This topic contains 4 replies, has 3 voices.
Last updated by Itamar 11 months, 1 week ago.
Assisted by: Itamar.
August 27, 2024 at 5:06 am #16107263
lucB
We have a problem translating a button on our Avada website.
Our Avada button uses ACF data as a dynamic parameter for the url and content.
On the original language, everything works fine, but in the translated page, there is no href.
The ACF data is translated correctly, we can show that content using a text block with dynamic content, and it shows fine.
However, the "dynamic_params" attribute of the "fusion_button" doesn't seem to be translated correctly. The dynamic parameters are a base64-encoded: eg:
eyJsaW5rIjp7ImRhdGEiOiJhY2ZfdGV4dCIsImxpbmsiOiIiLCJmaWVsZCI6ImUtbWFpbF9hdXRldXIiLCJiZWZvcmUiOiJtYWlsdG86IiwiYWZ0ZXIiOiIiLCJmYWxsYmFjayI6IiMifSwiZWxlbWVudF9jb250ZW50Ijp7ImRhdGEiOiJhY2ZfdGV4dCIsImVsZW1lbnRfY29udGVudCI6IiIsImZpZWxkIjoidm9vcm5hYW1fYXV0ZXVyIiwiYmVmb3JlIjoiTWFpbCAiLCJhZnRlciI6IiIsImZhbGxiYWNrIjoiIn19
"link":{"data":"acf_text","link":"","field":"e-mail_auteur","before":"mailto:","after":"","fallback":"#"},
"element_content":{"data":"acf_text","element_content":"","field":"voornaam_auteur","before":"Mail ","after":"","fallback":""}
But the advanced translation editor shows the element_content.before value of the decoded content, instead of the base64-encoded hash.
For the fusion_social_links shortcode, it shows the dynamic_params correctly as en encoded value.
The wpml-config.xml of Avada doesn't tell WPML to decode the attribute:
fusion_button
link
title
dynamic_params
I can't find any config that tells WPML to base64-decode the dynamic_params of the fusion_button shortcode.
Can you help us fix this problem?
August 27, 2024 at 5:59 am #16107359
Dražen
Thanks for contacting us.
Can you please try to add a new custom XML configuration for this button but also add encoding part to that attribute
encoding="base64"
- https://wpml.org/documentation/support/language-configuration-files/register-page-builder-content-for-translation/#:~:text=You%20can%20use%20the%C2%A0encoding%C2%A0attribute%20with%20this%20one.%20It%20handles%20special%20encoding%20that%20various%20page%20builders%20use.%20The%20encoding%20attribute%20is%20usually%20specific%20to%20the%20page%20builder%20you%20use.%20It%20accepts%20the%20following%20values%3A
You will need to add it to WPML > Settings > Custom XML. Change your title a bit resave your page in the default language and then re-translate.
Let us know how it goes.
Drazen
September 4, 2024 at 9:06 am #16139244
lucB
Hi Drazen,
We've added the following to our XML config, but it doesn't work.
<wpml-config>
<shortcodes>
<shortcode>
<tag>fusion_button</tag>
<attributes>
<attribute type="link">url</attribute>
<attribute>title</attribute>
<attribute encoding="base64">dynamic_params</attribute>
</attributes>
</shortcode>
</shortcodes>
</wpml-config>
And we've tried it with 'encoding="base64,json"', but this doesn't seem to work either.
It only shows "fusion_button dynamic_params before" and no other fusion_button parameters.
When we use the following, it does work because the dynamic_params attribute is not translated at all.
<wpml-config>
<shortcodes>
<shortcode>
<attributes>
</attributes>
</shortcode>
</shortcodes>
</wpml-config>
Is there another possibility to do this because the dynamic_params cannot be translated on any button now.
Kind regards
September 4, 2024 at 3:17 pm #16141688
Itamar
WPML Supporter since 02/2016
If you are using an off-canvas element, please check the following known issue and try to apply the suggested workaround.
https://wpml.org/errata/avada-new-off-canvas-elements-not-appearing-as-translated-in-the-front-end/
Itamar.
September 4, 2024 at 3:22 pm #16141708
Itamar
In addition to the above, please also check the following errata.
https://wpml.org/errata/avada-cart-count-widget-dynamic-parameters-not-fully-available-for-translation/
If you need further help, please share your site's Debug information. You can read about it here.
Itamar.
The topic ‘[Closed] Translating buttons with ACF parameters using Avada’ is closed to new replies.
