This topic contains 32 replies, has 2 voices.
Last updated by Dražen 1 year, 10 months ago.
Assisted by: Dražen.
September 11, 2023 at 9:39 am #14374349 | |
lobkeB |
Dear Drazen, I am sorry for not getting this done quickly. Best regards, Lobke |
September 11, 2023 at 10:41 am #14375119 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello Lobke, sure, let me know when the website is ready. Regards, |
September 11, 2023 at 1:11 pm #14376607 | |
lobkeB |
Dear Drazen, The following issue is solved: Unfortunately I can not activate the plugin 'WPML Multilingual CMS'. I don't know why... I think you can now access the beta without a problem. If not, please let me know. Best regards, Lobke |
September 11, 2023 at 1:11 pm #14376611 | |
Dražen Supporter
Hello, I have checked your staging site and I still see a different email than the one on the production site. It is not same website / issue as on your live website. Let me know if you are able to create the latest staging site, if not, it is okay for me to take a copy of your production website and disable some plugins on the live production website to check the issue. Thanks, |
September 11, 2023 at 1:22 pm #14376635 | |
lobkeB |
on this page you see 'review reminder' and 'review for discount'. So: and beta.heatperformance.nl/wp-admin/admin.php?page=cr-reviews-settings&tab=emails§ion=review_reminder They are exactly the same.. Best regards, Lobke |
September 12, 2023 at 6:32 am #14380409 | |
Dražen Supporter
Hello Lobke, you are right, I apologize I was confused with 2 different emails in settings. I have checked your live website and run WPML Troubleshooting tools to re-generate new MO files for string translation, and it seems it works fine now. Image attached. Please check. Regards, |
September 12, 2023 at 7:34 am #14380717 | |
lobkeB |
Dear Drazen, I see you tested the Dutch email. Indeed, the dutch email works fine. But the Swiss and Belgian email not. Maybe you can test again and choose for the Swiss flag? Best regards, Lobke |
September 12, 2023 at 9:46 am #14382271 | |
Dražen Supporter
Hello, thanks for getting back and for your help and patience on this. I was able to check and confirm the issue happens only when using domain per language mode, it works fine otherwise. I am not 100% sure if this is a bug or not expected environment since we do not recommend using uppercase language code, and usually, this is not allowed when you try to add custom language. Or is this some bug with language per domain mode. Anyway, I have escalated this case to our 2nd tier to further check and advise. I will update you soon. Regards, |
September 12, 2023 at 10:45 am #14382835 | |
lobkeB |
Ok, I will wait patiently! |
September 13, 2023 at 11:21 am #14389697 | |
Dražen Supporter
Hello, we are trying to access your beta website to further check the issue, but seems the login is not working anymore for us. Can you please allow us access again, so we can continue to check. Thank you. |
September 13, 2023 at 12:06 pm #14390035 | |
lobkeB |
Dear Drazen, Beta.heatperformance.nl is again available for you with your pasword. Best regards, Lobke |
September 13, 2023 at 12:14 pm #14390117 | |
Dražen Supporter
Hello Lobke, yes, it is easier to debug without all not needed plugins, and in this case we need to keep them disabled. Please do not remove or change the beta website until we have finished debugging. Thank you, |
September 13, 2023 at 1:56 pm #14390705 | |
lobkeB |
Dear Drazen, Please allow me to activate the Password Protection Plugin (password is 'bekijken') and the Wordfence plugin in order to protect the website. I don't want anything to happen. Feel free the deactivate these plugins for a short period of time if needed. Best regards, Lobke Buijs |
September 14, 2023 at 5:59 am #14393393 | |
Dražen Supporter
Hello, okay, thanks. We will update you when we have some news. Regards, |
September 15, 2023 at 6:10 am #14400659 | |
Dražen Supporter
Hello, thanks for your patience. We found an issue, please find more details and fix bellow. Please also contact the plugin author and report this back to them, so they can include the fix in new versions. Go to: \wp-content\plugins\customer-reviews-woocommerce\templates\email.php In: - //WPML and Polylang integration if ( has_filter( 'wpml_translate_single_string' ) && defined( 'ICL_LANGUAGE_CODE' ) && ICL_LANGUAGE_CODE && !function_exists( 'pll_current_language' ) && $ivole_language === 'WPML' ) { $wpml_current_language = strtolower( $lang ); Change $wpml_current_language = strtolower( $lang ); to: $wpml_current_language = ( $lang ); Regards, |
