The client was experiencing an issue where part of the layout was missing from the translated page of their website, even though it was visible in the source code.
We investigated the issue and initially thought it might be related to the Spectra plugin. However, further investigation showed that the problem was not with Spectra, as other translated pages displayed correctly. The client then experimented by removing different blocks from the page and discovered that a specific block was causing the issue. Once this block was removed, the layout appeared correctly on the translated page.
If you're experiencing a similar issue, we recommend trying to isolate the problem by selectively removing components or blocks to see if one might be causing the layout to break. Additionally, ensure that all plugins and themes are up to date.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by 1 year, 8 months ago.
Assisted by: Waqas Bin Hasan.
