If you're using the Xstore header builder and cannot find specific strings such as "Contact Us On WhatsApp" in WPML's String Translation.
We recommend adding these strings for translation through the following steps:
1. Navigate to WPML > String Translation.
2. Click on 'Not seeing strings that you are looking for?'.
3. Select the 'Admin text' option.
After performing these steps, the strings should be available for translation.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
This topic is split from https://wpml.org/forums/topic/translations-not-updating-on-login-registration-and-cart-pages/
Last updated by 2 months, 3 weeks ago.
Assisted by: Dražen.
