The client was unable to translate a string on their website, and some methods were deprecated in the admin interface. The main issue was that the English header was not displaying correctly, showing a Persian header instead.
We identified that the issue was related to the use of a legacy widget that was no longer compatible. To resolve this, we guided the client to make corrections in the widget settings. We provided a direct link to the widget settings page and instructed the client to adjust the widget language each time edits were made. After making these adjustments, the issue with the string translation was resolved.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Kor 1 month, 3 weeks ago.
November 12, 2024 at 10:50 pm #16394779
sinohehE
I am trying to translate a string on my website. The issue can be seen on this page: hidden link
String translation is not working, and some methods are deprecated in the admin interface. I expected to see an English header, but instead, I got a Persian header, which is the default language.
Why is the string translation not working?
Why methods are deprecated in the admin interface? (php 8.3)
November 13, 2024 at 2:45 pm #16398157
Thanks for contacting us.
November 13, 2024 at 6:56 pm #16399269
Thanks for your reply.
I don't see any issues as shown in the attached screenshot. Did you sort it out yourself?
November 13, 2024 at 7:01 pm #16399287
sinohehE
Top widgets are in Persian, and also all strings are not available in translation sections
November 13, 2024 at 7:03 pm #16399302
sinohehE
Ahh, do you meant the errors?
After update to the latest plugin version they were gone
November 14, 2024 at 10:03 am #16401501
sinohehE
I could fix some of them by searching in admin string but two of them not working
November 14, 2024 at 2:23 pm #16403376
Thanks for your reply. I'm checking now .
November 14, 2024 at 3:08 pm #16403571
Looks like these "Legacy widget" are not working correctly even after using the "Creating Widgets in Each Language" as explained here https://wpml.org/documentation/getting-started-guide/translating-widgets/#using-different-widgets-for-different-languages and I will have to troubleshoot this further.
I regret any inconvenience caused, but to proceed with troubleshooting, I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
November 15, 2024 at 11:16 am #16407731
It looks like you did not upload the correct zip file. It is only 700bytes as it should be around 300++mb . Could you recheck and share the correct file with me?
November 15, 2024 at 11:24 am #16407762
sinohehE
I did by mistake,
Would you mind to download it directly form the admin panel?
November 15, 2024 at 11:28 am #16407783
I tried, but it says the file does not exist. I installed the duplicator pro and will see if I can download it.
November 15, 2024 at 11:29 am #16407833
sinohehE
I would appreciate your time and effort,
You should be able to download from the FTP as well
November 15, 2024 at 2:55 pm #16409003
sinohehE
FYI
My site get hacked (wasn’t important)
I can’t assume it was a reason but I guess it’s better you be aware of it
November 15, 2024 at 5:58 pm #16409504
Thanks for your reply. You can ignore that. I will remove that duplicator pro plugin now. I will check and revert
November 15, 2024 at 6:36 pm #16409523
Thanks for your reply. Could you please check now? I've fixed the issue for you.
