The client is experiencing an issue where sub-taxonomies are not displaying in an Elementor widget. This widget is part of the Havezic theme, which has not been tested or made compatible with WPML.
We recommend contacting the theme author to request adjustments in the code to correctly fetch translated taxonomies. If the theme author is willing to make their theme compatible with WPML, they can join our GoGlobal program. We are ready to collaborate and provide assistance once the theme author agrees to work with us.
If this solution does not apply to your case, or if it seems outdated, please check our related known issues, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. We highly recommend opening a new support ticket if further assistance is needed. You can do so at our support forum.
This topic is split from https://wpml.org/forums/topic/taxonomies-is-not-translating/
This topic contains 17 replies, has 0 voices.
Last updated by 1 year, 1 month ago.
Assisted by: Dražen.
