This topic contains 16 replies, has 3 voices.
Last updated by Vitomir Ognjanovic 3 years, 3 months ago.
Assisted by: Bruno Kos.
April 1, 2022 at 8:28 am #10927055 | |
Vitomir Ognjanovic |
Hi, As I said in the subject, if I turn off Auto register strings for translation, strings show untranslated, and if I enable it everything works fine...for 2 hours. |
April 1, 2022 at 11:39 am #10928901 | |
Laura WPML Supporter since 05/2018
Languages: English (English ) Italian (Italiano ) Timezone: Europe/Rome (GMT+02:00) |
Hi, thanks for contacting us. But you don't see any string translated, or it happens only for specific strings? If so, from which plugin the strings come from? |
April 1, 2022 at 11:48 am #10929077 | |
No strings translated until I turn on Auto register strings for translation. All strings are from theme. |
April 4, 2022 at 7:44 am #10941297 | |
Bruno Kos WPML Supporter since 12/2018
Languages: English (English ) German (Deutsch ) French (Français ) Timezone: Europe/Zagreb (GMT+02:00) |
Hi, Can you try the following: And then run "Generate .mo files" when it appears. Has it helped? Regards, |
April 4, 2022 at 9:28 am #10942625 | |
I've just done that, everything went without errors, but the problem still remains. |
April 4, 2022 at 9:36 am #10942813 | |
Hi, Can I ask you the following? In order to debug this issue, I will install Duplicator plugin, will create packages and will try this on my localhost and escalate further to 2nd tier. Also send me at least one screenshot to show me in the frontend where any of such strings don't show up (or URL would do). I will exclude all the media files, etc, to keep the package minimal. https://wpml.org/faq/provide-supporters-copy-site/ Let me know if this is OK with you. If yes, I will need WordPress admin username and password so I could do this. I marked your next reply private so you can safely add this information. Please make a full backup of your site before sharing this info! Regards, |
April 5, 2022 at 7:48 am #10950961 | |
Hi, I get error 400 when trying to create Duplicator package, can you check with hosting what's happening there? And exclude media files (wp-uploads folder) when creating a package. Regards, |
April 5, 2022 at 11:21 am #10953149 | |
I'll setup a staging environent on our dev servers durring the day and send you access details. |
April 5, 2022 at 11:54 am #10953575 | |
Ok, I marked your next reply private so you can safely add credentials for the staging site. |
April 6, 2022 at 7:16 am #10960243 | |
Hi, This is escalated to our 2nd tier team and may take some debugging time, I'll get back to you as soon as I have any news or questions for you. Regards, |
April 6, 2022 at 12:01 pm #10964005 | |
Hi, Can you install and activate this plugin? Does it help? Regards, |
April 6, 2022 at 12:10 pm #10964079 | |
I don't see how it could help, since string translation doesn't have anything to do with CF7 plugin, string translation doesn't work site wide, not just in the header. None of the string translated in WPML String Translation is working in Serbian language, unless we enable Auto register strings for translation. |
April 6, 2022 at 12:36 pm #10964481 | |
I know it is a bit weird case, we were surprised too, but you can check hidden link now. Technically this happens because of "Listo" plugin. This plugin calls the following: switch_to_locale( $locale ); and this unloads all localized .mo files for the sr_RS locale, as it calls it with "en_US". Since this plugin is directly connected to CF, when you install CF7ML it filters the calls to switch the locale so it is necessary to have it. |
April 6, 2022 at 12:50 pm #10964685 | |
Nope, it's not working on production, you can see for yourself hidden link Plugin is installed and enabled. |
April 6, 2022 at 12:55 pm #10964733 | |
Does it work if you clear all the caching cached by W3 Total Cache? |
