Last updated by Bigul 4 months, 2 weeks ago.
Assisted by: Bigul.
July 31, 2025 at 7:14 pm #17286499
alinam-2
Fatal errors while translating the posts.
[proxy_fcgi:error [pid 1851519:tid 1851635 [client XXXXXX:0 AH01071: Got error 'PHP message: PHP Notice: Function _load_textdomain_just_in_time was called incorrectly. Translation loading............a> for more information. (This message was added in version 6.7.0.) in /home/1164702.cloudwaysapps.com/vjgpsqycrh/public_html/wp-includes/functions.php on line 6121', referer: hidden link
parse_str(): Input variables exceeded 2500. To increase the limit, change max_input_vars in php.ini. in /home/1164702.cloudwaysapps.com/vjgpsqycrh/public_html/wp-content/plugins/sitepress-multilingual-cms/classes/editor/ClassicEditorActions.php on line 20
PHP Warning: Undefined array key 6841817 in /home/1164702.cloudwaysapps.com/vjgpsqycrh/public_html/wp-content/plugins/sitepress-multilingual-cms/addons/wpml-page-builders/classes/Shared/tm/class-wpml-tm-page-builders-field-wrapper.php on line 121
Kind regards
Alina
August 4, 2025 at 5:26 am #17291731
Bigul
Hi Alina,
Welcome to the WPML support forum. I will do my best to assist you in resolving the issue.
I have created a separate ticket for this case to make follow-ups easier and to avoid discussing multiple topics in a single thread. This will help us support you more effectively.
Please check the attached image. I encountered this error multiple times today while reviewing posts, products, and site settings.
We are using a similar staging setup on Cloudways and have experienced a similar issue there as well. So, just to confirm, are you seeing the same conflict on the live site?
It would be very helpful if you could share the SFTP credentials for your staging site, as this will assist us in troubleshooting the fatal error more effectively.
I have enabled the Private Reply option for your next response to securely share the details.
Bigul
August 4, 2025 at 6:44 pm #17294503
alinam-2
I got this error on my site, not the staging, you are working on stating, I don't
Kind regards
August 5, 2025 at 4:03 pm #17297324
Bigul
Hi Alina,
Thank you for the confirmation. We will debug it further and get back to you as soon as possible. Please wait.
Bigul
August 6, 2025 at 4:06 pm #17300415
alinam-2
OK.
Please, consider what I wrote.
WPML html copy is not working
Kind regards
Alina
August 7, 2025 at 5:53 pm #17303596
Bigul
Hi Alina,
Thank you for the updates. We are currently trying to reproduce the issue on our local copy and will get back to you as soon as possible. Please wait.
Bigul
August 7, 2025 at 6:29 pm #17303722
alinam-2
I do wait
August 12, 2025 at 5:23 am #17311807
alinam-2
and wait
August 13, 2025 at 12:58 pm #17317569
Bigul
Hi Alina,
I have conducted detailed testing on our local copy, which involved creating posts, translating them, updating both the posts and their translations, and duplicating the posts along with their translations. However, I was not able to reproduce the following warnings.
I also tested this on your staging site, but was not able to reproduce the issue exactly. According to the debug.log file, these warnings have not been recorded since the last week of July.
It appears that upgrading to the latest plugin and theme versions, along with increasing the PHP configuration values, has helped resolve the warnings.
Therefore, could you please check if the issue still occurs on your side? If it does, kindly share the exact steps to reproduce it.
Thank you for your understanding and cooperation.
Bigul
August 13, 2025 at 6:58 pm #17319088
Bigul
Hi Alina,
An update. I was able to reproduce the following warning while updating and translating old posts on your staging site. It appears that the issue does not occur with new posts.
HP Warning:  Undefined array key 6870369 in /***/public_html/wp-content/plugins/sitepress-multilingual-cms/addons/wpml-page-builders/classes/Shared/tm/class-wpml-tm-page-builders-field-wrapper.php on line 121
I will run further tests and get back to you as soon as possible. Please wait.
Bigul
