The Translation management page won't load, showing an infinite wait.
If you're experiencing this issue, we recommend you try the following steps after ensuring a full backup of your site:
1. Deactivate all plugins that are not related to WPML.
2. Temporarily switch to a default WordPress theme, such as Twenty Twenty-One.
3. Check if the issue is resolved. If it is, reactivate the plugins one by one to identify which one is causing the interaction issue.
If the problem still persists, please enable debug mode in WordPress by adding the following code to your wp-config.php file:
// Enable WP_DEBUG mode define( 'WP_DEBUG', true ); // Enable Debug logging to the /wp-content/debug.log file define( 'WP_DEBUG_LOG', true ); // Disable display of errors and warnings define( 'WP_DEBUG_DISPLAY', false );
After adding the code above, try reproducing the issue again and check for a debug.log file in the wp-content folder. If you find it, kindly share the last lines here in the ticket.
This solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket.
This topic is split from https://wpml.org/forums/topic/suppressing-url-translations/
Last updated by 2 months, 2 weeks ago.
Assisted by: Andrey.
