This topic is split from https://wpml.org/forums/topic/approving-translations-reviews-failed/
Last updated by sebastiaanV-11 1 year, 10 months ago.
Assisted by: Bigul.
October 21, 2022 at 6:38 am #12284465 | |
sebastiaanV-11 |
We have discussed this already in another ticket but should be relevant to this one: The below products show the in the URL the Dutch category, though it should be in English. It seems only these have the issue, and it's only the category. I believe these are the same products that show as "Published — Pending review" in the translations queue. So it's related to each other. hidden link hidden link hidden link hidden link I believe this PHP warning is also related to the issue: [19-Oct-2022 14:25:18 UTC] PHP Warning: Attempt to read property "element_id" on null in /home/mymoissanite/public_html/staging/wp-content/plugins/sitepress-multilingual-cms/classes/API/REST/jobs/class-wpml-tm-rest-jobs-view-model.php on line 171 |
October 21, 2022 at 10:14 am #12286203 | |
Bigul Supporter
Languages: English (English ) Timezone: Europe/Vienna (GMT+02:00) |
Hello, Welcome to the WPML support forum. I will do my best to help you to resolve the issue. This looks like a conflict with the Rank Math SEO plugin. On my local copy, it works fine when the Rank Math SEO plugin is inactive. So I have shared the details with my team and waiting for their feedback. Please wait. -- Bigul |
October 23, 2022 at 2:15 pm #12295441 | |
sebastiaanV-11 |
Yes, that works. Thanks. Will wait further guidance. |
October 24, 2022 at 11:48 am #12299929 | |
Bigul Supporter
Hello, Thank you for the confirmation. The issue is escalated to our second-tier team for further debugging. We will get back to you as early as possible. Please wait. -- Bigul |
November 3, 2022 at 10:03 pm #12375085 | |
sebastiaanV-11 |
Hello. May I please receive an update? This issue prevents us from launching our staging site to live, because of faulty URL's. Thank you. |
November 4, 2022 at 4:57 pm #12384495 | |
Bigul Supporter
Hello, Our second-tier team is still working on this. We will get back to you as early as possible. Please wait. -- Bigul |
November 7, 2022 at 9:16 am #12396701 | |
Bigul Supporter
Hello, We have a workaround for this bug. Please try the following steps after a full site backup{mandatory} and make sure the issue is existing or not. 1) Go to *wp-content/plugins/seo-by-rank-math/includes* folder From private function get_primary_term( $taxonomy, $post_id ) { $primary = Helper::get_post_meta( "primary_{$taxonomy}", $post_id ); if ( ! $primary ) { return false; } $primary = get_term( $primary, $taxonomy ); return is_wp_error( $primary ) || empty( $primary ) ? false : $primary; } To private function get_primary_term( $taxonomy, $post_id ) { $primary = Helper::get_post_meta( "primary_{$taxonomy}", $post_id ); $test_post = apply_filters( 'wpml_post_language_details', NULL, $post_id ); $test_meta_id = apply_filters( 'wpml_element_language_details', null, array('element_id' => $primary, 'element_type' => $taxonomy ) ); if ( isset($test_post["language_code"]) && ($primary != "") && $test_post["language_code"] != $test_meta_id->language_code ) { $primary = apply_filters( 'wpml_object_id', $primary, $taxonomy, TRUE ); } if ( ! $primary ) { return false; } $primary = get_term( $primary, $taxonomy ); return is_wp_error( $primary ) || empty( $primary ) ? false : $primary; } 5) Visit Settings>>Permalinks & resave the settings -- Bigul |
November 7, 2022 at 11:03 am #12398243 | |
sebastiaanV-11 |
Thank you. This indeed fixed the issue. I appreciate it! What should I do when there's a rankmath update? |
November 7, 2022 at 12:42 pm #12399819 | |
Bigul Supporter
Hello, Thank you for the feedback. Happy to know you are getting the expected results now. We are not able to reproduce the issue exactly in a fresh installation. So as of now it is an exception and hopes it will be fixed in the future version of the Rank Math plugin. May you have to append this fix code to the latest version of the plugin also. -- Bigul |
November 10, 2022 at 6:15 am #12425959 | |
sebastiaanV-11 |
Thank you! |
