-points-and-rewards\/woocommerce-points-and-rewards.php":{"woocommerce-points-and-rewards":170,"woocommerce":2,"woogrow-compat-checker":16}},"active_cache_plugin_id":"wp-super-cache\/wp-cache.php","active_cache_plugin_name":"WP Super Cache","visible_columns":{"title":true,"name":true,"domain":true,"source":true,"type":false},"WPML\\ST\\Upgrade\\Command\\UpgradeWpSettingsStrings_has_run":true,"autoregister_strings_were_new_translations_loaded":true,"WPML\\ST\\Upgrade\\Command\\DeleteFileHashingOption_has_run":true,"was_frontend_visited_key":1},"default_categories":{"en":"299","ar":522},"default_language":"en","setup_wizard_step":3,"languages_order":["ar","en"],"dont_show_help_admin_notice":true,"store_frontend_cookie":1,"setup_complete":1,"translation-management":{"custom_fields_translation":{"title":2,"description":2,"keywords":2,"_edit_last":0,"_edit_lock":0,"_wp_page_template":0,"_wp_attachment_metadata":0,"original_post_id":0,"_wpml_original_post_id":0,"_wp_old_slug":0,"_icl_translator_note":0,"_alp_processed":0,"_pingme":0,"_encloseme":0,"_icl_lang_duplicate_of":0,"_thumbnail_id":0,"_wp_attached_file":0,"_wp_attachment_image_alt":2,"footnotes":2,"_elementor_page_settings":3,"_elementor_edit_mode":1,"_elementor_template_type":1,"_elementor_version":1,"_elementor_data":3,"_elementor_css":0,"_elementor_popup_display_settings":3,"_mc4wp_settings":3,"text_subscribed":2,"text_error":2,"text_invalid_email":2,"text_already_subscribed":2,"text_required_field_missing":2,"text_unsubscribed":2,"text_not_subscribed":2,"text_no_lists_selected":2,"rank_math_title":2,"rank_math_description":2,"rank_math_facebook_title":2,"rank_math_facebook_description":2,"rank_math_twitter_title":2,"rank_math_twitter_description":2,"rank_math_focus_keyword":2,"rank_math_canonical_url":0,"rank_math_robots":3,"rank_math_pillar_content":3,"rank_math_facebook_enable_image_overlay":1,"rank_math_facebook_image_overlay":1,"rank_math_twitter_use_facebook":1,"rank_math_twitter_card_type":1,"rank_math_twitter_enable_image_overlay":1,"rank_math_twitter_image_overlay":1,"rank_math_primary_category":1,"rank_math_primary_product_cat":1,"wd_layout_type":1,"wd_layout_conditions":3,"_woodmart_extra_content":2,"_woodmart_product_custom_tab_title":2,"_woodmart_product_custom_tab_content":2,"_woodmart_product_custom_tab_title_2":2,"_woodmart_product_custom_tab_content_2":2,"woodmart_wc_video_gallery":2,"_backorders":1,"_crosssell_ids":2,"_default_attributes":0,"_download_limit":1,"_download_expiry":1,"_download_type":1,"_downloadable":1,"_file_paths":2,"_downloadable_files":2,"_featured":1,"_manage_stock":1,"_sku":1,"_global_unique_id":1,"_stock":0,"_stock_status":1,"_sold_individually":1,"_subscription_length":1,"_subscription_period":1,"_subscription_period_interval":1,"_subscription_price":1,"_subscription_sign_up_fee":1,"_subscription_trial_length":1,"_subscription_trial_period":1,"_tax_class":1,"_tax_status":1,"_upsell_ids":2,"_virtual":1,"_visibility":1,"_weight":1,"_width":1,"_height":1,"_length":1,"_woocommerce_exclude_image":1,"total_sales":1,"_product_url":2,"_button_text":2,"_purchase_note":2,"_wcml_custom_prices_status":0,"_min_price_variation_id":0,"_min_regular_price_variation_id":0,"_min_sale_price_variation_id":0,"_max_price_variation_id":0,"_max_regular_price_variation_id":0,"_max_sale_price_variation_id":0,"attr_label_translations":0,"_per_product_pricing_active":1,"_pricing_rules":1,"_regular_price":1,"_sale_price":1,"_price":1,"_min_variation_regular_price":1,"_min_variation_sale_price":1,"_min_variation_price":1,"_max_variation_regular_price":1,"_max_variation_sale_price":1,"_max_variation_price":1,"_sale_price_dates_from":1,"_sale_price_dates_to":1,"_wcml_schedule":1,"_variation_description":2,"wcml_sync_hash":0,"wpml_language":0,"_product_attributes":0,"_children":2,"_subscription_limit":1,"_low_stock_amount":1,"_regular_price_EGP":0,"_sale_price_EGP":0,"_price_EGP":0,"_min_variation_regular_price_EGP":0,"_min_variation_sale_price_EGP":0,"_min_variation_price_EGP":0,"_max_variation_regular_price_EGP":0,"_max_variation_sale_price_EGP":0,"_max_variation_price_EGP":0,"_sale_price_dates_from_EGP":0,"_sale_price_dates_to_EGP":0,"_wcml_schedule_EGP":0,"_templately_template_type":1,"_templately_template_platform":1,"_templately_conditions":1,"_templately_import_session_id":1,"_additional_settings":1,"_form":2,"_hash":1,"_locale":1,"_mail":2,"_mail_2":2,"_messages":2,"_woodmart_custom_sidebar":"2","_woodmart_main_layout":"2","_woodmart_mobile_content":"2","_woodmart_open_categories":"2","_woodmart_page-title-size":"2","_woodmart_sidebar_width":"2","_woodmart_title_bg_color":"2","_woodmart_title_color":"2","_woodmart_title_image":"2","_woodmart_title_off":"2","_woodmart_whb_header":"2","attribute_color-of-the-globe":"0","attribute_number-of-globe":"0","attribute_number-of-globes":"0","attribute_number-of-pieces":"0","attribute_pa_cm":"0","attribute_pa_colors":"0","attribute_pa_size":"0","attribute_size":"0","bg_color":"0","bg_image_desktop":"0","bg_image_mobile":"0","bg_image_position_desktop":"0","bg_image_position_mobile":"0","bg_image_position_tablet":"0","bg_image_position_x_mobile":"0","bg_image_position_x_tablet":"0","bg_image_position_y_mobile":"0","bg_image_position_y_tablet":"0","bg_image_size_desktop":"0","bg_image_tablet":"0","content_width":"0","content_width_mobile":"0","content_width_tablet":"0","fb_age_group":"0","fb_brand":"0","fb_color":"0","fb_gender":"0","fb_material":"0","fb_mpn":"0","fb_pattern":"0","fb_product_condition":"0","fb_product_description":"0","fb_product_group_id":"0","fb_product_image":"0","fb_product_item_id":"0","fb_product_price":"0","fb_product_video":"0","fb_rich_text_description":"0","fb_size":"0","fb_visibility":"0","gallery_sync":"0","horizontal_align":"0","instant-layout-style":"0","rank_math_analytic_object_id":"0","rank_math_contentai_score":"0","rank_math_internal_links_processed":"0","rank_math_news_sitemap_robots":"0","rank_math_og_content_image":"0","rank_math_primary_fb_product_set":"0","rank_math_primary_product_brand":"0","rank_math_seo_score":"0","slide_animation":"0","text_updated":"0","vertical_align":"0","wcf-flow-id":"0","wcf-step-type":"0","wcf-steps":"0","wd_additional_variation_images_data":"0","wd_page_css_files":"0","woodmart_chosen_cats":"0","woodmart_fbt_bundles_id":"0","woodmart_price_unit_of_measure":"0","woodmart_sguide":"0","woodmart_sguide_hide_table":"0","woodmart_sguide_select":"0","woodmart_total_stock_quantity":"0","wpfoof-identifier_exists":"0","wpr_secondary_image_id":"0","_awcdp_deposits_deposit_amount":"0","_awcdp_deposit_enabled":"0","_awcdp_deposit_type":"0","_cms_nav_minihome":"0","_eael_custom_js":"0","_eael_post_view_count":"0","_eb_reusable_block_ids":"0","_elementor_conditions":"0","_elementor_controls_usage":"0","_elementor_element_cache":"0","_elementor_is_screenshot":"0","_elementor_page_assets":"0","_elementor_pro_version":"0","_elementor_screenshot":"0","_elementor_screenshot_failed":"0","_elementor_source":"0","_elementor_source_image_hash":"0","_elementor_template_layout_type":"0","_elementor_template_widget_type":"0","_last_translation_edit_mode":"0","_menu_item_block":"0","_menu_item_classes":"0","_menu_item_colorscheme":"0","_menu_item_design":"0","_menu_item_dropdown-ajax":"0","_menu_item_event":"0","_menu_item_height":"0","_menu_item_icon":"0","_menu_item_image-type":"0","_menu_item_label":"0","_menu_item_label-text":"0","_menu_item_menu_item_parent":"0","_menu_item_object":"0","_menu_item_object_id":"0","_menu_item_opanchor":"0","_menu_item_padding":"0","_menu_item_scroll":"0","_menu_item_style_aside":"0","_menu_item_target":"0","_menu_item_type":"0","_menu_item_url":"0","_menu_item_width":"0","_menu_item_xfn":"0","_product_360_image_gallery":"0","_product_image_gallery":"0","_product_version":"0","_top_nav_excluded":"0","_trp_automatically_translated_slug_ar":"0","_trp_menu_languages":"0","_trp_translated_slug_ar":"0","_wcml_average_rating":"0","_wcml_duplicate_of_variation":"0","_wcml_rating_count":"0","_wcml_review_count":"0","_wc_attachment_source":"0","_wc_average_rating":"0","_wc_facebook_product_image_source":"0","_wc_facebook_sync_enabled":"0","_wc_review_count":"0","_woodmart_copyrights_off":"0","_woodmart_exclude_show_single_variation":"0","_woodmart_extra_position":"0","_woodmart_footer_off":"0","_woodmart_hide_tabs_titles":"2","_woodmart_new_label":"2","_woodmart_new_label_date":"2","_woodmart_prefooter_off":"0","_woodmart_product-background":"0","_woodmart_product_custom_tab_content_type":"0","_woodmart_product_custom_tab_content_type_2":"0","_woodmart_product_custom_tab_html_block":"0","_woodmart_product_custom_tab_html_block_2":"0","_woodmart_product_design":"0","_woodmart_product_hashtag":"0","_woodmart_product_video":"0","_woodmart_related_off":"0","_woodmart_single_product_style":"0","_woodmart_swatches_attribute":"0","_woodmart_thums_position":"0","_wpcode_auto_insert":"0","_wpcode_auto_insert_number":"0","_wpcode_conditional_logic":"0","_wpcode_conditional_logic_enabled":"0","_wpcode_library_id":"0","_wpcode_location_extra":"0","_wpcode_note":"0","_wpcode_priority":"0","_wpcode_shortcode_attributes":"0","_wpml_location_migration_done":"0","_wpml_media_has_media":"0","_wpml_media_usage":"0","_wpml_post_translation_editor_native":"0","_wpml_word_count":"0","_wp_attachment_backup_sizes":"0","_wp_desired_post_slug":"0","_wp_old_date":"0","_wp_trash_meta_status":"0","_wp_trash_meta_time":"0","_yoast_wpseo_content_score":"0","_yoast_wpseo_estimated-reading-time-minutes":"0","_yoast_wpseo_primary_fb_product_set":"0","_yoast_wpseo_primary_product_brand":"0","_yoast_wpseo_primary_product_cat":1,"_cogs_total_value":1,"gallery_reviews":1,"_gallery_reviews":1,"product_reviews_gallery":1,"_product_reviews_gallery":1,"popup_settings":3,"popup_title":3,"_wpml_media_duplicate":1,"_wpml_media_featured":1,"_sections_layout_meta":1,"_action_manager_schedule":0,"_yoast_wpseo_title":2,"_yoast_wpseo_bctitle":2,"_yoast_wpseo_metadesc":2,"_yoast_wpseo_metakeywords":2,"_yoast_wpseo_focuskw":2,"_yoast_wpseo_focuskeywords":2,"_yoast_wpseo_meta-robots-noindex":1,"_yoast_wpseo_meta-robots-nofollow":1,"_yoast_wpseo_meta-robots-adv":1,"_yoast_wpseo_canonical":0,"_yoast_wpseo_redirect":0,"_yoast_wpseo_opengraph-description":2,"_yoast_wpseo_google-plus-description":2,"_yoast_wpseo_twitter-title":2,"_yoast_wpseo_twitter-description":2,"_yoast_wpseo_opengraph-title":2,"_yoast_wpseo_opengraph-image":3,"_yoast_wpseo_twitter-image":3,"_yoast_wpseo_primary_category":1},"custom_fields_readonly_config":["title","description","keywords","_edit_last","_edit_lock","_wp_page_template","_wp_attachment_metadata","original_post_id","_wpml_original_post_id","_wp_old_slug","_icl_translator_note","_alp_processed","_pingme","_encloseme","_icl_lang_duplicate_of","_thumbnail_id","_wp_attached_file","_wp_attachment_image_alt","footnotes","_elementor_page_settings","_elementor_edit_mode","_elementor_template_type","_elementor_version","_elementor_data","_elementor_css","_elementor_popup_display_settings","rank_math_title","rank_math_description","rank_math_facebook_title","rank_math_facebook_description","rank_math_twitter_title","rank_math_twitter_description","rank_math_focus_keyword","rank_math_canonical_url","rank_math_robots","rank_math_pillar_content","rank_math_facebook_enable_image_overlay","rank_math_facebook_image_overlay","rank_math_twitter_use_facebook","rank_math_twitter_card_type","rank_math_twitter_enable_image_overlay","rank_math_twitter_image_overlay","rank_math_primary_category","rank_math_primary_product_cat","_backorders","_crosssell_ids","_default_attributes","_download_limit","_download_expiry","_download_type","_downloadable","_file_paths","_downloadable_files","_featured","_manage_stock","_sku","_global_unique_id","_stock","_stock_status","_sold_individually","_subscription_length","_subscription_period","_subscription_period_interval","_subscription_price","_subscription_sign_up_fee","_subscription_trial_length","_subscription_trial_period","_tax_class","_tax_status","_upsell_ids","_virtual","_visibility","_weight","_width","_height","_length","_woocommerce_exclude_image","total_sales","_product_url","_button_text","_purchase_note","_wcml_custom_prices_status","_min_price_variation_id","_min_regular_price_variation_id","_min_sale_price_variation_id","_max_price_variation_id","_max_regular_price_variation_id","_max_sale_price_variation_id","attr_label_translations","_per_product_pricing_active","_pricing_rules","_regular_price","_sale_price","_price","_cogs_total_value","_min_variation_regular_price","_min_variation_sale_price","_min_variation_price","_max_variation_regular_price","_max_variation_sale_price","_max_variation_price","_sale_price_dates_from","_sale_price_dates_to","_wcml_schedule","_variation_description","wcml_sync_hash","wpml_language","_product_attributes","_children","_subscription_limit","_low_stock_amount","wd_layout_type","wd_layout_conditions","_woodmart_extra_content","_woodmart_product_custom_tab_title","_woodmart_product_custom_tab_content","_woodmart_product_custom_tab_title_2","_woodmart_product_custom_tab_content_2","woodmart_wc_video_gallery"],"custom_fields_translation_custom":[],"custom_fields_translation_custom_readonly":[],"doc_translation_method":"ATE","__custom_types_readonly_config_prev":[],"custom_types_readonly_config":[],"__custom_fields_readonly_config_prev":["title","description","keywords","_edit_last","_edit_lock","_wp_page_template","_wp_attachment_metadata","original_post_id","_wpml_original_post_id","_wp_old_slug","_icl_translator_note","_alp_processed","_pingme","_encloseme","_icl_lang_duplicate_of","_thumbnail_id","_wp_attached_file","_wp_attachment_image_alt","footnotes","_elementor_page_settings","_elementor_edit_mode","_elementor_template_type","_elementor_version","_elementor_data","_elementor_css","_elementor_popup_display_settings","rank_math_title","rank_math_description","rank_math_facebook_title","rank_math_facebook_description","rank_math_twitter_title","rank_math_twitter_description","rank_math_focus_keyword","rank_math_canonical_url","rank_math_robots","rank_math_pillar_content","rank_math_facebook_enable_image_overlay","rank_math_facebook_image_overlay","rank_math_twitter_use_facebook","rank_math_twitter_card_type","rank_math_twitter_enable_image_overlay","rank_math_twitter_image_overlay","rank_math_primary_category","rank_math_primary_product_cat","_backorders","_crosssell_ids","_default_attributes","_download_limit","_download_expiry","_download_type","_downloadable","_file_paths","_downloadable_files","_featured","_manage_stock","_sku","_global_unique_id","_stock","_stock_status","_sold_individually","_subscription_length","_subscription_period","_subscription_period_interval","_subscription_price","_subscription_sign_up_fee","_subscription_trial_length","_subscription_trial_period","_tax_class","_tax_status","_upsell_ids","_virtual","_visibility","_weight","_width","_height","_length","_woocommerce_exclude_image","total_sales","_product_url","_button_text","_purchase_note","_wcml_custom_prices_status","_min_price_variation_id","_min_regular_price_variation_id","_min_sale_price_variation_id","_max_price_variation_id","_max_regular_price_variation_id","_max_sale_price_variation_id","attr_label_translations","_per_product_pricing_active","_pricing_rules","_regular_price","_sale_price","_price","_cogs_total_value","_min_variation_regular_price","_min_variation_sale_price","_min_variation_price","_max_variation_regular_price","_max_variation_sale_price","_max_variation_price","_sale_price_dates_from","_sale_price_dates_to","_wcml_schedule","_variation_description","wcml_sync_hash","wpml_language","_product_attributes","_children","_subscription_limit","_low_stock_amount","wd_layout_type","wd_layout_conditions","_woodmart_extra_content","_woodmart_product_custom_tab_title","_woodmart_product_custom_tab_content","_woodmart_product_custom_tab_title_2","_woodmart_product_custom_tab_content_2","woodmart_wc_video_gallery"],"__custom_term_fields_readonly_config_prev":["rank_math_focus_keyword","rank_math_description","rank_math_title","category_extra_description_text"],"custom_term_fields_readonly_config":["rank_math_focus_keyword","rank_math_description","rank_math_title","category_extra_description_text"],"custom_fields_encoding":{"footnotes":"json"},"custom_fields_editor_label":{"wd_layout_type":"Layout type","wd_layout_conditions":"Layout conditions","_woodmart_extra_content":"Extra content","_woodmart_product_custom_tab_title":"Custom tab title","_woodmart_product_custom_tab_content":"Custom tab content","_woodmart_product_custom_tab_title_2":"Custom tab 2 title","_woodmart_product_custom_tab_content_2":"Custom tab 2 content","_yoast_wpseo_bctitle":"Breadcrumb Title","_yoast_wpseo_metadesc":"Meta Description","_yoast_wpseo_metakeywords":"Meta Keywords","_yoast_wpseo_focuskw":"Focus Keyword","_yoast_wpseo_focuskeywords":"Focus Keywords"},"custom_term_fields_translation":{"rank_math_focus_keyword":2,"rank_math_description":2,"rank_math_title":2,"category_extra_description_text":2,"gallery_reviews":1,"_gallery_reviews":1,"product_reviews_gallery":1,"_product_reviews_gallery":1},"custom_term_fields_editor_label":{"category_extra_description_text":"Extra description"},"custom_fields_attributes_whitelist":{"footnotes":{"*":{"content":"Footnote"}},"woodmart_wc_video_gallery":{"*":{"upload_video_url":"","youtube_url":"","vimeo_url":""}},"_yoast_wpseo_focuskeywords":{"*":{"keyword":""}},"_mail":{"subject":"","body":""},"_mail_2":{"subject":"","body":""}},"taxonomies_readonly_config":{"translation_priority":1,"wp_theme":0,"elementor_library_type":0,"product_cat":1,"product_tag":1,"product_type":0,"shop_order_status":0,"product_visibility":0,"product_shipping_class":1,"categories":1,"tag":1,"woodmart_slider":0},"custom-types_readonly_config":{"attachment":1,"wp_block":1,"wp_navigation":1,"wp_template":1,"wp_template_part":1,"elementor_library":2,"e-landing-page":2,"e-floating-buttons":2,"elementor_component":2,"product":1,"product_variation":1,"shop_coupon":0,"shop_order":0,"cms_block":1,"portfolio":1,"woodmart_sidebar":0,"woodmart_slide":1,"wd_popup":1,"wd_floating_block":1,"wd_product_tabs":1},"custom_fields_unlocked_config":{"_additional_settings":"0","_elementor_edit_mode":"0","_elementor_template_type":"0","_form":"0","_hash":"0","_locale":"0","_mail":"0","_mail_2":"0","_messages":"0","_woodmart_custom_sidebar":"0","_woodmart_main_layout":"0","_woodmart_mobile_content":"0","_woodmart_open_categories":"0","_woodmart_page-title-size":"0","_woodmart_sidebar_width":"0","_woodmart_title_bg_color":"0","_woodmart_title_color":"0","_woodmart_title_image":"0","_woodmart_title_off":"0","_woodmart_whb_header":"0","attribute_color-of-the-globe":"0","attribute_number-of-globe":"0","attribute_number-of-globes":"0","attribute_number-of-pieces":"0","attribute_pa_cm":"0","attribute_pa_colors":"0","attribute_pa_size":"0","attribute_size":"0","attr_label_translations":"0","bg_color":"0","bg_image_desktop":"0","bg_image_mobile":"0","bg_image_position_desktop":"0","bg_image_position_mobile":"0","bg_image_position_tablet":"0","bg_image_position_x_mobile":"0","bg_image_position_x_tablet":"0","bg_image_position_y_mobile":"0","bg_image_position_y_tablet":"0","bg_image_size_desktop":"0","bg_image_tablet":"0","content_width":"0","content_width_mobile":"0","content_width_tablet":"0","fb_age_group":"0","fb_brand":"0","fb_color":"0","fb_gender":"0","fb_material":"0","fb_mpn":"0","fb_pattern":"0","fb_product_condition":"0","fb_product_description":"0","fb_product_group_id":"0","fb_product_image":"0","fb_product_item_id":"0","fb_product_price":"0","fb_product_video":"0","fb_rich_text_description":"0","fb_size":"0","fb_visibility":"0","gallery_sync":"0","horizontal_align":"0","instant-layout-style":"0","rank_math_analytic_object_id":"0","rank_math_contentai_score":"0","rank_math_description":"0","rank_math_focus_keyword":"0","rank_math_internal_links_processed":"0","rank_math_news_sitemap_robots":"0","rank_math_og_content_image":"0","rank_math_primary_category":"0","rank_math_primary_fb_product_set":"0","rank_math_primary_product_brand":"0","rank_math_primary_product_cat":"0","rank_math_robots":"0","rank_math_seo_score":"0","rank_math_title":"0","slide_animation":"0","text_already_subscribed":"0","text_error":"0","text_invalid_email":"0","text_not_subscribed":"0","text_no_lists_selected":"0","text_required_field_missing":"0","text_subscribed":"0","text_unsubscribed":"0","text_updated":"0","total_sales":"0","vertical_align":"0","wcf-flow-id":"0","wcf-step-type":"0","wcf-steps":"0","wcml_sync_hash":"0","wd_additional_variation_images_data":"0","wd_layout_conditions":"0","wd_layout_type":"0","wd_page_css_files":"0","woodmart_chosen_cats":"0","woodmart_fbt_bundles_id":"0","woodmart_price_unit_of_measure":"0","woodmart_sguide":"0","woodmart_sguide_hide_table":"0","woodmart_sguide_select":"0","woodmart_total_stock_quantity":"0","woodmart_wc_video_gallery":"0","wpfoof-identifier_exists":"0","wpr_secondary_image_id":"0","_awcdp_deposits_deposit_amount":"0","_awcdp_deposit_enabled":"0","_awcdp_deposit_type":"0","_backorders":"0","_children":"0","_cms_nav_minihome":"0","_crosssell_ids":"0","_default_attributes":"0","_downloadable":"0","_downloadable_files":"0","_download_expiry":"0","_download_limit":"0","_eael_custom_js":"0","_eael_post_view_count":"0","_eb_reusable_block_ids":"0","_elementor_conditions":"0","_elementor_controls_usage":"0","_elementor_css":"0","_elementor_data":"0","_elementor_element_cache":"0","_elementor_is_screenshot":"0","_elementor_page_assets":"0","_elementor_page_settings":"0","_elementor_popup_display_settings":"0","_elementor_pro_version":"0","_elementor_screenshot":"0","_elementor_screenshot_failed":"0","_elementor_source":"0","_elementor_source_image_hash":"0","_elementor_template_layout_type":"0","_elementor_template_widget_type":"0","_elementor_version":"0","_last_translation_edit_mode":"0","_manage_stock":"0","_mc4wp_settings":"0","_menu_item_block":"0","_menu_item_classes":"0","_menu_item_colorscheme":"0","_menu_item_design":"0","_menu_item_dropdown-ajax":"0","_menu_item_event":"0","_menu_item_height":"0","_menu_item_icon":"0","_menu_item_image-type":"0","_menu_item_label":"0","_menu_item_label-text":"0","_menu_item_menu_item_parent":"0","_menu_item_object":"0","_menu_item_object_id":"0","_menu_item_opanchor":"0","_menu_item_padding":"0","_menu_item_scroll":"0","_menu_item_style_aside":"0","_menu_item_target":"0","_menu_item_type":"0","_menu_item_url":"0","_menu_item_width":"0","_menu_item_xfn":"0","_price":"0","_product_360_image_gallery":"0","_product_attributes":"0","_product_image_gallery":"0","_product_version":"0","_regular_price":"0","_sale_price":"0","_sku":"0","_sold_individually":"0","_stock":"0","_stock_status":"0","_tax_class":"0","_tax_status":"0","_top_nav_excluded":"0","_trp_automatically_translated_slug_ar":"0","_trp_menu_languages":"0","_trp_translated_slug_ar":"0","_upsell_ids":"0","_variation_description":"0","_virtual":"0","_wcml_average