This topic is split from https://wpml.org/forums/topic/we-need-a-way-to-translate-custom-product-attribute-names-imported-via-wpml-tools-without-using-str/
| - | 8:00 – 12:00 | 8:00 – 12:00 | 8:00 – 12:00 | 8:00 – 12:00 | 8:00 – 12:00 | - |
| - | 13:00 – 17:00 | 13:00 – 17:00 | 13:00 – 17:00 | 13:00 – 17:00 | 13:00 – 17:00 | - |
Supporter timezone: Europe/Vienna (GMT+01:00)
This topic contains 16 replies, has 0 voices.
Last updated by Lucas Vidal de Andrade 8 months, 3 weeks ago.
| Author | Posts |
| June 5, 2025 at 1:32 pm #17110423 | |
peterJ-48 |
Hello, Issue: What we’ve done so far: CSV File Path: For access to my site, please refer to this thread: As per your suggestion, we still need to test the custom attribute translation. Once the import process is fixed, we’ll then proceed to test the custom attributes in the secondary languages. Can you help me understand why we were unable to import products using the WPML import/export plugin? |
| June 5, 2025 at 1:34 pm #17110433 | |
Lucas Vidal de Andrade WPML Supporter since 11/2023
Languages: English (English ) Spanish (Español ) German (Deutsch ) Portuguese (Brazil) (Português ) Timezone: Europe/Vienna (GMT+01:00) |
Hello, I tried again today to access the staging version, but this time it's not even rendering. I checked the latest backup you shared, and tested importing a product with all plugins activated, and also with only WPML plugins + WooCommerce activated. The importing process worked fine on both scenarios. Can you please restore the staging version, and make sure that it is usable? Another option is for you to send a fresh copy, where the issue is happening. Please let me know how you wish to proceed. |
| June 6, 2025 at 6:47 am #17112930 | |
peterJ-48 |
Hello, The staging server is now stable, so you can access it. I’ve also shared the database file in case you want to test it locally: hidden link. We encountered an issue during the import process when the WPML Import/Export plugin is enabled. The import gets stuck specifically with variable products — simple products are working fine. Upon debugging, we found that the function removeProductsBySkuMeta() is causing the issue. If we comment out or disable the line: "$product->delete(true);" then we're able to import variable products successfully. Please see the screenshot for a reference to the plugin code: hidden link |
| June 6, 2025 at 5:36 pm #17114779 | |
Hey there, I'm checking what's the best way to proceed here, along with the 2nd tier team. I'll get back to you once we have new information or questions. Thank you for your patience. |
| June 9, 2025 at 7:44 am #17117251 | |
Christopher Amirian WPML Supporter since 07/2020
Languages: English (English ) Timezone: Asia/Yerevan (GMT+04:00) |
Hi Peter, This is Christopher. I just wanted to inform you that the staging website is still giving us a hard time to test the issue. We constantly get either 502 errors or simply no response and it limits our abilities to test the CSV file import. Lucas will get back to you with more details, but I wanted to interject here sooner so you can double-check the staging website to move this one forward. One more point is that we tested the same CSV file on another website and the process completed with no issues. So this is an isolated case on your website that we want to investigate. Thank you very much. |
| June 9, 2025 at 1:29 pm #17118605 | |
Hello there, After a couple of tries, I was finally able to download the DB package you shared. In my local copy, though, I couldn't reproduce the issue. Please check the video: In this copy, I didn't deactivate any plugins and used the file you provided - I just changes the product name and SKU. Is the issue still happening on the website? Are you performing any different steps than the ones I showed in the video? |
| June 10, 2025 at 6:27 am #17120291 | |
peterJ-48 |
Hello, Thanks for checking and sharing the video! Apologies for the confusion. It looks like we may have sent you an outdated database, which is likely why the products were imported successfully on your end. Here’s the latest database file we’re using: We’ve also recorded a video to demonstrate exactly what we’re seeing on our end: hidden link As shown in the video, we only changed the SKU and product title and tried importing the same file. However, the products didn’t import and the process got stuck in an infinite loop. Could you please review the steps in our video and let us know if there’s anything else we should try or any differences you notice? Looking forward to your insights. |
| June 10, 2025 at 2:47 pm #17122449 | |
Hello there, The steps you're following seem to be correct. I downloaded the latest DB file you shared, updated the local copy, but couldn't reproduce the issue. The import process worked flawlessly. In this case, I'd need to check a working staging version where the issue is reproduced. You can also check for conflicts yourself, keeping WPML Export and Import activates and disabling other plugins and your theme. Let me know how you wish to proceed. |
| June 12, 2025 at 11:34 am #17129828 | |
peterJ-48 |
