You want to add an extra website to your WPML subscription and translate only selected pages automatically.
First, install the WPML plugin on your new website and start the configuration process. Next, generate a new site key for this website through your account on wpml.org. During the installation, choose the "Translate What You Choose" method to ensure that only the pages you select are translated automatically. For more details on sending content for automatic translation, visit https://wpml.org/documentation/translating-your-contents/#sending-content-for-automatic-translation.
If this solution does not apply to your case, or if it seems outdated, we recommend opening a new support ticket. We also highly suggest checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please contact us through the WPML support forum.
Last updated by Andrey 1 year, 7 months ago.
Assisted by: Andrey.
August 6, 2024 at 12:59 pm #16044043
oliverh-53
I have automatic translation on two pages using WPML. I want to add an extra website to the subscription and translate it. On the new website, I only want to translate some of the pages and not all automatically.
No specific issue or error message mentioned.
How do I add an extra website to the subscription?
How do I get the new website to translate?
How do I translate only some of the pages on the new website and not all automatically?
August 6, 2024 at 1:15 pm #16044078
Andrey
WPML Supporter since 06/2013
You can install WPML plugin on a new website and begin the configuration process. Afterward, in your wpml.org account, you can generate a new site key for the new website.
During installation, you will have to select the "Translate What You Choose" method. This setting will enable you to translate automatically only the pages you select.