_rating":"0","_wcml_duplicate_of_variation":"0","_wcml_rating_count":"0","_wcml_review_count":"0","_wc_attachment_source":"0","_wc_average_rating":"0","_wc_facebook_product_image_source":"0","_wc_facebook_sync_enabled":"0","_wc_review_count":"0","_woodmart_copyrights_off":"0","_woodmart_exclude_show_single_variation":"0","_woodmart_extra_content":"0","_woodmart_extra_position":"0","_woodmart_footer_off":"0","_woodmart_hide_tabs_titles":"0","_woodmart_new_label":"0","_woodmart_new_label_date":"0","_woodmart_prefooter_off":"0","_woodmart_product-background":"0","_woodmart_product_custom_tab_content":"0","_woodmart_product_custom_tab_content_2":"0","_woodmart_product_custom_tab_content_type":"0","_woodmart_product_custom_tab_content_type_2":"0","_woodmart_product_custom_tab_html_block":"0","_woodmart_product_custom_tab_html_block_2":"0","_woodmart_product_custom_tab_title":"0","_woodmart_product_custom_tab_title_2":"0","_woodmart_product_design":"0","_woodmart_product_hashtag":"0","_woodmart_product_video":"0","_woodmart_related_off":"0","_woodmart_single_product_style":"0","_woodmart_swatches_attribute":"0","_woodmart_thums_position":"0","_wpcode_auto_insert":"0","_wpcode_auto_insert_number":"0","_wpcode_conditional_logic":"0","_wpcode_conditional_logic_enabled":"0","_wpcode_library_id":"0","_wpcode_location_extra":"0","_wpcode_note":"0","_wpcode_priority":"0","_wpcode_shortcode_attributes":"0","_wpml_location_migration_done":"0","_wpml_media_has_media":"0","_wpml_media_usage":"0","_wpml_post_translation_editor_native":"0","_wpml_word_count":"0","_wp_attached_file":"0","_wp_attachment_backup_sizes":"0","_wp_attachment_image_alt":"0","_wp_desired_post_slug":"0","_wp_old_date":"0","_wp_old_slug":"0","_wp_trash_meta_status":"0","_wp_trash_meta_time":"0","_yoast_wpseo_content_score":"0","_yoast_wpseo_estimated-reading-time-minutes":"0","_yoast_wpseo_primary_fb_product_set":"0","_yoast_wpseo_primary_product_brand":"0","_yoast_wpseo_primary_product_cat":"0"},"notification":{"new-job":1,"include_xliff":0,"completed_frequency":3,"completed":1,"resigned":1,"overdue":1,"overdue_offset":7,"dashboard":true,"purge-old":7,"job_limits":0},"post_translation_editor_wpml":"wpml","post_translation_editor_wpml_for_post_type":{"product":"wpml"}},"custom-types_sync_option":{"attachment":1,"wp_block":1,"wp_navigation":1,"wp_template":1,"wp_template_part":1,"elementor_library":2,"e-landing-page":2,"e-floating-buttons":2,"mc4wp-form":1,"cms_block":1,"portfolio":1,"woodmart_sidebar":0,"woodmart_slide":1,"product":1,"product_variation":1,"shop_coupon":0,"shop_order":0,"templately_library":1,"acf-post-type":0,"acf-taxonomy":0,"acf-ui-options-page":0,"wpr_templates":1,"omapi":0,"popup":1,"elementor_component":2,"wd_popup":1,"wd_floating_block":1,"wd_product_tabs":1,"wpcf7_contact_form":1},"theme_localization_load_textdomain":0,"xliff_newlines":2,"tm_xliff_version":"12","site_does_not_use_icl":true,"language_selector_initialized":1,"gettext_theme_domain_name":"default,woodmart,woo-cart-abandonment-recovery,all-in-one-wp-migration,installer,woocommerce,woo-checkout-field-editor-pro,classic-editor,contact-form-7,webp-converter-for-media,duplicate-page,elementor,elementor-pro,duracelltomi-google-tag-manager,mailchimp-for-wp,paymob-woocommerce,rank-math,rank-math-pro,safe-svg,insert-headers-and-footers,wpccp,wpml-string-translation,wps-hide-login,woocommerce-multilingual,WP Endpoints,WordPress,admin_texts_woocommerce_gateways,wpml-translation-management,sitepress,woo-feed,admin_texts_woocommerce_price_decimal_sep,cmb2,js_composer,admin_texts_woocommerce_price_thousand_sep,admin_texts_xts-woodmart-options,admin_texts_rank-math-options-general,admin_texts_rank-math-options-titles,essential-addons-for-elementor-lite,woodmart-core,sitepress-multilingual-cms,templately,essential-blocks,essential-addons-elementor,wpml,admin_texts_whb_main_header,action-scheduler,woo_ce,woocommerce-bookings,wp-content-copy-protector,wccp_pro_translation_slug,admin_texts_woocommerce_email_from_address,admin_texts_woocommerce_email_footer_text,admin_texts_woocommerce_email_from_name,jetpack-connection,admin_texts_whb_header_255353,wc-hide-shipping-methods,product-import-export-for-woo,wpml-page-builders,redirection,structured-content,woocommerce-wholesale-pricing,loco-translate,freemius,customer-reviews-woocommerce,ivole,facebook-for-woocommerce,litespeed-cache,admin_texts_woocommerce_shipping,woo-discount-rules,woo-discount-rules-pro,easy-woocommerce-discounts,advanced-dynamic-pricing-for-woocommerce,Third Item