Hello, I downloaded the latest DB file you shared, updated the local copy, but couldn't reproduce the issue. The import process worked flawlessly. Also, please remember that when the WPML Import/Export plugin is enabled, the product import process fails. So make sure this plugin is also enabled during your testing. |
| June 12, 2025 at 5:55 pm #17131129 | |
Hello there, I tested again, and: 1. Made sure that all 155 tables were imported; No issues. Please check the video for confirmation: Are you able to provide a working staging version, where the issue is reproduced? |
| June 13, 2025 at 10:29 am #17132838 | |
peterJ-48 |
Hello, We tested the same database locally, and the product import works fine when the WPML Export and Import plugin is enabled. However, the import process gets stuck when using it on live environments such as staging, dev, or new servers. We observed that the product import works as expected with the old database, but fails when using the latest database on the server. After comparing both databases, we found a difference in the _wcml_settings entry in the options table. We copied the value from the old database and updated it in the latest one (under option_name = _wcml_settings), but that didn’t resolve the issue. Specifically, the value of "sync_product_cat" differs between the two databases (0 in the old one and 1 in the new one). Here’s the serialized data from the old database: This is serialize key for new table: Are you able to provide a working staging version, where the issue is reproduced? |
| June 13, 2025 at 7:24 pm #17134645 | |
Hey there, The staging website is unusable. Let me share what I've done so far, when accessing it: 1. I was able to import the variable product, with WPML Export and Import active, with no issues, though very slowly (the process took over 10 minutes); It's very likely that the issue is related to performance and not to WPML Export and Import (as I said, I was able to import a variable product with it active, though I couldn't record it), but we can't confirm, since the website is unusable. If possible, please provide a working staging version with only WPML, WPML String Translation, WooCommerce, WooCommerce Multilingual and Multicurrency and WPML Export and Import active (that's what I wanted to test when I encountered the fatal error). |
| June 16, 2025 at 6:45 am #17137088 | |
peterJ-48 |
Hello, Previously, we performed this exercise on the staging server by enabling only the WPML and WooCommerce plugins, deactivating all other plugins, and switching to the default WordPress theme. However, we were unable to import products. Currently, with the following plugins activated — WPML, WPML String Translation, WooCommerce, WooCommerce Multilingual & Multicurrency, and WPML Export and Import — the product import is working correctly on the staging server. Could you please confirm if any changes were made to the code, ATE, or database? If so, kindly let us know, as we need to test the same process on the staging server before applying it to the production server. I’ll continue investigating further and will get back to you with any findings. |
| June 16, 2025 at 7:33 am #17137239 | |
Hi Christopher here is answering as Lucas is off today. We do not have any changes to force a successful import. We did test whatever given to us and it worked as Lucas mentioned. Please get back to us with your findings. Thanks. |
| June 16, 2025 at 12:15 pm #17138558 | |
peterJ-48 |
Hello, We are currently using the WPML and WCFM plugins. To troubleshoot an issue, we deactivated all plugins and then activated only the following updated plugins: - WPML - WPML String Translation - WooCommerce - WooCommerce Multilingual & Multicurrency - WPML Export and Import - WCFM – WooCommerce Frontend Manager - WCFM – WooCommerce Multivendor Marketplace We also switched to the default WordPress theme. We attempted to import products in English only but were unable to complete the import successfully. Then, we deactivated the WPML Export and Import plugin and were able to import products without any issues. Next, we reactivated the WPML Export and Import plugin and deactivated the WCFM – WooCommerce Multivendor Marketplace plugin — and again, the product import worked correctly. This suggests a compatibility issue between the WPML Export and Import plugin and the WCFM – WooCommerce Multivendor Marketplace plugin. When both plugins are active, we are unable to import products. However, when either one is deactivated, the import process works as expected. Can you please investigate why the product import fails when both plugins (WPML Export and Import and WCFM – WooCommerce Multivendor Marketplace) are active? For site access, please refer to this thread: Note: Please use wp-admin for login access, as the plugin that changes the login URL has been deactivated. Additional Note: When comparing performance, we observed that enabling the WPML Export and Import plugin significantly increases the product import time compared to when the plugin is deactivated. |
The topic ‘[Closed] Split: Import won't work when WPML Export and Import is active’ is closed to new replies.
