The client is experiencing issues with string translation from English to German. Despite changing words to German in WPML String Translation, the correct results are not showing. Additionally, strings such as "write your review," "submit review," and "show chat" are not found in the WPML String Translation.
If you're experiencing similar issues, we recommend you try the following steps:
1. Go to WPML -> Theme and plugins localization, select your theme/plugin, and scan.
2. Navigate to WPML -> String Translation.
3. Scroll down and click on the "Translate texts in admin screens »" link.
4. Search for the needed strings.
5. Select the strings.
6. Click on the "Add to String Translation" button.
7. Then click on the "« Return to String Translation" link.
8. Translate the strings, clear the cache, and check the front end.
For more detailed guidance, kindly check our guide on translating texts in the admin texts screen.
Please note that the solution provided might be irrelevant due to being outdated or not applicable to your case. If the issue persists, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please do not hesitate to open a new support ticket. Contact WPML support.
Last updated by Osama Mersal 1 year, 4 months ago.
Assisted by: Osama Mersal.
March 4, 2024 at 7:48 am #15367779
pascalW-18
There are some issues with string translation from English to German. I have already changed the words to the German language in WPML string translation, but it is not showing the correct results. Additionally, some words such as "write your review," "submit review," and "show chat" cannot be found in the WPML string translation, and I am unsure why. Please help me.
page link:
1) Single product pages, e.g. hidden link also when you click on contact agent.
2) Profil pages, e.g. hidden link
3) Booking confirmation: hidden link
Your support would be greatly appreciated.
Many thanks
March 4, 2024 at 8:26 am #15367919
Osama Mersal
WPML Supporter since 02/2020
Please try the following steps:
1- Go to WPML-> Theme and plugins localization, select your theme/plugin, and scan
2- Go to WPML-> String Translation
3- Scroll down and click on the "Translate texts in admin screens »" link
4- Search for the needed strings
5- Select the strings
6- Click on the "Add to String Translation" button
7- Then click on the "« Return to String Translation" link
8- Translate the strings, clear the cache, and check the front end
Kindly check our guide to know more about translating texts in the admin texts screen. (https://wpml.org/documentation/getting-started-guide/string-translation/finding-strings-that-dont-appear-on-the-string-translation-page/)
Osama
March 4, 2024 at 1:37 pm #15369888
pascalW-18
check this page:
some words are not chaged into german infect i changed it into wpml string translation like:
"Description","Author Info","Location","Address","Comment "
March 4, 2024 at 1:49 pm #15369910
Osama Mersal
Please go to Directory Builder-> General DE, edit the Single Layout, and translate these strings. (Kindly check the attached screenshot)
Osama
March 7, 2024 at 5:04 am #15382158
pascalW-18
still some words are not changed yet , infect I have already change it Directory Builder-> General DE, edit the Single Layout, and some words like "Author Info", "Contact Agent", "View Profile", "Show Chat" I can't found these words.
March 7, 2024 at 7:53 am #15382505
Osama Mersal
Those strings can be translated by the steps mentioned in this reply. (https://wpml.org/forums/topic/there-are-some-issues-with-string-translation/#post-15367919)
I translated a string on the staging site to check if it works correctly. (Kindly check the attached screenshot)
Osama
March 8, 2024 at 12:56 pm #15389304
pascalW-18
Thank you for providing a solution to my previous query. However, I am unable to translate the following words:
1) Author Info - Autoreninfo
2) Contact Agent - Kontaktieren Sie den Agenten
3) View Profile - Profil anzeigen
* I have uploaded the screen shot related to this issue.
4) Show Chat - Chat anzeigen.
The webpage link for translation is: hidden link
Please assist from your end as I am unable to translate these words.
If you want any further information relatated about this page then let me know.
March 9, 2024 at 9:53 am #15391237
Osama Mersal
I would need to access your live site as on the staging site, I can locate and translate these words.
Osama
March 11, 2024 at 9:57 am #15394033
Osama Mersal
I translated the mentioned strings via String Translation. (hidden link)
Please check if they are translated correctly on the front end. (hidden link)
Osama
March 11, 2024 at 10:45 am #15394266
pascalW-18
Thank you so much for your support.
March 12, 2024 at 1:29 pm #15399596
pascalW-18
Hey ,
I have some issues on the page :
1) In english version some option block like "Appointments" is showing but same option block is not showing in the french version: hidden link
2)In this link : hidden link , author info in german "posted 4 month ago" is not showing into english.
3)go to this link : hidden link / , the bookin confirmation link is also can't translate into english.
4)In this page: hidden link , english/ german switcher is not showing.
, I have also upload an images for all problems. please can you solve it from your end , I can't do that.
you have all the access of server before I gave you.
New threads created by Osama Mersal and linked to this one are listed below:
https://wpml.org/forums/topic/split-there-are-some-issues-with-string-translation/
March 12, 2024 at 1:37 pm #15399718
Osama Mersal
We try to keep one issue per ticket in our forum. Continuing with one ticket per issue helps supporters focus on one issue at once and enables other users to find solutions to their questions faster.
Therefore, I've split the other issue and created a new ticket with this issue. (https://wpml.org/forums/topic/split-there-are-some-issues-with-string-translation/)
Osama
