The client reported issues with incorrect translations in the menu across all languages and problems with the placement and visibility of the language switcher, especially on mobile devices. Additionally, the flags added to the menu were causing the header to shift, and there were discrepancies in media visibility across different languages.
1) We corrected the menu translations. The client needs to manually edit the translated menus to include translations for specific strings like 'About Us'.
2) For the language switcher issues, we recommended checking the guide on language switchers to learn about adding them in different locations.
3) To address the footer not being translated, the client should navigate to Footer-> All Footers in their site's admin area and translate the footer.
4) For media not appearing correctly in other languages, we advised going to WPML-> Media Translation and referred the client to the media translation guide.
If this solution does not resolve your issues or seems outdated, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If problems persist, please open a new support ticket.
This topic contains 18 replies, has 0 voices.
Last updated by Osama Mersal 4 months ago.
Assisted by: Osama Mersal.
December 14, 2025 at 10:02 am #17661937
homeP
Translation and Flag Issues
The menu was translated incorrectly in all languages.
The other problem is with the flags; when I add a flag to the menu, the header is completely shifted.
December 15, 2025 at 11:22 am #17663849
Osama Mersal
First, apologies for the delayed response; it was due to a higher workload.
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
❌ Please back up your database and website ❌
✙ I need your permission to deactivate and reactivate plugins and themes, and to change site configurations. This is also why the backup is critical.
Osama
December 21, 2025 at 10:13 am #17680447
Osama Mersal
Hi Nuno,
Thanks for the access details, and sorry for the late reply due to the weekend.
I checked the issue and found that the menu was not translated correctly, so I translated it.
You will need to edit the translated menus to translate the About Us strings.
Osama
December 21, 2025 at 11:03 am #17680471
homeP
Hello Osama,
No problem at all — I understand that it is the weekend and that the page has other priorities.
However, the language switcher is currently placed in the wrong location. I do not want it inside the menu, but outside of it. Otherwise, this causes issues on mobile, where the language selector is not visible in the header.
I also noticed that the footer is not being translated. Additionally, there are issues with media translations.
In the original English version, all media elements are visible:
In other languages, not all media items are available:
December 21, 2025 at 12:03 pm #17680498
Osama Mersal
1) Please check this guide to know more about language siwtchers and how to add them in different locations.
2) Please go to Footer-> All hidden link">Footers, and translate the footer.
3) To translate the media, please go to WPML-> Media Translation. Please refer to this guide for more information on media translation.
Osama
December 22, 2025 at 7:47 am #17681361
homeP
thank you for the instructions. I know how to set the language, but unfortunately, when I do that, the entire header shifts. This is also mentioned in my first message.
December 22, 2025 at 7:51 am #17681393
homeP
Footer hidden link
Media: hidden link
I don't feel like manually translating every piece of media.
December 22, 2025 at 8:05 am #17681411
Osama Mersal
1) Please add the language switcher and let me know how it breaks the header.
2) When you go to the footers, please make sure to select English.
3) You don't need to translate them manually. When you translate a page, post, or product, WPML automatically translates the media for that content.
Osama
December 22, 2025 at 12:48 pm #17682159
homeP
It seems to be working now.
There's a new problem. I can't change the language on my phone. Pressing the button doesn't bring up any other languages.
December 22, 2025 at 1:08 pm #17682195
Osama Mersal
It seems there is a CSS conflict because the languages appear on the side. (Kindly check the attached screenshot)
Please let me know if you use custom CSS in the header so I can check it.
Osama
December 23, 2025 at 7:21 am #17683909
homeP
I don't have any custom CSS. The site is new and everything is original. I do have custom CSS under WPML language. I copied this custom CSS from the other website you mentioned about two weeks ago 🙂
December 23, 2025 at 7:36 am #17683938
Osama Mersal
Hi Nuno,
Thanks for your update. I've edited the switcher CSS. Please check if it works as expected.
Osama
December 24, 2025 at 2:42 pm #17686715
homeP
It's good on mobile. On desktop, the flags are now offset on the right side, instead of stacked vertically!
December 24, 2025 at 2:49 pm #17686719
Osama Mersal
I've edited the switcher CSS for desktop. Please check if it works correctly.
Osama
December 24, 2025 at 3:09 pm #17686741
homeP
A sticky header has a frame (shadow) present.
If the normal header is okay, that was the cache; after clearing the cache, the flags are stacked vertically.