Discount,wcml-reviews,pys,product-catalog-feed-pro,social-connect-pys,pixel_cost_of_goods,edd-products-feed-pro,smart-opengraph,woocommerce-smart-prices,wordpress-feed-for-facebook-dynamic-ads,force-regenerate-thumbnails,wp-eddproducts-feed,acf,wpr-addons,woocommerce-points-and-rewards,wp-loyalty-rules,wll-loyalty-launcher,loco-auto-translate,twentytwentyfour,wordfence,perfmatters,rocket,twentytwentyfive,acfml,acf-field-group-35415,better-search-replace,string-locator,wp-file-manager,duplicator,instawp-connect,chaty,easy-wp-smtp,wpforms-lite,woogrow-compat-checker,hurrytimer,sales-countdown-timer,wp-reviews-plugin-for-google,google-listings-and-ads,advanced-coupons-for-woocommerce-free,advanced-coupons-for-woocommerce,woocommerce-jos-autocoupon,optin-monster-api,popup-maker,wpml-media-translation,wpml-media,woocommerce-pdf-invoices-packing-slips,wpo_wcpdf_templates,print-invoices-packing-slip-labels-for-woocommerce,admin_texts_woocommerce_email_header_image,admin_texts_Wf_Woocommerce_Packing_List,backup-backup,duplicator-pro,yith-plugin-fw,yith-live-chat,chatway,tidio-live-chat,wc-messaging,all-in-one-wp-migration-url-extension,autoupdate,media-cleaner,admin_texts_time_format,admin_texts_date_format,media-deduper,redis-cache,acf-field-group-group_689f5d8854f10,advanced-database-cleaner,envato-market,all-in-one-wp-migration-unlimited-extension,wp-seo-multilingual,contact-form-7-multilingual,drop_sitepress-multilingual-cms,pixelyoursite,WPML,w3-total-cache,shortpixel-image-optimiser,wp-all-import,wpai-woocommerce-add-on,under-construction-light,ucl-plugin,wt_woocommerce_invoice_addon,wt-woocommerce-shippinglabel-addon,wt-woocommerce-proforma-addon,wt-woocommerce-picklist-addon,wt-woocommerce-addresslabel-addon,wt-advanced-customizer-addon,wp-super-cache,health-check,wp-smushit,wp-nonstop-smushit,suretriggers,woo-order-export-lite,lwc-whatsapp-order,wpwoof,r2k-terms-copier,duplicate-post,wp-all-export,elementor-pro-activator,seo-by-rank-math,updraftplus,twentytwentyone","admin_text_3_2_migration_complete_07111a771582bd687bbac84fcc45ffa6":true,"admin_text_3_2_migration_complete_82a3256a1238298a53be6f85649c187a":true,"admin_text_3_2_migration_complete_0eb59941efabdc8d1ebaa170b5362376":true,"admin_text_3_2_migration_complete_109ce2ed0cb089695db15cc9dc025053":true,"admin_text_3_2_migration_complete_f77c405d1b1b42d2a2c53c61acada8d6":true,"taxonomies_unlocked_option":{"category":"0","post_tag":"0","wp_theme":"0","wp_template_part_area":"0","wp_pattern_category":"0","wpcode_type":"0","wpcode_location":"0","wpcode_tags":"0","elementor_library_type":"0","elementor_library_category":"0","cms_block_cat":"0","woodmart_slider":"0","project-cat":"1","product_brand":"0","product_type":"1","product_visibility":"0","product_cat":"1","product_tag":"0","product_shipping_class":"0","pa_cm":"0","pa_colors":"0","pa_size":"0","translation_priority":"1","elementor_font_type":"0","wd_popup_cat":"0","wd_floating_block_cat":"0","pos_product_visibility":"0","pa_strings":"0"},"custom_posts_unlocked_option":{"post":"0","page":"0","attachment":"0","custom_css":"0","customize_changeset":"0","oembed_cache":"0","user_request":"0","wp_block":"0","wp_template":"0","wp_template_part":"0","wp_global_styles":"0","wp_navigation":"0","wp_font_family":"0","wp_font_face":"0","wpcode":"0","e-floating-buttons":"0","elementor_library":"0","elementor_snippet":"0","woodmart_layout":"0","woodmart_woo_lv":"0","woodmart_woo_fbt":"0","cms_block":"0","woodmart_size_guide":"0","woodmart_slide":"0","portfolio":"0","product":"0","product_variation":"0","shop_order_refund":"0","shop_order_placehold":"0","wpcf7_contact_form":"0","templately_library":"0","mc4wp-form":"0","patterns_ai_data":"0","rm_content_editor":"0","rank_math_schema":"0","elementor_font":"0","elementor_icons":"0","woodmart_sidebar":"0","shop_coupon":"0","shop_order":"0"},"WPML_Translate_Link_Target_Global_State":false,"theme_language_folders":null,"admin_text_3_2_migration_complete_cecfb7e44d0d031a354f204fd9abb2c4":true,"just_reactivated":0,"admin_text_3_2_migration_complete_62caec036db7c6ae217a70d9b8f38ab2":true,"admin_text_3_2_migration_complete_c641a9216b624f8a2045a2a789c21226":true,"admin_text_3_2_migration_complete_7975eda60d5e8f730f87ed7bb49cbdf3":true,"admin_text_3_2_migration_complete_1ad3c67e1b9d7ba2fd5457012bc54ff6":true,"admin_text_3_2_migration_complete_dd691c866e1fc9aae29f57730fb2ae70":true,"admin_text_3_2_migration_complete_e5e08d0a71412ed2bf475aaf8c2a1e03":true,"admin_text_3_2_migration_complete_994afe8ddb5e9e0e487b019c48cbaf89":true,"admin_text_3_2_migration_complete_f7b2e4da1e602f9d850e4fe46d2f25e7":true,"admin_text_3_2_migration_complete_cd9e20ebe7d005a1dcd1fd3d140e043c":true,"show_translations_flag":0},"installer":{"version":"3.1.14","repositories":{"wpml":{"api-url":"https:\/\/api.wpml.org\/","bucket-url":"not