The client reported that some links were not being transferred to the translated pages. Specifically, certain links that should have been present and bold were missing entirely, and attempts to add these links using various methods were unsuccessful.
We recommended the following steps to address the issue:
1. Ensure to create a backup of the site before making any changes.
2. Disable all plugins except for WPML and Elementor.
3. On the default language page, switch to the text editor (not visual), cut all the text, paste it back, and then save the page.
4. Attempt to re-translate the page.
These steps helped resolve the issue locally in our tests. If the problem persists, we suggest trying to reproduce the issue on a test site and provide us with the steps, so we can investigate further.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue continues, please open a new support ticket at WPML support forum.
Last updated by chazE 6 months, 2 weeks ago.
Assisted by: Dražen.
January 14, 2025 at 7:44 am #16591435
chazE
Anyway, a slightly related issue I'm left with now is some links not being transferred at all to the translated pages - as in not even wrongly linking to original pages. The links are just not there. They're on this page: hidden link
Lesiones en trampolines, Lesiones laborales, Muerte por negligencia - these should have links. They're not even bold like on the original page (but they become bold if I remove the link). Adding the link back just makes the text weight regular and nothing more (it doesn't matter if I use dynamic links or not, that's never helped with anything).
I was able to add one or two links by just repeatedly making slight edits to the original text, either to the link itself or the paragraph it's in and there was no discernible pattern that always worked. It's all very random. Those last 3 links I just wasn't able to add whatever I tried and however many times I tried it. Hope you can help with this.
January 14, 2025 at 7:48 am #16591440
Dražen
please share the access details of your website, so I can log in and take a look.
I’m enabling a private message for the following reply.
We have strict policies regarding privacy and access to your information.
Please see:
- Please backup the site files and database before providing us access.
- If you have a staging site where the problem can be reproduced, it is better to share access to the staging site.
Drazen
January 15, 2025 at 11:48 am #16596943
chazE
Unfortunately I can't give you access to the site.
Judging by all the numerous issues I've seen people have with WPML, I'm certain you've heard people having this issue before.
Do you have any ideas about what else I can try? It copied over all the links on the page and translated them except for those 3 that it won't even copy over, no matter how many times I remove them -> publish -> add them -> publish again. Doesn't matter how I add them either (internal links vs. /page-slug/).
I've wasted a lot of credits trying to get those links fixed, hope I won't need to waste any more.
January 15, 2025 at 12:00 pm #16596958
chazE
What happens if I directly edit the ES pages and manually add those links?
January 15, 2025 at 12:01 pm #16596959
Dražen
I am afraid it is difficult for me to say this, can be many things. If the pages are translated and you are adding the correct translated links, it should work fine.
If you can share access to the staging site or provide a copy of the website that would be helpful so I can have a look and investigate what went wrong.
- https://wpml.org/fr/faq/provide-supporters-copy-site/
Drazen
January 16, 2025 at 7:37 am #16599961
Dražen
my reply was general about your question if I can suggest or know what was causing it.
Yes, if you do manual edits they will overwritten, unless you switch to Worpdress editor and continue to add changes manually.
- https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/
I will take the copy you shared and check further, and update you when I have some news.
Drazen
January 16, 2025 at 2:00 pm #16602374
Dražen
thanks for your patience.
I have checked your website and could see the issue, I have also tried to reproduce it on Sandbox but there it works fine.
So this is what have I done locally and it seems to work and translate fine:
- Please make sure to create a backup, before doing any actions, just in case.
- Disable all other plugins and leave active only WPML plugins and Elementor
- Go to the default language page and edit this section, in the text editor select text view, not visual, and "cut" all the text, paste it again, and save the page
- Re-translate and it should work fine, at least for what I have tried.
I am not sure what could have caused it but maybe it was the way the page were saved or something was blocking it first it was saved.
If you can provide steps to reproduce it again or try to reproduce it on the test site I can escalate further for check. Otherwise please try the suggested steps and let me know if that works.
Clean website to reproduce issue:
- hidden link
Drazen
January 16, 2025 at 5:38 pm #16603291
chazE
I fixed those links by adding them using the text editor instead of the visual editor.
The code was identical to all the other links that transferred over fine. Really wish you'd forward this issue to someone on the dev team so they can look into it.
