Last updated by Subash Chandra Poudel 1 year, 11 months ago.
June 30, 2023 at 5:55 pm #13925387
contatoJ
Hello!
The other problem is that I use WP Job Openings and on the translated pages the application shortcode is not working, it shows that there are no jobs available, whereas the job pages themselves were translated successfully.
June 30, 2023 at 6:09 pm #13925407
Please note that we try to handle only one issue per ticket so as to keep better track of issues. So I split your original ticket ( https://wpml.org/forums/topic/elementor-header-footer-builder-wpml/ ) into this one to work on the WP Job Openings issue.
So regarding the issue with WP Job Openings , please note that "WP Job Openings" plugin is not in our list of compatible plugins at https://wpml.org/plugin/ so there could be some issues.
However this does not necessarily means the plugin is incompatible with WPML. I recommend you to contact the plugin provider and ask them if the plugin is supposed to work with WPML and/or if they can fix the issue from their end and also ask them to join our Go Global Program linked next so that we can work with them to make the plugin compatible with WPML:
https://wpml.org/documentation/support/go-global-program/
Furthermore, I can also take a look at the plugin setup and see if this could be fixed with some setup of workaround. So, I setup a sandbox site for you which you can login to using the next link:
Can you please login to the site, setup WPML and your plugin and add some dummy/test data on the site so as to replicate the issue and let me know where exactly can I see the issue?
Please use as less data and setup as possible on the sandbox site so that it is kept minimal and we can troubleshoot the issue faster.
The topic ‘[Closed] Split: Elementor Header & Footer Builder – WPML’ is closed to new replies.