assigned","subscription":{"key":"d43b40c4df","key_type":0,"data":{"subscription_type":6719,"expires":"2027-05-13","status":"1","notes":"","order_id":"18033768","hasAutoRenewal":true},"registered_by":2,"site_url":"https:\/\/wahageg.com"},"last-successful-subscription-fetch":"2026-05-14 09:02:27"},"toolset":{"api-url":"https:\/\/api.toolset.com\/","bucket-url":"not assigned","subscription":"","last-successful-subscription-fetch":"none"}},"instances":{"\/home\/wahageg\/public_html\/wp-content\/plugins\/sitepress-multilingual-cms\/vendor\/otgs\/installer\/installer.php":{"bootfile":"\/home\/wahageg\/public_html\/wp-content\/plugins\/sitepress-multilingual-cms\/vendor\/otgs\/installer\/installer.php","version":"3.1.14","args":{"plugins_install_tab":1,"site_key_nags":[{"repository_id":"wpml","product_name":"WPML","condition_cb":[{"wpdb":{"show_errors":false,"suppress_errors":false,"last_error":"","num_queries":322,"num_rows":0,"rows_affected":0,"insert_id":0,"last_query":"UPDATE `IP9gTaU7_options` SET `option_value` = \u00271\u0027 WHERE `option_name` = \u0027_transient_wpml_rest_api_status\u0027","last_result":[],"queries":null,"prefix":"IP9gTaU7_","base_prefix":"IP9gTaU7_","ready":true,"blogid":0,"siteid":0,"tables":["posts","comments","links","options","postmeta","terms","term_taxonomy","term_relationships","termmeta","commentmeta","woocommerce_payment_tokenmeta","woocommerce_order_itemmeta","wc_product_meta_lookup","wc_tax_rate_classes","wc_reserved_stock","woodmart_unsubscribed_emails","actionscheduler_actions","actionscheduler_claims","actionscheduler_groups","actionscheduler_logs"],"old_tables":["categories","post2cat","link2cat"],"global_tables":["users","usermeta"],"ms_global_tables":["blogs","blogmeta","signups","site","sitemeta","registration_log"],"old_ms_global_tables":["sitecategories"],"comments":"IP9gTaU7_comments","commentmeta":"IP9gTaU7_commentmeta","links":"IP9gTaU7_links","options":"IP9gTaU7_options","postmeta":"IP9gTaU7_postmeta","posts":"IP9gTaU7_posts","terms":"IP9gTaU7_terms","term_relationships":"IP9gTaU7_term_relationships","term_taxonomy":"IP9gTaU7_term_taxonomy","termmeta":"IP9gTaU7_termmeta","usermeta":"IP9gTaU7_usermeta","users":"IP9gTaU7_users","blogs":null,"blogmeta":null,"registration_log":null,"signups":null,"site":null,"sitecategories":null,"sitemeta":null,"field_types":{"post_author":"%d","post_parent":"%d","menu_order":"%d","term_id":"%d","term_group":"%d","term_taxonomy_id":"%d","parent":"%d","count":"%d","object_id":"%d","term_order":"%d","ID":"%d","comment_ID":"%d","comment_post_ID":"%d","comment_parent":"%d","user_id":"%d","link_id":"%d","link_owner":"%d","link_rating":"%d","option_id":"%d","blog_id":"%d","meta_id":"%d","post_id":"%d","user_status":"%d","umeta_id":"%d","comment_karma":"%d","comment_count":"%d","active":"%d","cat_id":"%d","deleted":"%d","lang_id":"%d","mature":"%d","public":"%d","site_id":"%d","spam":"%d"},"charset":"utf8mb4","collate":"utf8mb4_unicode_520_ci","func_call":"$db-\u003Equery(\u0022UPDATE `IP9gTaU7_options` SET `option_value` = \u00271\u0027 WHERE `option_name` = \u0027_transient_wpml_rest_api_status\u0027\u0022)","is_mysql":true,"time_start":null,"error":null,"categories":"IP9gTaU7_categories","post2cat":"IP9gTaU7_post2cat","link2cat":"IP9gTaU7_link2cat","payment_tokenmeta":"IP9gTaU7_woocommerce_payment_tokenmeta","order_itemmeta":"IP9gTaU7_woocommerce_order_itemmeta","wc_product_meta_lookup":"IP9gTaU7_wc_product_meta_lookup","wc_tax_rate_classes":"IP9gTaU7_wc_tax_rate_classes","wc_reserved_stock":"IP9gTaU7_wc_reserved_stock","woodmart_products_table":"IP9gTaU7_woodmart_wishlist_products","woodmart_wishlists_table":"IP9gTaU7_woodmart_wishlists","wd_unsubscribed_emails":"IP9gTaU7_woodmart_unsubscribed_emails","actionscheduler_actions":"IP9gTaU7_actionscheduler_actions","actionscheduler_claims":"IP9gTaU7_actionscheduler_claims","actionscheduler_groups":"IP9gTaU7_actionscheduler_groups","actionscheduler_logs":"IP9gTaU7_actionscheduler_logs"},"locale_utils":{},"footer_preview":false,"icl_translations_cache":null,"icl_language_name_cache":{},"icl_term_taxonomy_cache":null,"ROOT_URL_PAGE_ID":null},"setup"]}]},"delegated":true},"\/home\/wahageg\/public_html\/wp-content\/plugins\/woocommerce-multilingual-old\/vendor\/otgs\/installer\/installer.php":{"bootfile":"\/home\/wahageg\/public_html\/wp-content\/plugins\/woocommerce-multilingual-old\/vendor\/otgs\/installer\/installer.php","version":"3.1.14","args":{"plugins_install_tab":1},"delegated":false}}}}}
