Home›Support›English Support›[Resolved] Translated featured images on Blog post and ACF Post pages are not showing
Problem: You are unable to see translated featured images on blog posts and ACF Post pages. Solution: If you're experiencing issues with translated featured images not appearing on your blog posts or ACF Post pages, we recommend checking for any error messages within the image blocks. In a recent case, clicking the 'Attempt Recovery' button resolved the issue when the image block displayed a message about unexpected invalid content. Please try this and confirm if the images appear correctly in your translated content.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Our Debugging Procedures
I can confirm that the featured images are showing on the backend under individual Press posts, so I need to learn more about how you are displaying these posts on the frontend. Are you using a custom template, custom code, so that I can review and try to find why the content on the backend is not showing on the frontend? Please let me know where you are setting the backend content to display on the frontend so I can look further into this. Thanks!
Hi Lauren, I am not using any custom template; we are using the GeneratePress theme. I made a video to show you my current settings. See video here: hidden link
Thanks for the video, this prompted me to open the translation using the WordPress editor and as you can see from my attached screenshots, there are no fields showing in the translation to set the image to "featured image". How are you adding these fields to this page in the original language?
I have only created these posts in the original language. I have not edited or changed the "featured image" setting in the translated posts. I believe the settings are the same for all of all the press posts.
To change the tags, you have to click edit in the list view (see image). The two tags are "term list" and "meta post tag," I believe. They list fields from "categories" and a tag called "post date".
I noticed in your last screenshot that the image block had a message about unexpected invalit content. I clicked the Attempt Recovery button on the French page and it appears to have resolved the issue. Can you please confirm that you now see the images in French? hidden link
