The client's footer is not translated and does not appear in the strings.
If you're experiencing this issue and you used Divi to create your footer, we recommend you refer to the following articles for instructions on translating the Global Footer:
If you have already completed the translation but it is not displaying correctly on the front end of your site, please try the workaround mentioned in this errata: Divi Global Footer Translation Issue, and see if that resolves your issue.
This solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
Last updated by Andrey 1 year, 1 month ago.
Assisted by: Andrey.
March 20, 2025 at 1:03 pm #16840141
digitalG-2
My footer is a not translated and does not appear in the strings, how do I add this to the strings.
March 20, 2025 at 1:11 pm #16840152
Andrey
WPML Supporter since 06/2013
Please provide more details on how you created your footer.
If you used Divi to create your footer, please refer to this article for instructions on translating the Global Footer:
https://wpml.org/documentation/theme-compatibility/divi-builder/#translating-custom-global-header-footer
If you have already completed the translation but it is not displaying correctly on the front end of your site, please try the workaround mentioned in this errata: https://wpml.org/errata/divi-global-footer-translation-is-not-displayed-upon-changing-the-default-language/, and see if that resolves your issue.
I hope this helps.
