The client was facing issues with the mobile menu in the Italian version of their site. The problems included incorrect font size, missing icons, and a missing HOME link. The mobile menu was incorrectly showing desktop menu items instead of mobile-specific items.
1. We advised the client to manually translate the mobile menu by switching to the Italian version in WP > Design > Menu. This can be done using the language switcher at https://bau24.ad-passion.it/wp-admin/nav-menus.php?menu=27&lang=it.
2. For translating menus that appear differently in each language, we recommended using the method described in Translating Menus That Appear Different in Each Language.
3. To address the issue of the mobile menu displaying desktop items, we corrected the menu assignment for the Italian mobile version as shown in the provided screenshot.
4. For the missing HOME menu item, it should be added manually via https://bau24.ad-passion.it/wp-admin/nav-menus.php?menu=26&lang=it.
5. The issue with the font size is likely controlled by the theme options, and we suggested checking how the mobile menu is styled within those settings.
If this solution does not resolve your issue or seems outdated, we recommend opening a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at https://wpml.org/forums/forum/english-support/.
This topic contains 10 replies, has 0 voices.
Last updated by Kor 7 months, 1 week ago.
July 20, 2025 at 9:53 am #17252841
waldemarK
I am trying to copy the mobile menu from the German (DE) version to the Italian (IT) version, including font size and settings like icons. The issue can be seen on this page: hidden link
The mobile menu in the Italian version has the wrong font size, missing icons, and a missing HOME link.
How can I ensure the mobile menu settings are copied correctly from DE to IT?
Why are the font size, icons, and HOME link not appearing as expected in the IT version?
July 21, 2025 at 9:59 am #17254697
WPML Supporter since 08/2022
Thanks for contacting us. I need to check how the navigation menu is created. I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
July 21, 2025 at 5:09 pm #17256961
Thanks for your reply.
I've checked and I can see the missing arrows in the Italian language mobile menu as shown in this screen recording hidden link . Could you please edit this menu in WP > Design > Menu > Switch to Italian using the language switcher and translate it hidden link .
Let me know how it goes.
July 21, 2025 at 5:18 pm #17256968
waldemarK
Yes I suppose that this manual job will work.
I am not using a plugin like WPML to doing it manually, but I hoped to get that automatically. Hopy ou understand. If tomorrow the clients likes dots instead of arrows i have to do it again
And this still does not resolve in IT
– why HOME is not shown
– why the font is bigger
I thing that the better way is to make it automatically using one of the custom or system fields in WPML > settings. I did this for theme specific page settings, so I suppose for theme specific menu settings it will work in the same way… BUT which one I have to click?
July 21, 2025 at 5:33 pm #17257008
Thanks for your reply. Unfortunately, translating a navigation menu does not work the same way as translating a page or post. There is no option to copy the mega menu items options directly. You will need to use one of the methods described here:
https://wpml.org/documentation/getting-started-guide/translating-menus/#translate-menus-different-per-language
I used the "Translating Menus That Appear Different in Each Language" method to resolve the issue you encountered.
For the missing Home menu item, you can add it manually here:
Regarding the font size, it appears the styling is controlled in the theme options. Could you check how the mobile menu is created?
July 21, 2025 at 5:38 pm #17257011
waldemarK
Hi Kor, yes I know how to translate a menu, did it over 30 times.
The font size in DE is correct, but not on IT, handled by wpml
sure that there are no menu settings to copy/copy once/translate?
July 21, 2025 at 5:41 pm #17257012
waldemarK
like these
July 21, 2025 at 5:49 pm #17257079
waldemarK
Sorry for writing again. I discovered the problem, the sync is wrong
In IT on mobile it shows the deskop menu, not the mobile menu
I added an icon on the IT mobile menu and nothing happens, so I addes an icon on the desktop menu… and I can see it also on mobile
= in DE I have desktop menu for desktop and mobile menu for mobile
= in IT I have desktop menu for desktop and desktop menu for mobile
why that?
July 22, 2025 at 4:23 pm #17260381
Thanks for your reply. The mobile menu has been assigned incorrectly here hidden link . I've corrected it for you as shown in the attached screenshot and it shows up fine now. Could you check?
July 22, 2025 at 4:36 pm #17260428
waldemarK
Hi Kor,
thank you for the help. This was a stupid mistake, sorry for that. I thought that Betheme does assign them automatically.
So I just need to resolve the font size problem and to insert all icons manually.
Maybe tell to devs if in the future that settings could be copied trough languages.
July 22, 2025 at 4:38 pm #17260433
Thanks for your reply. I will forward your feedback to our devs. If you need anything further, feel free to open a new ticket/chat.
