I'm trying to send strings to automatic translation from WPML > String Translation but there is a notice message:
"Selected strings are not in the site's default language and will not be translated automatically if you're using the "Translate Everything Automatically" mode. Instead, after sending them for translation here, you need to go to the WPML -> Translations page and translate them manually".
Currently, WPML does not support sending strings to automatic translation if the source language of strings is not in the site's default language. You can follow the documentation to change the language of strings and send them to automatic translation.
Relevant Documentation:
https://wpml.org/documentation/getting-started-guide/string-translation/how-to-change-the-source-language-of-strings/
Last updated by 1 year, 11 months ago.
Assisted by: Long Nguyen.
