The client was experiencing 404 errors when trying to access translated versions of their pages. The issue was related to the disappearance of translation links in the menu, which seemed to occur intermittently, often after automatic updates. The client had integrated absolute links of the pages into the menus rather than selecting these pages directly in the menu settings.
We recommended that the client delete and recreate all menus in the required languages (FR, EN, DE) and then use the WPML > Synchronize WP menus function to ensure proper synchronization. It's important to note that custom menu items can only be translated using WPML > String Translation or adjusted manually within each menu, as WPML Menus Sync cannot automatically handle custom menu items. For more detailed guidance on translating menus, please visit Translating Menus Documentation.
If this solution does not resolve your issue, or if it seems outdated or irrelevant to your specific case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should further assistance be needed, please open a new support ticket at WPML Support Forum.
This topic contains 7 replies, has 1 voice.
Last updated by Andreas W. 5 months, 2 weeks ago.
January 21, 2025 at 4:57 pm #16620012
ronanL-3
I am trying to check my page at hidden link and expected to see it translated into French.
Translation links disappear and cause 404 errors. Instead of seeing my page translated into French, I got an error 404.
Why are the translation links disappearing?
How can I fix the 404 error on the translated page?
January 21, 2025 at 5:04 pm #16620025
ronanL-3
ok, pour comprendre le contexte du probleme, je décris plus en détails.
Dans le menu du site en Français, il y a "Nos chambres" > "Chambre Sandro & Delos" le lien en Français est :
Cependant, dès fois le lien change tout seul, (sans que l'on ne sache pourquoi) et se transforme en lien en anglais, ce qui provoque une erreur 404 :
Puis d'un coup, sans que l'on ne sache pourquoi, il revient en Français et tout ce remet à focntionner normalement.
Que faut-il faire pour que cela soit stable ?
January 21, 2025 at 5:20 pm #16620039
ronanL-3
I have integrated the absolute links of the 4 rooms pages into the menus rather than directly selecting these 4 pages in Appearance > Portfolio Menus + add to menu
January 22, 2025 at 8:29 am #16621432
Waqas Bin Hasan
WPML Supporter since 05/2014
Thank you for contacting the support. Meanwhile this ticket is attended by one of my colleagues, I checked your site thoroughly and can see all the links working properly for default language, as well as, for English and German.
Can you find any pattern that when exactly the said issue happens? I mean any update in the content, or in server?
However, is it possible for you that you isolate the site into a separate copy, as soon as this issue happens, before even fixing it? So then we can observe the problem and proceed accordingly.
Regards.
January 22, 2025 at 6:24 pm #16624822
ronanL-3
the difficulty is that it appears and disappears a few minutes later and often following automatic updates, but I am not sure. At the time I am writing this request, there is no problem.
I'll clarify the problem:
When I click on the menu on "Our rooms > room-sandro-delos" from the French version, the page that appears is a 404 error page and the link in the URL is rewritten https://
www2.lheurebleueprovence.fr/ubernachtung-mit-fruhstuck-villeneuve-les-avignon/studio-sandro-delos/
instead of:
Then by visiting other pages, then returning to the French version and then again "Our rooms > room-sandro-delos" the page is displayed correctly.
It's incomprehensible.
I just copied the entire thing (files and database) to the test domain hidden link
The admin for the Wpml team:
Admin url: hidden link
user: wpml@intrasite.fr
Password: WXVzTJFJ!c7yytMCt0%TH%hs
I'll let you watch and tomorrow I'll redo the translation of the menus into English and German
Good luck.
Ronan
January 25, 2025 at 6:09 pm #16633854
It looks like you sorted the problem out already.
Take note, that:
Your menu uses custom menu items and such items can only be translated with WPML > String Translation or can be adjusted inside each menu manually.
WPML Menus Sync can not do this automatically in this case.
Translating menus:
https://wpml.org/documentation/getting-started-guide/translating-menus/
Let me know if you have any further doubts or questions.
January 27, 2025 at 6:42 am #16635934
ronanL-3
I just deleted and redid all the menus in FR EN DE, then I used the menu synchronization function in WPML > Synchronize WP menus
This seems to work, can you just tell me if this respects the recommended operation of WPML?
Ronan
January 28, 2025 at 9:07 am #16640417
Yes, this sounds correct and I am glad to hear that it worked out.
WPML's Menus Sync will auto-create and sync any pages that are used inside your menus but it can not create translations for custom menu items.
Custom menu items need to get translated at WPML > String Translation or can be adjusted inside each menu directly.
