Last updated by Marsel Nikolli 10 months, 1 week ago.
Assisted by: Marsel Nikolli.
July 30, 2024 at 8:11 am #16019084
markusP-25
Hi Marsel!
Great, thanks for the quick service. It worked and I'll remember it. Unfortunately, I have to bother you again. The following problems:
1)
on the "agency" page in the default language English, the 4 "listings" offered are displayed on this page:
on the translated page (German), these 4 "listings" are not displayed, even though I have already translated these 4 listings into German:
On the "agent" page in English, you can click on the agency hyperlink and get to the agency:
You cannot click on this link in German, although I have already translated the agency page into German:
thank you for your time and support.
July 30, 2024 at 8:28 am #16019166
Marsel Nikolli
We will continue troubleshooting the question #1 on this ticket.
Can you please tell me if there is a specific reason why you are using the Classic Translation Editor (please check the attached image)? If not can you please switch to the Advanced Translation Editor, and try making a small change in one of the properties in the default language (ex. add a "+" sign to the title and remove it again) and check if the issue persists.
Let me know how it goes,
Marsel
July 30, 2024 at 8:56 am #16019455
markusP-25
Hi!
I used the classic editor because I didn't have to translate every paragraph of the property description. But I will use the advanced editor from now on if it is safer. Regarding your solution. I tried it as you indicated: Advanced Translation Editor - small change in one of the property in default language. I also revised the German description again using the advanced editor. Unfortunately, the problem was not solved.
Please note. The page is not live and a backup was made 20 minutes ago. You are welcome to try out what you need on your own. You still have access from yesterday's ticket. Thanks for your support in advance.
July 30, 2024 at 11:17 am #16020111
Marsel Nikolli
Thank you for the update.
Could you please update all the plugins that require updating, after clear the website's cache (server-side included) and check if the issue persists?
