If you're experiencing issues with your checkout not translating or adjusting properly,
We recommend checking if you're facing a known issue related to WooCommerce Multilingual where cart page strings are not translated when using blocks. You can find more details and a possible workaround by visiting the following link: WooCommerce Multilingual cart page strings not translated when using blocks.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket at WPML support forum.
Last updated by Andrey 3 months, 1 week ago.
Assisted by: Andrey.
July 28, 2025 at 3:50 pm #17276174
kevind-34
Right now our checkout is not translating, it's just not adjusting, what can we do?
July 28, 2025 at 3:53 pm #17276176
Andrey
WPML Supporter since 06/2013
You might be experiencing the following known issue:
https://wpml.org/errata/woocommerce-multilingual-cart-page-strings-not-translated-when-using-blocks/
Please review the article for more details and a possible workaround.
